Question about Microsoft Xbox 360 Console
Light is on and green but no video coming out to television what might be the problem.
  • 31 Answers
Typically, this problem occurs if the audio/video (A/V) cable is not connected correctly, or if the A/V cable is faulty.
Solution 1: Set the television or monitor to the correct input
Make sure that the TV or monitor is set to the correct input for the console. Check the TV or monitor's manual to see how to configure the video inputs, or try to use the console on a different TV or monitor.
Solution 2: Connect the A/V cable securely
Sometimes, you can insert the A/V cable far enough to prevent any red lights from flashing on the Xbox 360 console but not far enough for the console to transmit images or sounds to the screen.
Solution 3: Switch the Xbox 360 Component HD AV Cable to the correct setting
Make sure that the TV/HDTV switch on the cable is set correctly.
  • For standard-definition TVs with only the yellow connector plugged in, set the switch to TV.
  • For high-definition TV or monitors with the red, blue, and green connectors plugged in, set the switch to HDTV.
For more solutions, check this web page.
Posted on Oct 09, 2010
The tv will flash a green light and will turn off, it doesnt turn on either when you power it on
if the green light is a flash on screen with retrace lines most likely the video driver ic on the green crt board , just take the speaker grill .
theair should be a way to get to crts. the one in the center is the green crt. the green video driver ic is an inline 24 pin ic.
to test unplug the video drive plug leading to green crt board turn tv on .if it comes up its a bad ic.
if not unplug the crt socket ,and try to turn it on if it comes up
bad crt internal short hope this helps, butler
Oct 02, 2016 | Televison & Video
Changed the main board in my Toshiba 23HLV87, the green light comes on but no picture or sound nor will the green light go out when pushing the power button
I would investigate the T-con board (Timing control board). If you do not have sound or video as you say, it may be the T-con board that will need replaced.
Oct 05, 2013 | Toshiba 23HLV87 23 in. LCD Television
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi ws-55859 reset light flashing won't reset
You have blown capacators in your DM board. Here is a video that I used that guides you step by step video instructions for repairing TV. Bought the capacators at Radio shack for appx. $2/each.
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
Jun 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Vizio 50" P50hdm Audio with No Video
when tv is on horz trans is damge
Apr 10, 2008 | Televison & Video
Video Shuts Off - Green Light Flashes
Your lamp most likely needs to be replaced. Not uncommon for this to happen.
Nov 30, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Green color comes on and off
I need some answers here... Do you have only one video source to test it? Is this happening with an external source or with your tv tuner or both? I need more info....
Aug 10, 2007 | Samsung HCL4715W 47" Rear Projection...
Green lights
HELLO I WOULD REPLACE THE HOLE BOARD.!!! AND GO FROM THERE. HOPE THIS HELP'S YOU.!!! "GOOD LUCK"
Oct 29, 2006 | Hitachi 50UX58B 50" Rear Projection...
Microsoft Xbox 360 Console Logo
103 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
