Question about Kenmore Washing Machines
It wont empty. How do you get the top open? - Kenmore Washing Machines
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 44 Answers
:-> If it's the direct drive model, to get to the internals, remove 3 screws from the back of the control console. Remove console and you will see two brass colored clips. Stick a screwdriver into the front side so it engages the front lip of clip and push forward. This should release clip. Pull whole washer frame forward, toward you, and lift off. Be sure to undo the lid switch. You should now have access to the internals. Hope this helps,
Rich
Western Appliace Repair
Appliance Repair Meridian
Posted on Oct 09, 2010
Hi, I have a zanussi wwashing machine model= ghg1200apm. The door won't open. I plugged out the machine after the wash and when i plugged it in again, the door wont open. Can you help me?
Hi.
The door does not open because there is water inside the machine. To open the door you need to empty the tub first.
To empty the tub disconnect power, open the door at the bottom of the machine's front side, unscrew the drain filter cap and collect water using a container.
Usually that is enough to allow the door to open. If the door does not get released, try running a cycle again.
If still no luck, then the door is locked either because the pressure switch detecting water level is clogged with soap or because the power surge has damaged some component. In that case the machine must be partially disassembled to reach the back of the door opening mechanism. The door latch is reachable either from drain filter access or from top of the appliance.
Emptying water through the drain filter and/or restarting a cycle usually is enough to release the door lock.
Regards.
Ginko
Aug 19, 2011 | Zanussi ZWF12070 Front Load Washer
Leaving home
it wont do any harm to unplug it if left upright,leave the doors open to stop things smelling/growing inside.wash out with bicarb when empty.
Jun 10, 2010 | Kenmore 64802 Top Freezer Refrigerator
Washer will not empty
if it spins and agitates, but wont empty, ur timer is bad,(dialcontrol)
May 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The 4 disc magazine is jammed and wont eject
was the unit recently shipped to you ? if so open top cover , if the empty magazine was left inside the cd trays can slide out into the playing area and jam the unit ,check it like that anyhow . sometimes u can see a small metal tab to release the magazine maNUALLY
Jan 13, 2010 | Car Audio & Video
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
The washer fills and empties but no spin or agitate
I assume by empties you mean it pumps the water out.
That being the case you will need a way to make sure the timer is sending power to the motor. If it is emptying by itself then you have a siphon problem and need to raise the drain hose exit above the top of the washer or install a siphon break.
Eric
Jun 08, 2009 | Kenmore 23012 Top Load Washer
Matag top load washer wont spin or empty
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
Mar 14, 2009 | Maytag Washing Machines
Cannot remove empty cartridge
moz-screenshot.jpgmoz-screenshot-1.jpgThis may sound crazy but I had a friend call me and said he couldn't get his empty ink cartridge out of his ip3500. Same problem I think.
First you probably did this but wont hurt to ask. Did you lift the top deck cover up, then where the word CANON on the front panel is, did you open that by pulling it toward you. All this has to be done with the power on so the Ink holder can cycle to the center, so you can easily remove an ink cartridge. Hope this helps. Bud
Dec 02, 2008 | Canon PIXMA iP5300 InkJet Photo Printer
Washer wont empty and spin
BAD LIDSWITCH OR THE SCREWS ON THE LEFT SIDE HINGE ARE LOOSE CAUSING THE LID TO BOW UP APPLY PRESSURE ON THE LID TO GET IT TO START SPINNING IF IT DOES TIGHTEN THE SCREWS ON THE HINGE IF IT DOESN'T THE LIDSWITCH NEEDS TO BE REPLACED
May 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
How to empty a Tech Solutions TS8000 shredder
Pull the top of the basket toward you and the top of it should swing out. Then you can lift the basket up and out once the top of the basket is partly open. Hope this helps. Have a good day. Mac =)
Mar 09, 2007 | Tech Solution TS-8000 Cross-Cut Shredder
Washing Machines Logo
16 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
