My gateway computer won't turn on and now its beeping at me when I try to turn it on. What do I do?
  • Robert Art
    Robert Art Oct 09, 2010
    The beeps are audible errors codes advising what is wrong with the computer Depending on the beeps it could be something as simple as a bad memory stick or it could be major like failing motherboard or hard drive..... I just recently had a computer that would just do long beep after long beep.... problem was the cpu was fried.... put in a new cpu and computer started up again.... I need to know a little bit about the computer and what are the beeping noises you are hearing? Are they long or short sounds? Thanks
  • Computers & ... Master
  • 5,660 Answers
The beeps you hear are BIOS Beep Codes. The computer's way of telling you something is wrong, and the area to look into for it.
For one example: One long beep, followed by two short beeps. Then a small period of silence, and the beep code starts over.
Without knowing the beep code you hear, it's like shooting in the dark when giving a diagnosis.
Also wish I had the Model Number of your Gateway desktop computer to help you further.
This is up on the side of the computer tower, or on the back.
[ Example.
Model: Gateway 7200X.
S/N = Serial Number. DO NOT give this out in a public forum. Only to a Gateway representative, or Gateway Support online ]
If I were to take an educated guess, it would be a problem with your graphics, or Ram Memory.
I would suggest opening the computer case, and removing all Ram Memory modules, then cleaning the gold plated contact pins on the bottom.
Clean the contacts with a pencil eraser.
FIRST!
Power unplugged to the computer. Work on a table. Unplug all cables to the computer. Open the computer case, follow Anti-Static Precautions.
(If you are not perfectly sure where the cables go, I advise making notes, and a drawing of where they go before you unplug them)
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
[ Some hardware components examples are; Processor, Ram Memory, Harddrive, Graphics Card, and Motherboard's chipsets ]
TOUCH the metal frame of the open computer case.
This action will relieve your body of Static.
Computer unplugged from power, you are safe.
Touch the metal frame, your computer is safe.
Should you leave your computer in the middle of working on it, upon your return be SURE to Touch the metal frame again.
This is a basic example of a Ram Memory module, ('Stick'),
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can left-click on the photo to enlarge. You can enlarge twice)
Note the gold plated contact pins on the bottom, of the Ram Memory module.
These are the contact pins you clean with a pencil eraser.
You don't have to rub the eraser on the contact pins very hard.
Just go over the contact pins with the eraser.
If you are using an eraser on the end of a pencil, refrain from letting the metal band, contact the gold plated contact pins on the Ram Memory module.
After you clean each contact pin it may not look like you have done anything. You have.
Corrosion builds up on the contact pins after time. It takes very little corrosion to make a bad contact on those contact pins.
Use air to remove the eraser dust.
If you have a can of compressed air for computers available, this will work.
If not air pressure from your mouth will be sufficient.
Reinstall the Ram Memory module/s.
Reinstall the computer cover.
Plug the computer back into power.
WAIT 1 minute, turn the computer on.
Gateway Support > All desktop models,
http://support.gateway.com/support/supinfo/index.asp?pg=2&file=dt.html
Video of how to remove, and reinstall Ram Memory,
http://www.videojug.com/film/how-to-install-more-memory-in-my-computer
[ You won't need an ESD wrist strap following my Anti-Static Precautions above ]
Posted on Oct 09, 2010
I turn on my power on my gateway, I here 1 beep then after that comes 2 beeps, my monitor is showing no signal
ohhhhhh a running Gateway, (nastalgic to the max)
the beeps are gfrom the motherboard.
they have meaning,]'
there is no standard, only the gateway book on your PC
covers it. t
these are called cold boot errors from BIOS ROM.
can be bad memory
or bad video card.
if you have 2 or more memory sticks?try them one at a time in bank 1 slot (lowest)
if that works try a spare video card.
Feb 16, 2017 | Power Computers & Internet
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Windows won't start up? Well, try this Download Tenorshare Data Recovery from its offical site and install it. Burn it into CD/DVD, or USB flash, put into the computer you need to repair, Bios setting. It can make sure your important data will not lose. Best of luck
Related: windows won't start
Aug 25, 2012 | Gateway MP8708 Notebook
Gateway GM5442 PC Desktop Won't Boot!
