Question about Sony KP-46WT510 46" Rear Projection HDTV
Picture seems curved and will not align. - Sony KP-46WT510 46" Rear Projection HDTV
  • Sony Master
  • 1,525 Answers
Hello, convergance ic are your problem, 2 big black chips that sit on a metal frame called a heatsink , they usually located behind the tuner board, also there some resistor in front of the ic and 2 capacitors at either end, all will need to be tested, it's a big job to do yourself and even bigger job if you have no soldering and electonic experience, hope you can get somethink sorted.
regards
shaun
Posted on Oct 11, 2010
What would cause the steering to feel like it's sticking when turning to the right in a curve?
Under-inflated tyres. Pump up your tyres. Another thing is it could be is out of alignment. So, it might need a wheel alignment. While getting a wheel alignment, have the mechanic check the suspension bushes and control arm bushes.
May 15, 2014 | 2005 Suzuki XL7 - With factory rails -...
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 01, 2011 | Philips Televison & Video
Picture seems to be offline( curved down) also everything seems doubled and you can see the red, yellow and blue colors of the lenses on the screen
Tv have a problems known as a convergence problems it is dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the board that call the convergence board it is dead.This convergence board require service must be replacing parts 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the tv picture convergence problems mis alignment.The tvs shops,will cost u like around $300-350 for parts and labors.
May 28, 2011 | Samsung HCM4215W 42" Rear Projection...
Mitsubishi 1080 hd series 65" Curved picture
The problem is the convergence circuit.
Mitsubishi used two different types of convergence IC's in this series. The first is a pair of STK-392-570, the second is a single STK393-110. The only way to fix the problem is to replace the appropriate IC'S. In some cases the problem may appear to be intermitent or loose solder connections. Save yourself the anguish and replace the IC'S.
Getting the PowerSupply/ Convergence board
out to do this is tricky and I recommend a professional to do it. Hidden screws on the front of the heat-sink make it difficult to take out and you can break the board easily trying to force it.
Jun 17, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Picture is curved like an hour glass
that a pincushion problem likely caused by a failed capacitor
Mar 26, 2009 | RCA Televison & Video
Akia tv
Replace Stk392-040 convergence IC's. Use Panasonic brand
for reliabilty.Re-check alignment....
Let me know by your rating....T.
Oct 22, 2007 | Akai PTH5498 54" Rear Projection...
Convergence issue resolved but concave picture remains
Set will need new convergence IC's.Requires chassis pull===technical & mechanical skill mandatory.After repair,re-aligment necessary.
Sep 26, 2007 | Philips 55PW9363 55" Rear Projection...
Picture is weak, has gosth image and is warped.
you are having problem in your IF CIRCUIT it needs to be align take it to a tech to replace the IF ic Or transistor
Mar 26, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
