Question about Belkin (F5D7230-4) Router (587009)
I have two routers and i want to make one a repeater?
    Novelist:
  • 142 Answers
If its a 2 belkin router then u can set one router as an access point
But u have to make sure that both the router should be same ipaddress range
For example: For belkin router the ip address range is 192.168.2.x(x=2to253)
First u have to set the router for internet
For the access point, connect the second router with the computer with wired for the configuring the router.
Open a web browser
On the address bar type 192.168.2.1 You will get belkin setup page,
Posted on Oct 09, 2010
  • 1 more comment
  • Varghese Joseph
    Varghese Joseph Oct 09, 2010
    Configuring your Router as an Access Point
    Our Routers can be configured to act as strictly an Access Point, bypassing all of the routing and firewall functions.
    Setup Steps
    Connect the computer to one of the four LAN ports on your router.
    Open a web browser on the computer.
    In the address bar of the web browser, typehttp://192.168.2.1
    Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  • Varghese Joseph
    Click on "Use as Access Point" on the left-hand side of the opened page.
    Select Enable. This will give you the options to set the IP Address and Subnet mask for the router. These settings should match your existing network settings; by default the IP address will be set to 192.168.2.254 and the Subnet mask will be 255.255.255.0
    Alternatively:
    1. Click on LAN settings in the left hand menu.
    2. When the LAN settings page opens you will make two changes.
    Change the IP Address to something such as 192.168.2.47 or you can use 192.168.2.200. As long as the first three sets of numbers match your existing network, you will be fine.
    3. Secondly you are going to disable or turn off the DHCP server.
    4. Click the Apply Changes button
  • Varghese Joseph
    FOLLOW FROM THE LAST COMMENT
How to connect the ASUS EA-N66R as a range extender.
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers.
Mar 08, 2013 | ASUS EA-N66 Dual-Band Wireless-N900...
Tip
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's...
1. Connect your computer to the repeater router's RJ45 portwith a LAN cable.
4. Go to the page that changes the IP address of the router.Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10 or higher), such as 192.168.1.10 or higher, depending on how many devices are on your network.
7. Disable any firewall settings on the repeater router.This is usually in the "Security" section, depending on the make and model of your router.
on Feb 14, 2011 | Computers & Internet
Configuring a 3COM 3CRWDR200A-75 router as a repeater
Nov 17, 2012 | 3Com OfficeConnect® (3CRWDR200A-75) Router...
I want to use router as wireless extender
SETTING A ROUTER AS A REPEATER 1. Connect your computer to the repeater router's RJ45 port with a LAN cable. 2. Open a browser, then enter the router's URL configuration's IP address, This is usually something similar to 192.168.0.1 3. Enter the configuration user name and password. The router will display the various router settings. 4. Go to the page that changes the IP address of the router. Changed the IP address so that it is not the same as the main router on the network, or any other network devices. If the main router on the network is set to 192.168.1.1 then the repeater router should use a higher number (ie. 10), such as 192.168.1.10 or higher, depending on how many devices are on your network. 5. Disable the repeater router's DHCP server. This setting should be on the same page as the IP address, (this may be different depending on the make of the router). When the main router is operating normally, this server assigns an IP address to every device that is connected to your network. Because this router is used as a repeater, the main router on your network will still issue the IP addresses. 6. Also turn off the DNS server, if it is activated. This function will be taken over by the main router. 7. Disable any firewall settings on the repeater router. This is usually in the "Security" section, depending on the make and model of your router. 8. Remove all in the "Port Forwarding" section. Some routers may refer to this as "Applications and Gaming," and it allows less-restricted access to the internet. 9. Set the operating mode switch to "Gateway" or "Switch" if applicable. Also, if the repeater router is a wireless router then disable the wireless access or set it to access point only. 10. Save the settings for each page, and reboot the router. When the router boots up, the changes will allow it to act as a simple repeater. 11. Now, place the repeater router in a new location and connect both routers with a Ethernet cable in each of the router's RJ45 LAN ports, and power it up both routers. http://www.fixya.com/support/r8279884-setting_router_as_repeater
Nov 05, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
How to make a net gear dgb111g into a dummy or bridge unit for wifi, using with bt home hub?? thank you
Aug 15, 2012 | NetGear DGB111G Wireless Router
Can i use my old usr 5461 wireless max g as a repeater?