3 BEEPS -RAM
Guest Posts: n/a 01-24-2005 We had a power failure in the office this weekend. All the systems are back
up and running fine, except for the receptionists. It's a Gateway
Professional Series. P4 1.3 Ghz. It is giving me three beeps. No boot up
screen and no video source (monitor light stays yellow instead of turning
green). I looked up the beep code and it says three beeps means the ram
needs reseated. Which I have done several times. Also, I have just put in
one stick in difference seats. I have also reseated all the cards at least
three times. I have switched the jumper to try to boot into setup mode.
Nothing there either. Popped out the cmos battery and put it back in. No
good either.
Has all the ram been fried? The fan on the cpu is still spinning. The cd-rom
ejects. I can't hear the hard drive spinning. I guess I can swap the hard
drive for a different one.
Anything I'm missing? YEP
http://support.gateway.com/s/MOTHERBD/INTEL/m00262/beepcode.shtml
Apr 06, 2012 | Gateway GM5442 PC Desktop
Gateway laptop wont turn on just beeps continue
How Many Beeps you hear ?
1 Beep Continues > Problem in RAM
2 Beep Continues > Problem in RAM or Mother Board
3 Beep Continues > Problem in Base of RAM is Not Same
4 Beep Continues > Problem in Time System
etc.
i Recomended to you to see at zylone81.indonesianforum.net/forum/ for to know Computer and laptop Problem from Beep sound.
Jan 06, 2012 | Gateway NV5929u PC Notebook
Gateway GT5082 Media Center Computer - Froze. When I turn it on, I get a blank screen and a single, consistent beeping. Once I was able to F8 to restart, but then it happened again and it won't come...
That is a ram problem. Take em out and reseat them, and then one at a time, if more than one.
until something works. then is nothing works, get new ram.
Aug 06, 2011 | Gateway GT5082 PC Desktop
I have a Gateway FPD1975W 19in LCD monitor and now it won't turn on. I have checked the cables and tried unplugging and plugging it back in. The power light will come on for a second, the Gateway logo...
First of all check if the monitor works in another computer.
Pay attention at your computer beeps when you start it up.
If there are a series of repeated short beeps it means that there is a problem with your video card.
If there is a long beep that repeats, then its a bad memory module.
Fix one of the three, and you'll have your image back. Good luck.
Don't forget to rate this answer if it helps.
Aug 20, 2010 | Gateway FPD2275W LCD Monitor
Computer "turns on" i hear four to five beeps, but the monitor gets no signal. a friend gave me the computer, only once did i see it boot up fully but it froze up so i had to restart it and it wont work....
Without knowing the exact frequency/length of the beeps my first guess would be a bad stick of ram or a bad video card. If there is more than one stick of ram in the computer try it with one of the sticks pulled, pulling each stick until it does boot. if it doesnt, try pulling the video card. If you have on board video as well as a card, you can try it with just the on board and no video card. If not, borrow a vid card from someone. Doesnt have to be anything special, it can even be one of the old 4 MB PCI cards... just for diag. If that doesn't fix it, try pulling out any other cards that may be in it. Modem, sound, etc. etc.
and finally, here is a link to all the bios error codes for Gateway computers to help with further trouble shooting.
http://support.gateway.com/s/Servers/COMPO/MOTHERBD/WME859199/WME859199faq2.shtml
Jan 02, 2010 | Gateway GT5028 PC Desktop
Motherboard beeps three times, computer won't boot up
Your computer is experiencing memory problems. Turn power off, remove and reseat the memory chips, and try it again. If not successful, try different memory chips. Also could be power supply problem
Jun 13, 2009 | Gateway 506GR PC Desktop
Gateway 838gm
Does the computer beep when you turn it on? If so, count the beeps and google it. Something like "computer beep 3 times at post" or similar.
If it does not beep, remove all buy one of your memory chips. (mind your static charge, keep in touch with your computer case so you don't fry your mobo or memory) Will the system post with only one chip? If not, try all of your memory chips one at a time. Post now? If so, you can narrow down the issue.
If this doesn't work, remove all of the cards. (video, sound, network, etc) Turn the computer back on. If it still does not beep, it is very likely that the CPU is the culprit, with a slight left field chance of it being the power supply.
Jan 17, 2009 | Gateway 838GM (RB838GM) PC Desktop
Computers & Internet Logo
1,030 people viewed this question
David Payne
David Payne
