Question about CyberLink PowerDVD Deluxe
I'm getting error message: "this appilcation cannot play this DVD because of the current output display configuration. Try restarting the player". this does not work, i recently recently replaced the hard drive due failure on its part, but had all original software that can with the purchase of this dell laptop.i was able to load all apps with no problem this one from the DVD device. Can you help, the lapto is a Inspiron 1545
2 Suggested Answers
  • 202 Answers
SOURCE: I cannot play dvd's with power dvd dx-display output error
check if you display properties is set to 32bit and the pixel is 1024 X 768, this can be done by right clicking on the destop and clicking on properties. good luck
Posted on Sep 11, 2009
How do I fix a No Disc error given by my VIZIO Blu-Ray player?
Have you checked to see if the software is current on your player? If so do other discs function properly? Go to menu, chek to see current software, if current you can contact mfg. To see if it in fact current. Sometimes they have to be uptaded via cd. Retun disc to store get new one, try it to make sure. I have two 3d bl ray players and neither will play them. Software is not updated for these discs.
Feb 27, 2015 | Vizio VBR220 Blu-Ray Player
Hi, whenever I put a dvd on my Dell Inspiron 1545 laptop there's a msg comin sayin : ''This application cannot play the dvd because of the current output display configuration. Try restarting the player.''...
could be faulty graphics or incorrectly configured screen resolution goto manufacturers site to find correct configuration.Also go into bios and see your system specs ,you might be able to see any technical fault here (F2 whilst booting)
Oct 23, 2010 | Computers & Internet
Output display configuration
Try changing the display resolution of your system. To do this, follow the instructions below: Right click on the Desktop - Properties - Settings - on the screen resolution, drag the slider to the left or to the right to adjust, and click apply, and check the player before you click Ok. Repeat this steps until it's is playable. I can't help you perfectly since you didn't mention the operating system you are using. Good luck. Thanks for using FixYa.
Jun 02, 2010 | CyberLink Power DVD DX 8.0 for PC
Dell D830 laptop - try to open DVD player get error "This application cannot play this DVD because of the configuration of the output display. Please restart the player." Installed Cyberlink Power DVD DX...
Hi, you may have dual monitors activated which is a possible reason for the dvd not being playable. try holding down the fn key in the bottom corner of your keyboard and then tapping the f7 key. if your screen goes black, tap it again. you are cycling the display options. play around with tapping that key and starting the program. you may also right click the desktop>personalize>display settings, and make sure that your display is 32 bit and utilizing the maximum number of pixels it can. if you are using windows vista basic or business, you may need to download DVD codecs from microsoft or and affiliate's website.
Jan 27, 2010 | Dell Latitude D830 Intel Core 2 Duo T7250...
Try going to the Dell webpage to see if there are any updates for the software. It should be found under the support for my system link. Reason I say Dell rather than Cyberlink website is that Dell uses a "special" version bundled in their systems. There is probably an update required or it is missing the proper codecs to run. Hope this helps.
Sep 11, 2009 | CyberLink Power DVD DX 8.0 for PC
When i load the dvd player on my laptop with a movie it will not play or autoplay the message: THIS APPLICATION WIIL NOT PLAY THIS DVD BECAUSE OF THE CONFIGURATION OF THE OUTPUT DISPLAY PLEASE RESTART YOUR...
The output display is your monitor. You may need to change the resolution of your minitor. Change it back to default settings. Also try a new program to play your dvd such as VLC media player or Gom Player. Bother are available off Hope this helps. Can u rate me if it does.
Jun 23, 2009 | Dell Vostro 1500 Notebook
DVD Rejion problem
1. Turn on the unit
2. Open the loading tray
3. Press the "Setup" button on the remote
4. Navigate to the "Preferences" page using the right arrow key
5. Enter 138931
6. You will now see the current region code displayed
7. Use the Up/Down arrow keys to select the region required or "0" for all regions
8. Press the "Play" button on the remote
Jul 07, 2008 | Yamaha DVR-S120 DVD Player
PC flat screen monitor to DVD player hook-up
It appears that the monitor was designed to work with the display circuits and software driver on a Personal Computer. There is no circuitry in the display to handle the out put of DVD player. A smart TV has the circuitry. the display does not.
Nov 26, 2017 | Princeton Digital VL1916 19" LCD Monitor
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Computers & Internet Logo
44 people viewed this question
Top CyberLink Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
Are you a CyberLink Computer and Internet Expert? Answer questions, earn points and help others
