Question about Panasonic CQ-C8303U CD Player
Panasonic CQ-C8303U. Hooked up an amplifier and it works with the radio but when i put in a cd the amp doesn't work. the receiver just plays with normal sound.
  • hollywoodofh
    hollywoodofh Sep 10, 2012
    had the same problem!!!! thanks a million!!!!
    Scholar:
  • 50 Answers
Verify your wire connections are correct. Keep in mind that if your amp is hooked up to the radios power antenna wire this is the problem. When you insert a cd the radio is designed to lower the antenna. If your amp is hooked up to the antenna wire the radio is shutting off the amp when you put in a cd Panasonic does this on most of all their units. You may have to hook your amp up to a separate switch to turn the amp off and on or hook it to your ignitions acc wire, if you hook it up to your ignitions acc the amp will stay on as long as your key is on even if you turn off the radio.
Here's a link to download the manual for your radio just copy and paste it in to your web browser and download the PDF file. You will need the reader to view it. If you don't have the reader you can download it for free at www.adobe.com
http://www2.panasonic.com/consumer-electronics/support/Audio/Mobile-Electronics/CD/model.CQ-C8303U
Posted on Oct 09, 2010
Testimonial: "Thank you very much!!! I am sure that's the problem because i didn't know that these receivers did that when you insert a cd. thanks again."
Hi I have a Panosonic CQ-C1405W cd/mp3 player. I can play radio and hear the sound, great! But when I play a CD theres no sound its playing you can skip the tracks watch it counting the seconds and no...
are you using an amplifier? if so, it sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn your amp on. the power antenna remote wire turns off when you leave tuner mode.
Mar 17, 2011 | Panasonic Car radio CD CQ-C1110GN CD...
Can this be hooked up to cell phone???????
Yes it does as long as your phone supports bluetooth. Here's a link to the manual. You can download it for free. http://service.us.panasonic.com/OPERMANPDF/CQC8403U.PDF
Jan 12, 2011 | Panasonic CQ-C8303U CD Player
I took my panasonic cq-c8303u out of my jeep and put it in my civic hooked all the wires up right but no power to my deck whats could the problem be?
Check the in line cylinder fuse for the radio, cause they blow easy. Also, check the radio fuse under the dash or wherever your fuse box is located. Make sure you solder the connections for a good contact, cause just wrapping electrical tape around the wires will cause you problems down the road when you go over bumps.
Nov 11, 2010 | Panasonic CQ-C8303U CD Player
Panasonic cq-c8303u wiring diagram
Oct 09, 2010 | Panasonic CQ-C8303U CD Player
I HAVE PANASONIC CQ-C700U STEREO PLAYS ON ALL
are you running the rest of your speakers off an amp? if so, it sounds like you have the amp remote wire connected to the power antenna wire. on some radios there is an amp remote wire and a power antenna wire. the power antenna wire loses power when not listening to the tuner (radio). usuall there is a solid blue and a blue with white stripe. the blue with a white stripe should be amp turn on.
Aug 19, 2009 | Panasonic CQ-C700U Car CD/ MP3 Player
Panasonic CQ C1100U amp output?
Yes, the Panasonic CQ-C1100U can be connected to a 2-channel amp. It has a single set of preamp outputs. I'm attaching an image of the connection shown in the Panasonic user manual. The appropriate connection is the one without the dashed line. The dashed line showing a 2nd set of outputs only applies to the 1110, 1120, and 1200 models.
Hope this helps. If it does, please rate as "FixYa". Thanks!
Mar 30, 2009 | Panasonic CQ-C1100U CD Player
I have the panasonic cq-c8303u radio and i would like to hook up the ipod to it. any tips?
You need to get the Direct Cable for iPod® (CA-DC300U) from panasonic. This allows you to plug in and control your ipod from your headunit. There is also the expansion module (CY-EM100U), however I am not sure if this is necessary if you have the Direct Cable. The Direct Cable might plug directly into the back of the headunit without the need for the expansion module. Check with the company before purchasing one or both. If the direct cable requires the expansion module, then get both, however, I think the direct cable works independent from the expansion module. Again, contact the company about this. The expansion module also lets you plug your ipod as well as other devices into your headunit, however I don't think it allows you to control them via the unit. I think if you want to control the ipod from your headunit, you just need the Direct Cable for Ipod®.
Mar 23, 2009 | Panasonic CQ-C8303U CD Player
No sound!!!!!
sounds like you blew an interior speaker.. it would cause the radios internal amp to shut down.
Jan 17, 2008 | Panasonic CQ-C8303U CD Player
Panasonic cq-c8303u Car stereo problem
There is for sure a hook up problem my friend. There should be a memory wire that always has power to it even when the car or the ignition is off. Then there is a switched type wire that only comes on when the cars ignition is on. Check both of these wires in the car. Check the car wiring diagram to confirm this. To confirm the wiring in this vehicle, I Good Luck with this install. And if all else fails, don't take a chance and blow out the unit, take it to a pro to be installed. Good Luck found the right wiring diagram for your car. Confirm this wiring diagram with this one you have. Go here:http://www.the12volt.com/installbay/stereodetail/955.html
Jun 19, 2007 | Panasonic CQ-C8303U CD Player
Panasonic CQ-C8303U CD Player Logo
318 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
