Question about Whirlpool Duet GHW9150P Front Load Washer
I have a light on that says control locked, how do i fix it?
  • 347 Answers
Some of the time its a electronic issue , But if its simply locked controls push and hold for three to four seconds the signal cycle volume button on the lower right of the control panel,this will unlock the panel..
Posted on Oct 09, 2010
ABS & Traction control light are on, what is causing this?
About 39,700,000 results (0.44 seconds) Search Results
    Traction Control Light is on Inspection - YourMechanic
    www.yourmechanic.com > Auto Repair and Maintenance Services
    As a result, sometimes an issue in the ABS can trigger the traction control light. If this is the case, then both the ABS and Traction Control lights will be on.
    My anti-lock brakes and service traction control lights came on ...
    https://answers.yahoo.com/question/index?qid...
    Oct 16, 2006 - I drive a 2000 chevy impala...i have 135,000 miles on my car. ... The problem is that starting in '92, Anti-Lock Brakes are controled electronically, so if there is a problem with the sensor, your ABS might fail when you need them the most. ...ABS (?nti-lock Brake System) is a ...
    How To Fix ABS & Traction OFF / Service Traction System ...
    ? 5:35
    https://www.youtube.com/watch?v=KFQphWamcjQ
    Feb 17, 2014 - Uploaded by Zero Gar
    How To Fix ABS & Traction OFF / Service Traction SystemLight Monte ... side connector that leads from the ABS controlmodule to the speed ...
Feb 05, 2016 | Cars & Trucks
1999 Plymouth breeze door light keeps flickering on and off and my doot locks keep latching up and down
that sounds like the central locking controlling lock is malfunctioning , if it is the drivers door then that lock is the control lock and need replacing
Oct 27, 2014 | Cars & Trucks
Control off is on, how can I fix it?
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Apr 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control is locked
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The Dryer says "Control Locked"
Try pressing an holding the "End of Cycle Signal" button on the front panel in for 3 seconds. This button is used to lock/unlock the control panel to keep small children from manipulating the controls when the dryer is not in use. A designed safety feature. If this does not work for you, please post back and let me know. I hope this helps you.
Jun 25, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Mar 23, 2009 | Whirlpool ET8CHEXSQ Dryer
Control lock light is on , washer won't start
your controll is in child lock turnning power off wont fix find the lock button and push hold till light goes out
Feb 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
The Control Locked Light stays on and nothing else works
Is this like a child lock?? if so holding the appropriate button down for upto 10secs is the fix. is the control locked? it not its just the diode circuit which is faulty and will not effect the operation
Jan 01, 2008 | Kenmore Elite HE4 Electric Dryer
Flashing Control lock light
Press 'options' & 'select' for 5 to 6 seconds, controls may unlock (depending on your model) If it is a key you see, it is the child lock.
Apr 29, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool Duet GHW9150P Front Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
