Two big hoses attach to your radiator. Look for the one that goes back to the TOP of the engine. There is a housing with two bolts in it that the hose connects to. Drain radiator, remove hose. Remove the two bolts. Remove the housing. Thermostat is inside housing or still on engine. It just pulls out. Remove any remaining thermostat housing gasket material from the housing and the engine. Install new thermostat. Should only fit in one way. Install new thermostat housing gasket and the housing. Reattach hose and fill radiator, leaving the cap off. Turn on the car and wait until car gets to warm condition. You will see the water start to move from the radiator to the engine when the new thermostat releases at the proper temperature. Replace the radiator cap and clean up, you are finished.
From autozone.com Fig. Thermostat installation-4.5L and 4.9L engines
To install:
Trace the upper radiator hose to the mounting area on the intake manifold. Loosen the hose clamp on the manifold end of the hose and remove the hose. Pull the thermostat out of the intake manifold.
For more help and troubleshooting go through the help links below:---
Click the link below:-----
THERMOSTAT REMOVAL PROCEDURE/LOCATION DETAILS
Where is Thermostat Located on
Saturn
http://schematicsdiagram.blogspot.in/2012/06/2004-dodge-intrepid-how-to-replace.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-audi-a4.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-acura-car.html
http://repairhelpcenter.blogspot.com/2011/10/where-is-thermostat-located-on-2006.html
http://repairhelpcenter.blogspot.com/2011/10/thermostat-on-audi-19-tdi.html
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
How to Replace a Thermostat.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-thermostat.html
http://schematicsdiagram.blogspot.com/2011/12/how-to-locate-thermostat-on-any-car.html
http://technoanswers.blogspot.com/2011/12/where-is-thermostat-on-audi-a6.html
http://technoanswers.blogspot.com/2011/12/how-to-replace-thermostat-on-1992-buick.html
http://technoanswers.blogspot.com/2011/12/replacing-thermostat-on-1999-mercury.html
http://technoanswers.blogspot.com/2011/12/thermostat-replacement-on-toyota.html
