Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
The mixer is leaning too low. how do I put it back to it's normal position?
    Champion:
  • 248 Answers
Should be screw at pivot point between base and head,loosen slightly,hold head in proper position,and retighten
Posted on Oct 09, 2010
I've got a brand new Kenwood mixer and I cannot make the head-release lever work!
A model would be helpful. Put it on the floor, lean your weight down on the head and try to move the lever at the same time.
Dec 29, 2016 | Kenwood Food Mixers
Hinge pin came out from head of mixer and can't put it back..will only go through part way.
did you turn your mixer over and unscrew the set screw on the hinge shaft before trying to put back in? there is a small set screw that holds the hinge pin in place during normal operation. the screw sometimes comes loose and the shaft will vibrate out of it's normal operating position but when you try to push it back in the screw now stops the hinge shaft from going in, You have to turn the mixer upside down and look into the base cavity and you will see the set screw in the middle. Loosen first, return hinge shaft to normal operating position and the re tighten the setscrews, you can be firm with this screw, let us know if this helped
Feb 06, 2013 | KitchenAid Artisan Series Tilt-Head Stand...
Mixer won't turn on
Just recheck that you really have put the brushes back in the right way, use a torch and look in the hole. The brushes can each go in 4 ways, only one of which will work. Look for the blocker and line it up with the cut off corner on the brush. It's normally at the back, one side at the top the other at the bottom. After that you need to be looking at everything you have done for a booboo. I doubt it will be water ingress. Make sure the switch contacts come together when the lever moves to position 1.
Mar 18, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
Overheat after grating cheese, make an awful noise to top it up , have i burned the gears ?
You are putting too much pressure and overloading (motor) the Mixer. Specially if you run it for long time.
Grating cheese is hard on mixers.
Let it rest and turn it back on, ON LOW and little or no load.
Jan 14, 2011 | KitchenAid Artisan Series Tilt-Head Stand...
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
The top part of the mixer has about 1/2 inch play and must be lifted in order to put in lock position
It sounds like the bar that the head hinges on has come out. It is located on the base and should be flush with the side of the mixer on both sides. Just knock it back into position and then turn the mixer over to tighten the screw that holds the hinge pin in place. It might also be that you need to adjust the height of the head by turning the adjustment screw on the hinge. Lift the head and the adjustment screw should be visible.
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The head has a lot of play and the mixer attachment scraps the botton as it turns
It sounds like the pin that holds the head on is not in the correct place. IT should not stick out on either side, if it is, knock it back so it is flush with the sides. Turn the mixer over and tighten the screw that holds the pin in place.
The second problem is that the head is too low. This can happen over time. There is a screw that can be accessed when you lift the head up. It is in the middle of the hinge. Adjusting this will lower and raise the head position when the head is lowered back into place.
Jan 24, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Head tilting problem
OK,Where the mixer pivots there is an ajustment screw ( Flat head). Place a dime at the bottom of the bowl and make your adjustment carefully ( quarter turn at a time).Using the low speed only, adjust until the tip of the flat beater barely touches the dime.When your done, you'll be back in business.
Nov 04, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchen aid mixer
Tilt the head back and remove your cardboard shim. You should see a screw head. Turning this screw adjusts the beater/bowl clearence.
Apr 13, 2017 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
37 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
