Question about Philips GoGear HDD1830 MP3 Player
Philips GoGear will not repair
When I try to listen to music on my Philips Go Gear HDD1630/17, nothing shows up, but there is 5.7 gb of space used up, and it wont let me repair it either... what do i do?
when i connect it to the computer, it shows up, and i try to repair it, it partially goes through, then says "player either disconnected from computer, or another program trying to access gogear", but it is not disconnected, and no other programs are running...
i know product says hdd1830, but my product did not show up, and my product is HDD1630/17
  • 8,596 Answers
Uninstall your Windows Media Player 11, and rollback to Windows Media Player 10 first. instructions at microsoft.com or www.usasupport.philips.com.
Then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mps Doctor
Posted on May 30, 2008
Hello, I've bought a Philips GoGear VIBE mp3-player (4 GB), but one annoying problem has occurred: When I am uploading some music files to my mp3-player and, when it's charged, I disconnect it, there is...
Ok, I suggest you do a soft reset of your player. You will find the reset button next to the 'power on' button on the side of the player. Please hold the Reset button using a pen tip or other sharp object for 10 seconds.
If that doesn't work, I'd suggest that you format your player or repair it using Philips songbird or device manager. If your model number starts with SA1..... your player supports device manager. If it starts with SA2.... then it uses Philips Songbird. You can install them from the CD that came with your player or download it from Philips support site. www.philips.com/support
* Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair using Songbird:
Launch Songbird and then connect your player to your computer. Select "Repair" under the "Tools" menu. Follow the instructions given by the pop-up windows to perform the repair process.
Repair using Device manager:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Hope this works.
Mar 10, 2011 | Philips GoGear ViBE Digital Media Player
Licence Problem with Philips GoGear 2GB
try removing the dmr on the files heres a site with a freeware program to do this i havent tested it yet but try it www.downloadatoz.com/...drm.../drm-removal-freeware.html
Sep 25, 2009 | Philips GoGear SA3125/37 MP3 Player
Hdd6330 claims "empty list"...it's not
Run a Repair in the Philips Device Manager (note: the HDD6330 is not compatible with Windows Vista or with Windows Media Player 11 - pluggging the device into a computer with either of these installed will ruin the player, even though it may work initially).
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
-Tha Mp3 Doctor
Mar 25, 2009 | Philips GoGear HDD6330 MP3 Player
Mp3 4GB
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Feb 03, 2009 | Philips GOGEAR SA6045 MP3 Player
My philips gogear 8 GB media player won't take a charge or nothing
Make sure the hold/lock is not engaged.
Try a different USB port.
-Tha Mp3 Doctor
Jan 06, 2009 | Philips GoGear SA5285/37 Digital Media...
Sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Sep 03, 2008 | Philips GoGear SA178 MP3 Player
My mp3 player wont play anything
hmmm, that means that you may have synched some songs that are not fully compatible with your go-gear. although it is still mp3, it may have some "codecs" issues with it. and thus making your go gear crazy. what you can do is delete all the songs you have there, and make a fresh start from scratch, that way, you'll know.
Apr 28, 2008 | Philips GoGear HDD6330 MP3 Player
Philips mp3 player
whenever i turn on my philips 1gb gogear it says player problem connect to pc.
Feb 01, 2008 | Philips GoGear HDD6330 MP3 Player
On my philips HDD082 MP3 Player
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Dec 23, 2007 | Philips HDD082 MP3 Player
Music doesnt show up on mp3 player library, but it does on the computer
-Tha Mp3 Doctor
Nov 14, 2007 | Philips GoGear HDD075/17 MP3 Player
Philips GoGear HDD1830 MP3 Player Logo
114 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
