Question about LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB
My Ethernet Big Disk appears in Device Manager but is asking for a driver; In Windows Explorer however, no trace of the Ethernet Big Disk! What to do? How can I tackle this problem in order to access my data on Ethernet Big Disk? My Operating System is Windows 7. w.s. Lord Sunshine
  • 4 more comments
  • Lord Sunshine Oct 09, 2010
    The LaCie Ethernet Big Disk is attached directly to the pc via the USB cable.
    Strange indeed!
    I did try doing windows update to search for drivers: No results.
    I searched online: No results.
    The drives are spinning and I do not think that the drives have failed.
    I opened the LaCie Ehernet Big Disk drive and there are 2 SATA HardDrives attached in a RAID0 configuration.
    When I attached them separately to the pc, the BIOS immediately recognize them for what they are.
    There is important data on the disk that i want to salvage.
    The enclosure is the problem.
    I suspect that the RAID configuration is hardware managed by the enclosure.
    My question is: Do i enable RAID in BIOS when connecting broken RAID drives?
  • Lord Sunshine Oct 10, 2010
    Thanx a lot for your suggestions!
    I connected ethernet lan cable and usb cable to LaCie Big Disk.
    I did download all of the above suggestions and double-clicked on "Ethernet Disk mini & Big Disk USB Driver Win", resulting in the disappareance of the exclamation point behind the Ethernet Big Disk in the device manager.
    But still I am not seeing any Ethernet Big Disk appear.
    Next I double-clicked on IPconfigurator but am still not able to access the Big Disk with network.
    Please tell me What more to do?
    And where do the other ones I downloaded (update-1.0.10.signed & Ethernet_Disk_update-1.1.2.1 signed) come into action?
    KRISHMAQVAN IS A GENIUS!
    MANY, MANY THANX!
    Your proposed solution did work.
    I am finally now able to see the Big Disk in my network.
    God Bless You!
    and also accept my Heartfelt Blessings.
    w.s. Lord Sunshine
    THANK YOU VERY MUCH!
    Finally I am now able to see My Big Disk in my network.
    Thanks to the good work of the FIXYA.COM team I have been spared the calamity of losing valuable data.
    FIXYA.COM: Keep Up the Good Work !
    w.s. Lord Sunshine
  • 4,281 Answers
Click here Click on above link and download Lacie IP configurator and Ethernet Disk mini v2 (Gigabit) & Ethernet Big Disk Updater.Also download usb drivbers. Then install in windows 7. Make sure ethernet lan cable id working fine and ip address are in range of network. If you are not able to access it with network then connect usb cable then tack backup of all data. You can download ethernet and usb drivers from above link. there is also download for IP configurator so you can configure ip. Let me know if you need further assistance. Thanks for using FixYa,
Posted on Oct 09, 2010
  • Connect your Lacie disk with usb cable.Then
    Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
    then check.
    Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
    And remove upper filter and lower filter.Then restart computer then check.
    President:
  • 2,777 Answers
Interesting, it shouldn't need much of a driver with Windows 7. How are you attaching the device to your computer, directly, or through your network with a network cable?
Tim
  • Tim Grayson
    Tim Grayson Oct 09, 2010
    Strange, it shouldn't need any driver at all. Is this drive brand new? It sounds like you may have a bad drive on your hands here. Did you try doing the windows update to search for drivers? Go into device manager... go to the drive details, update driver, and let it search online.
    If it can't find anything that means the drive has failed.
    Thanks
    Tim
  • Tim Grayson
    Ok that would confirm then that the actual enclosure has failed. I hope there wasn't any important data on the drives. These Lacie drive enclosures are trouble, I have seen many many of them fail.
    I have also confirmed that Windows 7 has a built in driver for the device so the only reason it wouldnt load a driver would be the enclosure has failed and is sending irregular instruction sets to the computer, have seen this numerous times.
    At least the drives themselves are fine, was it hardware raid-0 meaning the enclosure manged the raid or was it software based? If software you can just rejoin them in windows and hopefully get your data back.
