I have a flashing 4 2 code. the book says replace control, is the eco a seperate replaceable device?
  • 2,272 Answers
First of all, just unplug the unit from the main power outlet for 10 mins and plug it in again and ON the unit and check whether the unit resets by itself.
Most of the error clear just by power resetting.
If the problem still exists then yes you will have to replace the control circuit. the control panel circuit can be removed easily by opening the screws beside the control panels and flipping it out from its plastic locks, then accordingly as per your model and brand. you can order the part from link below:--
Airconditioner parts link
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Oct 09, 2010
How to program a ge universal remote to a sharp tv
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Apr 06, 2012 | GE 24993 Remote Control
Automatic restart is not working. Seems to keep saying eco problem...I thinl...the code is four flashes followed by two flashes.
Gas control valve is not identified, so error code is not known.
ECO means energy cut off.
Energy cut off happens when gas control valve thermostat has gone bad, or when gas control senses runaway heating inside combustion chamber.
Newer heaters have resettable ECO for combustion overheat. This reset is typically located on combustion chamber door and is round and has two wires that connect back to gas control. Generally you have to clean combustion chamber and tubes and catch up on maintenance, then reset ECO, then fire up heater again to see if problem is resolved.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
Newer heater does not have reset for bad thermostat, and in that case you replace gas control valve thermostat.
Older heater does not have reset, and combustion chamber and parts are cleaned, and gas control valve thermostat is replaced.
Your manual is best place to start troubleshoot.
Open following link to help identify gas control valve:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Jul 10, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Our church has 2 Jazzy's one is blinking the code all lights flash 7 times the other 9 times all lights flash can not find what I need to do in our book. Can you help is there a web site I can get a...
mtp see the below list
The listed Flash codes are pretty standard and are applicable to powerchairs only not scooters:
1 flash User Fault (do not touch joystick) and turn back on
2 flashes Battery Fault Recharge batteries or replace
3 Left motor fault check connections or replace
4 Right motor fault check connections or replace
5 Left park brake fault check freewheel lever or brake connections
6 Right park brake fault check freewheel lever or brake connections
7 Remote fault check connections and wiring replace remote(joystick) (Check cable to the joystick unplug connector at rear of chair and plug back in then try turning on to see if you are getting same code)
8 Controller fault Check connections and wiring replace controller
9 Communication fault check cable replace (almost same problem as 7) try same fix if doesn't work joystick will have to be replaced
10 and 11 are unusual and will not be seen if at all Hope this helps you
Apr 04, 2011 | Pride Mobility Products Health & Beauty
Im trying t0 program a Phillips TV with a RCA niteglo universal remote.
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
Codes:
0154,1174,0062,0204,0004,0184,0208,0205,0206,0207,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0140
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 29, 2009 | RCA Universal Remote 3 Device Remote...
Need codes for rca remot control have phillps tv
CODES: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0199,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
Aug 28, 2009 | RCA Universal Remote Control
ECO Failure
make sure your flue is clear,, and no suit is in the burner, also there are wires going to the ignitor make sure they are not touching after time for what ever reason they need to be seperated because they short out but doesn't cause any problem other then the unit not lighting
Jun 12, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Can you replace the lower ball joints in the control arms
You can replace them seperately,but they need pressed out and in. Other methods of removing and installing likely will damage control arm.
Apr 23, 2009 | 1998 Ford Expedition
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Odd fault codes then stops working.
I had a hotpoint engineer try to fix this type of problem.
He insisted that there was something stuck in the bottom of the filter or pump.
Sure enough there was.
1. Unplug your dishwaser at the wall. Check its off or disconnected.
2. Remove the grill under the bottom rack.
3. Ensure that the filter is free from food and other obstacles and clean the filter.
4. Before replacing filter etc, get a piece of metal coat hanger wire and care fully insert it down the channel under the filter to free any lodged items. You may also see a small white impleller try to turn this with your finger or the coat hanger wire (this is the info from the engineer!).
5. replace filter and retry a wash.
This routine fixed or machine twice and will hopefully fix yours!
Don't forget to rate me!
fyi
The third time about 1 year later this occured again and even hotpoint gave up as they could not fix the machine. (after multiple visits). I think that the two flashing lights are were a red herring and the dishwasher had a separate intermittent fault. Hotpoint replaced the unit for a mimum charge. Callout + 40.
Dec 31, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Remote code i need the code book
I don't have the code book, but I can tell you how to program your remote using the automatic programming feature.
Programming RCA model RCR660 (no code search button)
While following these instructions, keep the following in mind:
device = the component you wish to control with your remote (TV, DVD, VCR, etc.)
DEVICE = the button labeled for the component you wish to program
1. Turn on the device you wish to program.
2. Turn off all other devices in the general vicinity.
2. Press and hold DEVICE
3. While holding DEVICE down, press ON/OFF and hold them both down until the LED turns on for that device.
4. Release both buttons.
5. Point the remote at the device, press and release PLAY and wait 5 seconds or until the LED stops flashing.
6. If the device does not turn off, then continue to press PLAY and wait the required interval (for a maximum of 20 times) until the device turns off.
7. When the device turns off, press REVERSE, wait two seconds and continue doing this until the device turns back on.
8. To finish programming, press and hold STOP until the LED turns off.
Jul 31, 2007 | RCA RCR660 Remote Control
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
