Question about Alpine CDA-7876RB CD Player
No soun thru speakers
Everything seems to work correct, except for no sound thru the speakers. After you drive it down the road awhile, sometimes it comes on. But up in the right hand corner there is an envelope with "IN" lite up and I've never seen that before. I a getting no sound thru the speakers. (CDA-7875)
  • 59 Answers
First try resetting the unit. If that don't work try this:
Press and hold the SETUP button for at least 3
seconds.
2 Press the UP button repeatedly to select
“mute”.
Each press of the UP button changes the
modes as shown:
NOTE
If you press the DN button the display scrolls in
reverse sequence.
3 Press the TUNE button to toggle the mode
between MUTE ON and MUTE OFF
4 Press the SETUP button to set the selected
mode.
→ NORMAL/HI-FI → AMBER* → DIM → SUB
DEMO ← AUX ← SCR ← MUTE ←BEEP ←
Posted on May 30, 2008
Why does my car try to die when i drive down the road?
Try to check the ignition coil, when you driving it become hot then the car dies end won't start. After awhile when it's cold, then it will start. Replace the ignition coil.
I hope it solves the problem
Jun 16, 2013 | 1991 Honda Civic
I am getting no sounds from my speakers. Everything on the PC seems to be set correctly. The speakers do work when an Ipod is plugged into it. How can I tell if the problem is the cord going from the PC to...
I have tried everything I can think of to fix the problem, but finally gave up and called the person who I purchased it from last June. As I had been using a headset, I don't think we ever tested if the speakers worked with this PC. He is coming to look at it tomorrow. I seem to have ruled out everything except the connection ports on the PC. I hope that he can solve the problem tomorrow.
Jan 17, 2010 | Koss HD 100 Computer Speakers
No audio. no manual.
how is ur sound output from the computer box is conencted....is there an external speaker thru which u listen sound ?
if so that cable from the sound output slot on the PC need to shift to the monitor speakers thru some cable that goes into the monitor from the CPU box....
Jan 04, 2010 | Computers & Internet
Left speakers sometimes cut out and leave just a high treble soun
please check the input connecetor could be the losse conact with the wire some times it happens with this type of sound try to play the system and move the connector if the sound trun go replace the input cor
Nov 07, 2009 | Audio Players & Recorders
I was driving down the road and my clarion vrx485vd audio stopped working everything else is fine but just no sound???
Could be a bad speaker causing the problem.. Disconnect the speakers, and then reconnect them one by one with the radio on, and see what happens.
Aug 10, 2009 | Clarion VRX485VD Car DVD Player
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
No sound but everything else seems to work. Please Help
check your speakers and speaker wires for shorts.
Apr 22, 2009 | Car Audio & Video
No souned
check that you haven't muted the sound by accident. Look for a speaker icon in the task tray at the bottom of the screen on the right hand side. If it has a red circle with a line going through it, then it is muted. Click on it then click on the little blue speaker to turn off the mute.
If you have not got a speaker icon in the tray then go to control panel, sound and click double click on speakers then click on the blue speaker icon to turn the mute off. (For Vista)
Also make sure that the speaker wires are plugged in correctly on the back of the computer.
Jan 13, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
No sound from p5k3 motherboard
have you connected to the motherboard with correct plug(generally green in for audio out)try with another of speaker if the problem persists than you onboard sound card is having problem
May 15, 2008 | ASUS Computers & Internet
Alpine CDA-7876RB CD Player Logo
171 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
