Question about Neovo F-417 17" LCD Monitor
I boot and my screen is hit and miss, so screens i see most i do not. worked intermitent, so times it would work, then it just stopped all together. i replaced the monitor and it works just fine. i then took my f417 to another computer and it is doing the same thing, i see some screeen but by the time it boots to the home page it goes black again. how can i determine if this is a power cord replacement issue of it the monitor is just done.
  • 11,361 Answers
Which version of the monitor do you have? Built-in power supply or external AC adapter?
http://www.agneovo.com/us/content/f-417.asp
or AC adapter: http://www.usadapter.com/LCD-AC-Adapters/AG-Neovo-F-417-LCD-Adapter-12V-4A.html
If it uses externa; AC adapter, then you need to attach a car bulb such as 1157 using high filament to the adapter output and see if it still putting out 12vdc with load.
If it uses built-in power then you need to check the power supply section first.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 09, 2010
Hp notebook won’t boot . Now when it boots it say no operation Help
NO PC stated just HP.
NO OS stated, but
All PC boot in SERIAL order. until if windows, windows loads.
ok?
so how far it gets into that process, is key the cause when it fails.
First I must assume the screen works, is this desktop or laptop(notebook).
if the PC is not older that 10 years old the HP RTC coin cell my be good. so you power on, and the BIOS message happens
and you hit the key "hit ESC to enter HP setup" as seen every day you owned this PC. you hit ESC (or what it says to do , F10,or>?)
and you get the bios screens.
Test 1 does it show the correct time and date. if not the coin cell is dead. RTC means real time clock, . and has battery.
test 2, do you get to Windows login screen, next?
or are you stopped by the painful BIOS PASSWORD screen.
Ill stop here. as I cant see your screen , its progress nor all errors on the screen.
Apr 10, 2018 | HP Computers & Internet
How to fix the LG LCD LM270WQ1 (SD) (B3)?
Rarely, a Mac may encounter some peculiar issue during system boot that can cause quite a bit of panic, like booting to a completely black screen. It would be easy to interpret that as a potential hardware problem, and in some particularly rare situations that may be the case, but it's more often a software issue that can be resolved with some simple troubleshooting steps.
Case in point; one of our readers experience with his MacBook Pro, which out of the blue rebooted to a completely dark screen. Though it's rare, we figured this would be a good opportunity to share three potential solutions to this problem, and similar issues, should you encounter a dark screen on system start.
First, Reset the System Management Controller to Fix the Black Display on Boot
The first thing you'll want to do resolve nearly every power related issue on a Mac is to reset the SMC, or System Management Controller. This will dump and reset settings for anything power management related, and is long known to resolve problems with things like fans, heat, sleeping problems, and of course, display issues.
On any modern MacBook Pro or MacBook Air with a built-in battery, which is just a bout all of them nowadays, this is how you do that:
  1. Shut down the Mac and connect it to your MagSafe adapter and a wall outlet as usual
  2. Hold down the Shift+Control+Option+Power button at the same time for a few seconds
  3. Release all keys at the same time, then boot the Mac as usual
Older Macs can find directions here for the same process on their machines, it's slightly different if you can take out the battery.
When the Mac boots, hopefully the black screen has gone away and you're back to normal, but if it doesn't... reader Nathan D. wrote in with the next tip.
Second, Try a Keypress Sequence to Ditch the Black Screen
Regular readers may recall that we covered some OS X keyboard shortcuts for the Shutdown, Sleep, and Restart controls of just about every Mac, and this little key press sequence takes advantage of those. Oddly enough, it seems to work to resolve some of the mystery Mac booting into black screen issues. Here's the precise sequence to follow:
  1. Press the Power / OFF button once - this will bring up the dialog box which you can't see
  2. Press the "S" button - this is the shortcut to sleep the Mac
  3. Hold down the Power button until a hard shut down is forced
  4. Wait about 15 seconds, then hit the Power button again to turn it back on
This key press solution was discovered by reader Nathan D., who found it tucked away on MacRumors Forums, and it has worked for several other commenters there as well. Some other users on the MR forums suggest that resetting PRAM helped them too, but most power issues are resolved by the SMC reset.
Try a PRAM Reset to Resolve the Black Boot Display
If the above two tricks failed, a PRAM reset can often do the trick, as many of the commenters on this article can attest to. As a potential solution to the black screen on boot, this is done upon restarting the Mac similar to an SMC reset:
  1. Reboot the Mac and as soon as you hear the boot chime, hold down the Command+Option+P+R keys together
  2. When you hear the boot sound again, the PRAM has been reset so let the Mac boot again as usual
At this point your Mac should boot again as usual and no longer have the black display, loading Mac OS or Mac OS X as usual.
