Question about Toshiba Satellite A60 Notebook
Is it possible to change laptop case - Toshiba Satellite A60 Notebook
  • 24 Answers
No. Laptops are specifically built for the case it's in. Sorry.
Posted on Oct 09, 2010
I have Dell Latitude D600 with keyboard problems,when i type some characters doesn't become appropriate.help on that please
I am not sure what you mean by "doesn't become appropriate". But to give some possibilities:
1. Your working in Microsoft Word and the characters are not standard, then you probably need to change the font
2. The keyboard layout may have been changed. For example if you press on the normal "S" key and it enters an "O" your layout has probably been changed to DVORAK layout. If this is the case then you simply need to change the layout back to standard QWERTY.
3. There may be a few other possibilities but if it's not one of the two above then it's possible someone installed some sort of prank.
A little more info on your problem would help narrow it down.
Sep 04, 2013 | Toshiba Satellite A100-S8111TD Notebook
Laptop wont switch on even when charger plugged in
I recommend to him not to do it because him lapto it is possible to put in shortly and is not going to ignite
Aug 31, 2011 | Toshiba Computers & Internet
Is it possible to replace pre installed web cam on my laptop?
It might be possible to replace the camera in case of some laptop companies which provides good service during their warranty period such as DELL, HP, VAIO, Apple.
If your camera isn't working properly in your warranty period then it could be replaced but not changed with other model.
If your warranty period has expired then it will cost you more; instead you can buy a decent USB webcam which could be easily attached to head of the display!!!
May 17, 2011 | Computers & Internet
Blank Screen , Power light comes on and all lights right under screen (sound and media playerand touch pad lights) come on and stay on. disk drive works and no secondary monitor display.tried the battery...
If you have checked all functions as you described and a remote monitor, then the problem is the graphics card on the motherboard, in most cases the motherboard must be changed because the graphics card is built in.
May 13, 2011 | HP Pavilion dv7-1130us laptop
Trying to connect wirelessly to 2 wire. I get limited access icon
Hi groveland1,
I see that you are having issue with your Internet Connection, Limited or no connectivity is a possible issue with your network key / security key on the router and your laptop.
1. Try and check the network key in your router.
2. Check your network settings in the Laptop and see if the security settings in your Laptop is the same as the security/network key in your Router.
3. If possible recreate your wireless connection in windows for a fresh connection from your Laptop to your Router.
4. Change your Network Key in the Router and in your Laptop see if it will connect in-case you may have forgotten you old Network Key.
Hope this helps.
Apr 04, 2011 | 2wire (1000-400108-001) Router
Battery light blinks for a split second then turns off seems like laptop is fried?
it means that the battery doesnt have much power try to change the adoptor it seems like ur adoptor is not doing its work and if possible try to use a different battery just in case if the battery is at fault
Dec 24, 2010 | Computers & Internet
I want graphics card for my acer 5570z laptop.ple help how to buy? where? because my laptop not suppot games or big size video.
It's not possible to change video card on laptops, because they are (in most cases) integrated on motherboard. You have to buy all new laptop with better graphic card, if you want play game;)
Aug 20, 2010 | Acer Aspire 5500 5570-2609 Laptop
My LCD screen won't always turn on.
If this is the case, you may have to replace the LCD screen on the notebook. Once your machine is still under warranty, it would be possible for a technician to bring over the new equipment within 3 to 5 days of your report and change it out for you.
There may be short circuit or connection problem with the display screen and I recommend changing it.
What you can also do to eliminate the possibility of it being the video card is to use a stand alone monitor and attach it to the laptop's VGA or DVI connection.
Hope this helps...
Apr 17, 2010 | Dell Latitude D600 Notebook
Laptop starts, fan runs, no hard drive led's, no audible hard drive activity, no display, then after about 5 minutes, switches off again
Here in this case, there could be 2 possibilities.
Possibility 1: You might have a to get a new HDD
Possibility 2: The RAM might have got loose
Under Possibility1: If you are able to get the initial display, then get into BIOS and see whether the HDD is shown in the BIOS. If it is so, then you should be able to use your laptop normally.
Under Possibility 2: There is a great chance that the RAM (memory stick) might have got loose. In this case, I would suggest you to take the laptop to the authorized service center and get them checked. If the problem is same as what I suspected, then you the service guys should be able to fix your laptop in just 10 minutes. And they might not even charge you for this.
In any case you could check out the RAM, because most probably this could be the culprit.
Mar 25, 2010 | Computers & Internet
Acer aspire 5610z
Greetings sergiu,
If I understand your question right you have a video card, possibly from a desktop, and you want to know if you can put it in your laptop?
If this is the case, regrettably most laptops have video cards built in to the motherboard. In some cases there are units that have replaceable video cards, but these are created differently and have different connections then a standard video card.
Sorry to be the barer of bad news.
Jon
Go Ahead. Use Us.
Jun 08, 2008 | Video Game Consoles & Games
Toshiba Satellite A60 Notebook Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
