Question about Fisher and Paykel OS302SS, Stainless Steel Single Oven
The oven light screw fitting came out when bulb unscrewed. There is now nothing to screw the bulb into
  • 1,070 Answers
Only solution is to replace the socket. no other choice.
Posted on Oct 09, 2010
Have a Bosch built in Oven, cannot release glass cover to replace oven bulb
Take a look at www.espares.co,uk where they have some videos explaining the different fittings....
On some the glass cover unscrews and on others there is a screw and cover plate that needs to be removed..
Apr 16, 2017 | Bosch Ovens
How do I change the light in my double oven microwave KEMC308
the light cover at the back of the oven needs to be unscrewed. There is normally 2 or 3 little screws involved. Once it has been removed it's like any other light bulbs, unscrew and change. Make sure to put back the cover tightly in place or the light will burn when the oven turns on.
Mar 14, 2011 | KitchenAid KEMC378 Electric Double Oven
How to change a Magic Chef gas oven light bulb?
My experience is that there is always at least one (and usually two) Phillips-head screws that secure a glass cover over the light bulb.
Unfortunately, a combination of heat and gunk can make these screws difficult to remove. Get a screwdriver with the proper-sized tip and a LARGE handle that will give you adequate torque, and try removing these screws. If they won't budge, try tapping the handle of the screwdriver LIGHTLY with a hammer... this might knock the gunk loose enough to turn the screws.
If that doesn't work, try using a ratchet with a Phillips-head fitting.
The most important thing is ensuring that your Phillips fits the screw(s). If not, you'll risk damaging the screw head(s) & then you'll have huge problems getting them out.
Once you get the screws out, remove the glass plate (you might need to lever it out with a flathead screwdriver). Clean it well. Unscrew & replace the light bulb. Reverse the steps for re-assembly. If the screws are gunky, or if the heads show any signs of damage, get some replacements at a hardware store (so you don't have trouble a few years from now!).
Mar 02, 2011 | Magic Chef Ovens
How do you change a light bulb in a panasonic microwave oven
Usually you need to remove the outer case from the microwave to change the light.
If you are confident with basic tools, a DIY person, if not get an electrical person to fix it.
Make sure it is unplugged and leave off for 30 minutes or so. Unscrew screws at the back to loosen the outer case. Slide the case off Change light and re-assemble. Make sure the case is properly fitting it usually has lugs that fit into the front piece.
Jan 13, 2011 | Ovens
How to fit oven bulb
You should have a glass cover over the bulb itself. It may either screw on or it may have 2 or 3 screws at the base of the glass to take out. Then you should be able to unscrew the bulb as you would any other light bulb in your house. You will want to replace it with another appliance bulb 40 watt. If you have another type bulb or set up in your oven let me know and we will work through it.
Feb 11, 2009 | Stoves Ovens
Glass light cover removal
Try spraying WD40 onto the glass and bulb holder, try to screw the bulb cover back on first, and then try to unscrew i, it may help if you grasp it with a cloth or similar as you try to unscrew it
Plz rate my solution.
Tghanks.
Jan 19, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Unable to take out light bulb
I can tell you it screws out . i had to break mine to get it out ( the bulb cover that is) Still had some thread left to wind back up.
Dec 22, 2008 | Ovens
Neff B1432 Oven Not Heating; oven light flickering
If the fan is working o/k then you need a new element fitting.
Remove the panel at the rear of the oven, there you will see the element, remove the fixing screws and ease the element forward,taking care not to lose the wires, disconnect the leads and fit new element.
The light flickering is probably the bulb not screwed in propely or a bad contact, nothing to worry about.
Thanks
Dec 19, 2008 | Neff B1432 Single circotherm plus Electric...
Light bulb
for most smeg, the bulb cover just unscrews as does the bulb and the bulb is a heat-proof small edison screw type
May 07, 2007 | Smeg SE250XUK Stainless Steel Electric...
Fisher and Paykel OS302SS, Stainless Steel Single Oven Logo
137 people viewed this question
Top Fisher Ovens Experts
Dennis Boxerman
Richard
Richard
ray gallant
Are you a Fisher Oven Expert? Answer questions, earn points and help others