Finally; Enter Password, Hit Return
Some users in our comments report an interesting alternative finding if they hit the black screen on boot; if they enter their regular login password and hit the Enter/Return key, the Mac boots up as usual and they're good to go. Try this out, it might work for you:
  1. When the Mac boots into the black screen, enter the password you'd use to login to the Mac as usual
  2. Hit the Return key
If this works, you'll know rather quickly because the black screen will give way to the regular Mac OS desktop.
Did one of these solutions work to get past the black screen on Mac boot for you? If you happen to run into this unusual issue with your Mac, let us know how you resolved it, and if the above tips worked for your MacBook, MacBook Pro, MacBook Air, and whichever Pro or Air model it may be. If you still need any assistance call me on +1(518)348-9393 i will be glad to assist you
Aug 14, 2017 | Apple Computers & Internet
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Cant access bios to change boot order to reuinstall windows 7
Boot the computer and watch the screen. It will tell you what key to hit to get into the Bios or System Setup. You have to hit the key when you see the message or it won't work and you will have to restart.
It also shows you which key to hit to change the Boot Sequence or Boot Order. But you have to hit the key when the message appears on the screen or it won't work and you'll have to reboot. This is a temporary 1 time change for the current boot cycle. When you change it in the Bios or System Setup it's a permanent change.
May 25, 2012 | Computers & Internet
Cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
May 08, 2009 | Acer Aspire 5100 Notebook
DESKTOP COMPAQ WONT BOOT UP
try hitting the F12 key when u turn on com. dont stop till it come up a screen or turn back off and try hitting all the keys the same like F8 works for me...
riversidehood@yahoo.com
May 06, 2009 | Computers & Internet
Stop: c000135 error
If you do not have any important data on teh computer and you computer was purchased after september 2008 you can try the factory restore. NOTE : DOING A REINSTALLATION OR FACTORY RESTORE WILL WIPE OUT ALL DATA AND APPLICATIONS YOU HAVE PUT ON THE SYSTEM.
To do a factory restore follow these steps.
Please power on the system and as soon as you see the Dell logo hold down the CTRL button and hit the F11 button 3 - 4 times. This will bring up the restore options. Hit Restore and follow the positive prompts on the screen.
If it does not work try a reinstalling from the CD.
Follow these steps to do a reinstallation from the CDs.
1. Load the XP CD in the top CD drive and restart.
2. Press F12 as soon as you see Dell Logo.
3. You will get the Boot Device Menu. Select IDE CD-ROM hit enter.
4. When you get the message “Press any key to boot from CD” hit enter immediately.
5. Windows XP Setup screen will appear loading files.
6. When the screen “Welcome to windows” appears.
7. Press ENTER .
8. Press F8 for license screen agreement.
9. Press ESC to install a fresh copy of windows.
10.Select the partition which says C:.
11.Press D to delete, press ENTER and L to confirm.
12.Highlight the Unpartitioned space hit ENTER.
13.Select “Format the Partition using NTFS file system” hit enter.
14. The setup will format the drive and then copy files and restart.
15. After the installation is complete you need to install the drivers and applcations back on the system.
Sep 14, 2008 | Dell Inspiron 5100 Notebook
On bootup checks, stops at 02FC Main and second fans failed. Black screen with bootup messages. ?Has the MA7 even got two fans? How to correct.
Sounds like you may have a virus or trojan of some sort. They are hard to get rid of but try downloading avg 8.0 it's free and picks up most trojans and viruses. If you get a black screen with boot message just hit control alt delete together and your pc should bypass this problem and allow you in. If avg doesn't pick up trojan or virus it maybe a software failure but it will usually tell you whats missing and if pc was working fine and just started this it is most likely a virus or trojan
Jul 26, 2008 | Gateway Computers & Internet
Acer Aspire T180-UB72 does not boot
I have the same model and had the same problem. Fortunately there is a simple fix - unplug all your USB devices (mouses, printers etc). It should now boot!
Assuming that fixed it, it was trying to boot from a USB drive for some unknown reason. I think it was due to the latest windows XP update. Wierd. Hit F12 next time you reboot and make sure it is booting from hard disk first.
Jan 09, 2008 | Acer Aspire™ T180 PC Desktop
Neovo F-417 17" LCD Monitor Logo
133 people viewed this question
Top Neovo Computers & Internet Experts
Questman
Questman
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