    Thanks
    Tim
Unable to detect cdrom after crash / reinstall Vista O/S
hpweb_1-2_minus.gifCheck the Windows Device ManagerDevice Manager is a Windows program that displays hardware devices installed on your computer that are currently recognized by Windows. If functioning properly, each piece of hardware has a corresponding entry in the Device Manager. If a piece of hardware is not listed, then there is a problem. There can be a variety of reasons, ranging from the easy-to-fix (such as missing or corrupted device drivers) to the more serious (such as broken or malfunctioning hardware).If your drive does not appear in Windows Explorer or there is no response from the operating system when you insert a disc, then you should check for an entry in Device Manager. This indicates whether there is a problem or not, and sets the stage for subsequent troubleshooting actions.To verify that the optical drive is listed in the Device Manager:
  1. Remove any discs that may be present from the disk drive.
  2. Click Start , type device into the search field, and then select Device Manager from the list.
  3. In the Device Manager window, expand the DVD/CD-ROM drives entry. There should be a name listed for each installed drive.If the drive is not listed or the DVD/CD-ROM drives entry does not exist and you have verified that it is listed in the BIOS , continue to the next troubleshooting item. reinstall the default device drivers Device drivers are software processes that allow Windows to use the computers hardware components. If the device driver fails or becomes corrupted, then Windows cannot properly communicate with the drive; in fact, it may not even recognize that the drive is connected at all.
Another common source of disk drive problems is that the correct device driver may have been inadvertently replaced with an incompatible one (for example, a generic driver for optical disk drives mistakenly installed by a third-party DVD burning program). In most cases, device driver problems like these can be resolved by reinstalling the default drivers and then installing any driver updates provided by HP. To reinstall the default device drivers:
  1. Click Start , right-click Computer , and then select Properties .
  2. In the System pane, click Device Manager link. If prompted, allow the computer to access the Device Manager.
  3. In Device Manager, click the plus sign c02993920.jpg (in Vista) or the arrow c02993921.jpg (in Windows 7) next to the type of driver you want to uninstall and reinstall (for example., Modems, DVD/CD-ROMs, and so on), unless a minus sign (-) is already showing.
  4. Right-click each listed driver one at a time and click Uninstall . When prompted, confirm that you want to uninstall the selected drivers. Do not restart the PC In the Device Manager pane, select any listed device and click the Scan for hardware changes button (near the top). Windows scans your system for hardware and installs default drivers for anything that requires drivers.
    1. Open Device Manager and verify that your device drivers are listed once again.
    2. After the device drivers have been reinstalled and appear in Device Manager, try running your program again.
      NOTE:Some devices may require your computer to restart. Windows will notify you when restarting is necessary. Save all open files and allow the computer to restart.
    If reinstalling the default drivers does not correct the problem, continue to the next troubleshooting item.
Oct 20, 2011 | HP Pavilion Dv6910us Notebook
I just purchesed the logitech pro 9000 iput the disk in my powerbook and the icon appears it asked me to choose an application to open it with ,What do i use to open with?
Applications like Windows Live Messenger, or Yahoo messenger, and Skype have webcam applications. Also, some picture type programs allow webcam video capture...
Oct 03, 2010 | Logitech Webcam
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
Ethernet not working after format and xp reinstall
Right-click the My Computer icon and select Manage, then go to the Device Manager in the list on the left and find the Network Adapter from the list on the right, right-click Network Adapter and select Uninstall. When you reboot, XP should find the Adapter and reinstall it automatically. Another reboot may be required.
If it still will not connect, go to the NIC Manufacturer's website and download the driver to removable media. The Driver Update option can be accessed in the Device Manager, but this time select Properties when you right-click the Network Adapter, and go to the Driver tab.
Dec 22, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Siren MP3 player not recognized by Windows Explorer‏‏
Installing the latest Windows Media Player solved the problem.
Oct 02, 2008 | Siren Edge MP3 Player
'lost' etherent driver
The ethernet drivers are present in your motherboard cd thats bundled with your pc or ask the vendor to provide it
Sep 14, 2008 | E-Machines eMachines Desktop PC
How do i get stuff into my new driver? just bought a newusb ext hd.500gb. i've looked in the handy dandy users guide,but no help there.
WHen you connect it, it should appear as a disk drive in Windows Explorer (type Windows key + e ).
If you cannot see a drive letter then try My Computer - right-click - properties - Manage - click on disk manager and see if you can see the USB disk.
If Windows does not detect the USB device when you connect it - check Device Manager in COntrol Panel - SYstem - Dev Man - Hardware to see if all USB drivers are installed
Aug 08, 2008 | Computers & Internet
Removable Drive
if you have reinstalled windows you will need to install the driver for your flash drive, because there are no built in drivers. install the driver and the drive should then be recognised and then show in device manager
May 14, 2007 | Lenovo ThinkPad R51
LaCie Big Disk Extreme with Triple Interface - hard drive - 1 TB Logo
446 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
