Question about Kenmore 63942 Dryer
The dryer isn't getting hot, clothes aren't drying. It's a gas dryer, so I'm not sure why it won't get hot
  • Kenmore Master
  • 2,694 Answers
Remove the bottom panel and start the dryer,if the ignitor isn't glowing orange or red then you could have a bad thermal fuse located on the blower wheel housing,a bad ignitor or a bad sensor located on the left side of the ignitor and on the outside of the burner tube,you'll need a meter to check the parts out,unplug the dryer,you need to pull at least one wire off the part you're going to check,the part will give you a reading or no reading it's that simple,if you get a reading it's good,if it stays on 1 and nothing else it's bad.if the ignitor is glowing then you have bad gas coils,bad gas valve or the ignitor could still be bad but most of the time if it's glowing it's good.if the dryer hasn't been cleaned in a long time check the thermal fuse first,pull out the lint filter,then remove the duct that the filter slides into and you'll see the thermal fuse on the right hand side of the blower wheel,it will be a 3392519 or a 3390719,these are the common fuses,if that's good read out the other parts,also if the fuse is bad you need to clean out the lint filter duct,vac out the bottom part of the dryer,then remove the vent line and blow it out if it's long,i use a leaf blower and it cleans the line out,go outside first and make sure the vent is clear so when you blow out the line nothing is blocking the lint from blowing outside,i've seen bird nests blow out of the line.clean it out once a year so you don't have a fire,the fuse won't blow again and your clothes will dry on time,let me know how you make out
Posted on Oct 09, 2010
My cloth dryer won't dry. It is not hot.
is it gas or electric, vent could be clogged. could need starting device. solonoid, or ignitor.
May 20, 2012 | Whirlpool Dryers
WHIRLPOOL DUET DRYER-Line clogged with wet lint from daughter air drying all of her delicate heat shrinking clothing. Dryer quit heating all at once that is when I discovered all of the wet lint in the...
if your dryer does not seem to be drying the wet clothes, first check that it is generating heat. If not, check the vent to make sure it is clear.
If the dryer runs but fails to heat clothing, check the circuit breaker. Most dryers use so much electricity that their functions are divided between two breakers. If one has been tripped, that may be why the heating elements aren't functioning. If the dryer still isn't heating, unplug it and pull it away from the wall. There's a service access panel on the back that should be pried free. Inside, you'll find a small black strip of plastic with two blue wires attached. This is the heating fuse. A replacement part can be had for around $15, and takes a little less than 1 minute to swap out. It's unlikely that the heating element itself, which consists of a few metal coils, is broken. If the dryer still won't heat, you're better off getting a replacement dryer than repairing the old one
Dec 08, 2011 | Whirlpool Dryers
Dryer will get hot but will not dry clothes
If the dryer gets hot, but not drying the clothes my first question would be if the drum is turning or not. If not then I would check the belt and make sure it isn't busted. Then I would check to make sure that your exhause hose is not clogged up. If so clean out.
But if that isn't the problem then I would check the blower assembly.
Aug 07, 2011 | Dryers
My roper gas dryer seems to be getting heat (not very hot) but isn't drying clothes. the selector nob only turns under timed dry.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 23, 2011 | Roper RGX4634KQ Gas Dryer
WON'T DRY CLOTHS..NO HOT AIR
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'';';
Jun 27, 2011 | GE Dryers
Clothes are real hot to the touch
sounds like you have a venting problem,, check for clogs or blockage in the vent pipe,, and also at the exit from the house to be sure the vent cover flows freely and isn't smashed down. check inside this vent to be sure the flap inside of it moves freely and isn't stuck,, Normally when clothes get hot to the touch its caused by the clothes heating up to dry and the moisture isn't allowed to be vented out
May 24, 2011 | Whirlpool Dryers
Dryer is not getting hot, not drying clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 07, 2010 | Whirlpool LER4634J Electric Dryer
Dryer does not get hot enough to dry clothes
heatman101
May 19, 2010 | GE DBXR463EDWW Electric Dryer
DLE5977W does not get our clothes dry. It seems to get hot, but...
check your dryer vent. more than likely the vent is clogged with lint or kinked.
Nov 25, 2009 | LG DLE5977 Electric Dryer
Kenmore 63942 Dryer Logo
63 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
