My hp pavilion dv2000 screen will not come on. all led lights work but screen will only stay blank. What do I do?
  • 5,660 Answers
Suggest you check first for damage to the Display Cable, before going further.
This is HP Support, the support page for the HP Pavilion dv2000 series laptops, and the Manuals download page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1817074&
Left-click on the first file name -
HP Pavilion dv2000 Notebook PC Maintenance and Service Guide.
After you click on the above PDF file name, you may not see anything happening for up to 30 seconds. The file is downloading in the background.
(For a test I downloaded it just now. Took almost 40 seconds with a medium speed DSL connection)
Don't know if you are familiar with PDF files. If so disregard the following.
Suggest you view the file at the 100% view. You can enlarge the view later anytime you wish.
At the top header is a Zoom In icon, and a Zoom Out icon.
Zoom In +
Zoom Out -
To the left is the Bookmarks menu.
By default it opens to the main heading - Maintenance and Service Guide.
Left-click on the + sign to the left of Maintenance and Service Guide.
Scroll down the sub-headings, and left-click on the + sign to the left of -
Removal and Replacement Procedures.
Now scroll down, and left-click on -
5.12 Display Assembly
You're on Page 145.
Use the blue Down Arrow in the top heading, and scroll down to Page 146.
I want you to view the Display Cable, item number 1.
Enlarge the illustration.
Scroll the page up a little for better clarity of the Display Cable.
The number 1 is pointing to the male connector on the end of the Display Cable, that plugs into the motherboard.
It is shown unplugged from the female (White) connector on the motherboard.
The Display Cable connects to the motherboard, and then routes to the LCD Display screen via right by one of the hinges. (Left Hinge)
Opening, and closing the laptop can cause the Display Cable to become partially disconnected from the motherboard.
The area the cable routes through, may cause damage to the cable over time. Generally the damage is visual enough to see.
Sometimes the cable is stretched, and the damage is not readily apparent.
The tiny wires inside that cable's sheath can be stretched far enough to break, and the outside sheath will show no apparent damage.
Fun stuff, huh?
Most of the time however, the male connection on the motherboard, has become partially disconnected.
To access the Display Cable:
1) Remove all power to the laptop.
Remove the AC adapter (Charger), and the Battery.
2) Lay the laptop on a table, push the LCD display assembly until it is laying flat on the table.
3) Remove the Keyboard.
(Page 137)
4) Remove the Switch Cover.
(Page 141)
I await your reply (Via a Comment) after you have opened the laptop, and diagnosed whether you have a Display Cable partially disconnected, or damaged, or no apparent damage is visible.
[ You may have to remove the Display Bezel from the Display Assembly, and look at the connection of the Display Cable going to the Inverter.
Pages 148-149, and 152 ]
Posted on Oct 09, 2010
HP Pavilion Entertainment PC Laptop DV2000
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
Oct 06, 2012 | HP Pavilion Computers & Internet
My HP Pavilion dv2000 turns on, but screen is black
If the laptop appears to boot up but the LCD screen is black, then the problem is a back-light fault caused by either a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to determine the fault and fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 14, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 15, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a HP pavilion Entertainment laptop and recently the screen went blank while the power was still on. I restarted and the screen continued to stay blank. I then turned the laptop off and unplugged it...
The connecting data bus between ur laptop monitor and ur motherboard has either been at fault or else there has been some problem with the wire connection between the two......i.e it has been loosen up....
Get ur laptop checked from the hp representative and if possible get ur laptop insured under different laptop policy schemes.....
With Regards
Abhineet Raj
Jul 29, 2009 | HP Pavilion dv2000 Series Laptop Full...
Screen is Black hard drive works screen lights up then goes blank
The Problem is that, your system is in STANDBY mode..bring it back..
This should solve your problem..
Jun 09, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
My hp pavilion dv2000 screen will not ocme on or reboot. The power led lights are all on. I have taken out the battery and lights stay on. I reinstalled the memory modduls and still nothing
hi im josh in cebu phils.may i help you? friend if the pc will not boot. the problems that may occur is in hardware connections and settings. First thing to do try to go to setup utility try to see if the hardisk and other devices are detected there.if not so you problem is the connection. try to change the IDE or the SATA cables. im sure these will solve your prblem. thats all good luck hope i helped you.
Feb 28, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
HP PAVILION DV2000 boot problem
Your could not be booting for several reasons anything from faulty RAM to software issues. Since you cannot boot to any type of working screen you will need to use the operating disc with XP or Vista on it. Put it in the CD-ROM and reboot. Let it run for a while and it will eventually ask you to install or repair. I would try repair first as if you install then you will lose all of your data, docs, favorites, pic, etc. if you have any questions let me know.
Feb 19, 2009 | HP Pavilion dv6000z Notebook
HP DV2000 screen going blank when try to restart my laptop
Check the swapping monitor function screen FN + F4 on Compaq.
It allows to change from internal to external or Both monitors.OR
Start in Safe mode with VGA basic settings and configure your Display settings.
Dec 14, 2008 | HP Pavilion dv6000z Notebook
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