SETTING A ROUTER AS A REPEATER1. Connect your computer to the repeater router's RJ45 portwith a LAN cable. 2. Open a browser, then enter the router's URLconfiguration's IP address, This is usually something similar to 192.168.0.13. Enter the configuration user name and password. Therouter will display the various router settings.4. Go to the page that changes the IP address of the router.Changed the IP address so that it is not the same as the main router on thenetwork, or any other network devices. If the main router on the network is setto 192.168.1.1 then the repeater router should use a higher number (ie. 10),such as 192.168.1.10 or higher, depending on how many devices are on yournetwork.5. Disable the repeater router's DHCP server. This settingshould be on the same page as the IP address, (this may be different dependingon the make of the router). When the main router is operating normally, thisserver assigns an IP address to every device that is connected to your network.Because this router is used as a repeater, the main router on your network willstill issue the IP addresses.6. Also turn off the DNS server, if it is activated. Thisfunction will be taken over by the main router.7. Disable any firewall settings on the repeater router.This is usually in the "Security" section, depending on the make and model ofyour router.8. Remove all in the "Port Forwarding" section. Some routersmay refer to this as "Applications and Gaming," and it allows less-restrictedaccess to the internet.9. Set the operating mode switch to "Gateway" or "Switch" ifapplicable. Also, if the repeater router is a wireless router then disable thewireless access or set it to access point only.10. Save the settings for each page, and reboot the router.When the router boots up, the changes will allow it to act as a simplerepeater. 11. Now, place the repeater router in a newlocation and connect both routers with a Ethernet cable in each
Jul 18, 2012 | U.S. Robotics USRobotics USR5461 Wireless...
Repeater isn't getting signal
Plug the first router into a LAN port on the router you are using as a repeater. Don't plug into the WAN port. That should make it work
Jun 17, 2012 | Linksys Wireless-G WRT54G Router
I installed this router on repeater mode, connection to existing router and signal is perfect but have no access to internet... in the access router the internet access is perfect. please let me know how I...
this is from Encore-usa.com
How to use ENHWI-N3 / ENHWI-N34D / ENHWI-2AN3 / ENHWI-2AN34D / ENHWI-3GN3 as a Repeater?
  • For Advance Users, you can download this document.
  • The reason why people use a Encore wireless repeater is because some wireless remote client computers are out of range from the main network's access point (wireless router), or the wireless client is in the dead spot or the device you want to share to the network have no wireless interface card.
    The function of a wireless repeater is basically to extend the wireless signal coverage. Wireless repeater does not authenticate, screen, secure, connect to the internet, give IP address to clients, broadcast names, etc., these are the wireless router's job. Repeater only repeats what the main wireless router does to the wireless clients.
    Checklist:
    • You should know the wireless security type of the existing wireless AP/router, is it a WPA, WPA2 or a WEP?
    • The wireless security key, or password or passphrase of the existing wireless router
    • Your existing wireless router's SSID
    • We recommend that the existing network you are about to add the Repeater on have a DHCP server running and able to lease IP address to all network clients. If you are not sure about this, please ask your ISP or the person who installed your network.
    Hardware Checklist:
    • Computer with wireless device turned off. This is only to set up the repeater, once finished the wireless can be turned on again.
    • The computer must have an available RJ-45 network interface card and web browser installed.
    • A working wireless router or Access Point with one available RJ45 port
    • RJ-45 UTP/TP Ethernet LAN Cable
    • The Encore Router is set to factory default. If your Encore Router is brand new and just pulled out of the box, no need to reset. If changes were made to any settings to the Encore Router before, make sure you "hardware reset" the Encore Router to the factory default settings. Check the User's Manual on how to "hardware reset" the router.
    PROCEDURES:
    1. Hooking up hardware connections:
    1. Both PC or Laptop and the Encore Router should be turned-on.
    2. Disable the wireless client from your PC or laptop computer (if not done so)
    3. Connect the Ethernet cable to the PC or laptop computer and the Encore Router. (This can be done while PC computer and router are turned on.)
    2. Switching mode from AP Mode to Repeater Mode
    1. Using your computer's web browser such as Internet Explorer or Safari Firefox, enter 192.168.0.1 to the address field then hit enter. You should see the Encore Router's User Interface screen still in the AP Router Mode
    2. On the upper right corner of the user interface menu, click on the drop down menu and select "Repeater Mode". Click the "OK" button to the warning box. Wait around 35 seconds until your screen comes back to Encore user interface screen, this time the screen is now in the Repeater Mode. If for some reason you were asked by the repeater to enter the username and password, enter the default username and password (admin/admin) and your Encore Router is now in Repeater Mode.
