Question about Lasonic Ghetto Blaster i931 Boombox
Hi, I bought my Lasonic Boombox a while ago. I turned it on and that only lasted for a little bit, then it made a buzzing noise, switched off and a bit of smoke came out of it. now it won't turn on.I think the fuse might be blown but I don't know what to do with it. Was is also something to do with the adaptor? cause I bought it in the US and I live in the UK so I don't know.
    Scholar:
  • 50 Answers
Sounds like its blown. If you bought it in the U.S. and tried to use it in the U.K. then you may have inadvertently fried the system. The U.S. uses 115 Volts AC and the U.K. user 240 Volts AC. If you plugged it in to the U.K. power with out a voltage reducer the radio received 240 volts of raw power instead of its required 115 volts it was built to handle.
Is possible a locale repair shop may be able to save it by replacing it's internal volta-pack, but it won't be cheap.
Hate to hear that happened to you, this is a great sounding radio! Don't feel bad this happens all the time as not many people know about the voltage difference between countries.
Posted on Oct 09, 2010
3 Suggested Answers
SOURCE: I have just turned on my brand new lasonic i+931
same happened to me. it might be the battery circuit or the batteries many times fall out of place so they dnt work. call lasonic or send it back for a new one for free like mine
Posted on Sep 16, 2009
SOURCE: brand new lasonic i931 boombox wont turn on!!!
okay, i had a similar problem, and the problem turned out to be a bad connection. If you open up the battery box, in the bottom top left corner there is a positive connection wire that looks kind of like a "U".
this connection doesn't come in contact with the batteries, so you need to extend it by wrapping a small piece of wire or something to make it stick out more.
what we actually did was put a piece of 1/4 in. by 1 in. piece of copper flashing in the plastic slot and across the U shaped connector to increase conductivity and it works fine.
i hope this was helpful!
Posted on Jul 01, 2009
I plug in my lasonic blaster g31 when I put up the volume it turn off what is it
From the description the audio outputs are cutting out due to bad connections, or semiconductor failure. Check to make sure there are no shorts in the speaker wiring, if no change! take it back to the place of purchase for exchange or repair.
Jul 07, 2012 | Lasonic Ghetto Blaster i931 Boombox
Sound comes out of left channel only in my Lasonic L-30K boombox
Check the speaker wire for proper contact, swap speakers around to rule out the speaker, if okay suspect the left audio output chip.
Jun 15, 2012 | Lasonic L-30K Cassette Boombox
Compatbility of product in Australia?
if you connect the boombox direct to the your mains of 240v, the appliances will blow up , to avoid that you need a step down transformer to connect the boombox before it goes into the mains source. you do not need any adapter, only if you want to use battery that is when you to swicth to 12v
May 25, 2010 | Lasonic TRC-931 Cassette Boombox
My Emerson 5812 Boombox will not turn on all of a sudden. I just bought it a couple months ago and it will not power on.
If its still under guarantee then take it back to the shop if you have the receipt. If not then it could be something as simple as a little glass fuse inside the boombox.
May 21, 2010 | Emerson (PD5812) Radio/CD Boombox
My boombox wont work when I put batteries in. It works fine when its plugged in but when I tried to play it using the batteries nothing happen. Please help. Thanks
A Lasonic 931 ? It has probably been taken apart by someone before you and may have unplugged the power feed from the battery compartment. Remove the rear panel then check the two wires that come from the battery box are connected to the circuit board.If not, then check to see where they go on the board, it`s not hard to do.Look for the little tabs they slide onto..
Jul 28, 2009 | Lasonic TRC-931 Cassette Boombox
My lasonic ghetto blaster won't come on
Make sure the switch on the back is on the correct power setting. The cord is AC and the input is DC. On batteries, switch it to DC and use tinfoil or copper wire on the left top U shaped + battery receptor. on mine, it didnt connect with batteries without metal there
Jul 20, 2009 | Lasonic Ghetto Blaster i931 Boombox
I have just turned on my brand new lasonic i+931 boombox. I plugged it in and it automatically turned on, made a loud humming noise and then within seconds turned itself off. I was thinking maybe a fuse...
Jul 16, 2009 | Lasonic Ghetto Blaster i931 Boombox
Brand new lasonic i931 boombox wont turn on!!!
Jun 10, 2009 | Lasonic Ghetto Blaster i931 Boombox
Lasonic Ghetto Blaster i931 Boombox Logo
450 people viewed this question
Top Lasonic Audio Players & Recorders Experts
stynger007
Level 1 Expert
Joseph Hoffmann
Are you a Lasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