    NOTE:
    As of this moment your repeater is not connected to any router or network. It has to be configured further to be able to be connected to your current network and access point router.
    3. Connecting your Repeater to your existing network access point or router:
    1. As soon as the Encore Router switched to the Repeater Mode, you should be able to see the same Utility Screen with fewer selections on the left pane.
    2. From the Main Menu screen click on "Wireless" located on the left pane.
    3. Click on "Site Survey" button, a new Window dialogue box will pop up showing a list of Access Points reachable by your Repeater
    4. Check your existing network's access point SSID then click on the radio button that corresponds to your access point router then click "Connect" button.(If you can't find your existing AP router, click on "Refresh" repeatedly until your access point show up, or your location is too far from your existing AP router).
    5. Click on the "Encryption" drop down menu, select your existing access point wireless security, enter your existing router's wireless security key or passphrase then click "Apply". If you get a FAILED message, repeat this procedure again, a wireless hiccup might be interfering, otherwise you now have a working Repeater.
    6. Check your repeater connection by going to your internet browser and open a web page of your choice. If successful your new wireless repeater is working.
    7. Disconnect the Ethernet cable and setup your computer back to its original wireless settings. At this stage, the Repeater is now invisible to any wireless client computers. When connecting a new wireless client within the repeater's wireless range the process is the same as there is no Repeater device at all, the SSID of the wireless router will just be extended in range around where the Repeater is physically located.
    4. Connect your remote wireless client to your wireless router
    1. Using your wireless client utility program, look for your existing router's SSID and connects to it, if this is a new client you will be prompted with the wireless security key. Your repeater is invisible to all wireless clients. All it does is to repeat the wireless router signal as it is to extend its range. Once you have converted the Encore Router to Repeater and successfully connected to your existing router there will be no more configuration needed to the repeater. If you happen to see two identical SSID's of your existing router, this means your wireless client is within the same range of your existing router and the new wireless repeater, then your client don't need the repeater's service.
    NOTE:
    If you are using Windows 7 and your existing access point security wireless is set to WPA2 (AES), make sure your Windows 7 wireless security type properties is set to WPA2-Personal. To check go to Windows 7 Wireless Network Connection, look for your REPEATER router, right-click on it then click Properties, check the settings in the "Security" tab.>
    NOTE:
    When checking the wireless site survey, you may see two routers with the same SSID (names), these are your Access Point and the REPEATER tied together. This also means you are within the reachable range of both Access point and REPEATER.
    5. To check the Repeaters user interface
    At this moment, the Repeater is invisible to any client. The client's IP address is drawn from the DHCP server most likely to be also your wireless router. Therefore the IP address of the repeater is also invisible to the clients. Follow steps below:
    1. Disable wireless connection or turn off wireless in the client PC computer
    2. Connect Ethernet network cable to the RJ-45 port of the client PC computer
    3. Connect the other end of the Ethernet cable to one of the LAN ports of the repeater.
    4. From your computer, set the network card IP address to Static IP Address entering 192.168.0.102, Subnet Mask 255.255.255.0, leave the rest as blank.
    5. Open IE or Internet explorer or any other web browser software and run 192.168.0.1, you should be able to see the Encore Repeater user interface screen. (Changing any settings in the repeater may affect its performance)
    That should help :)
    Christopher
    May 15, 2012 | Encore Enhwi-2an3 Wireless-n Router
    I have an e3000 and I'm trying to hook up a Lutron RadioRA2 main repeater, but the router will not find it. Its hooked up directly to the router, but the router refuses to aknowlege the repeater's...
    Is it a wireless or wired repeater? Connect a different device to the repeater, then connect the repeater to the router. If your device receives traffic, the repeater is working fine.
    Aug 03, 2011 | Computers & Internet
    DWL-G710 - Not able to logon with standard IP-adress 192.168.0.30
    Must have same IP-adress on Router and Repeater 192.168.0.x. Then have cable from router to PC and from router to repeater. Then logon to repeater and the Dlink-repeater SW have a command where you can see available networks. See to that you choose the right one and that channel, name and password is the same as the router. The repeater will not be visible when you search for available networks because it has the same name as the router. I also had to restart the router and the repeater before it worked.
    The repeater gives us excellent connection where we otherwise has no connection, so I can recommend it.
    Aug 27, 2008 | D-Link AirPlus G DWL-G710 Wireless Range...
    Belkin (F5D7230-4) Router (587009) Logo
    100 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
