Question about Panasonic KX-FL511 Plain Paper Laser Fax
I have a Panasonic KX-FL511 and it's displaying a Call Service 2
  • 4 more comments
  • oleprint389 Oct 09, 2010
    Everything works, I was able to clear it by pressing a bunch of buttons. But what happens
    when it displays it again
    I have a Panasonic KX-511 Plain paper fax. It is displaying Service Call 2 - and fax in memory. How do I clear and get fax out?
    Sorry I don't know how to use this site very well. I have unplugged and plugged 3 times today and the problem keeps happening.
    If I have already unplugged 3 times and the problem persist is there something wrong with the unit?
    It worked for now. Thanks
  • 2,272 Answers
"call service 2" means :- laser beam error. replace the laser beam unit(lsu).
But try resetting first. In most cases resetting will solve the issue. Press Menu first, then #9000*, next press 550, press Start, wait for printing, unplug the electric cord, wait 10s or more, plug it again, it's done.
if it does not reset then you will have to get laser beam unit replaced.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Oct 09, 2010
    President:
  • 2,777 Answers
Does anything work on the device still? Usually that indicates the machine has hardware failure and needs servicing...
Let me know
Tim
  • Tim Grayson
    Tim Grayson Oct 09, 2010
    Ah ok, as long as it got cleared out you are ok. It was probably just a temporary hardware glitch, it happens sometimes. One way to be sure to get rid of it (unless it's really having hardware problems) is to simply turn off the device, unplug it from the wall for a good 2 minutes, then replug it in.
    If it continues to display the message though that means something is actually wrong with the device. But it sounds like the unit just had a temporary glitch. It basically has little miniature computer in it, and like regular computers they can have software glitches, that's all it was - thankfully.
    Thanks
    Tim
  • Tim Grayson
    Wait did you just reject my solution? Why :(
    Tim
5 Suggested Answers
  • 31 Answers
SOURCE: Keep Adding Toner to Panasonic KX-FL511
kindly follow this instruction
but doing this will erase all the message in the memory
press menu #9000*550 start
unplug the unit once heard the beep
after 10 seconds, plug it again
Posted on Mar 11, 2008
  • 82 Answers
SOURCE: Panasonic KX-FL511 cannot receive faxes but can send
check to see if your phone line is plugged in the " L" or line slot on your fax machine if it is then press the speaker or monitor key and listen for dial tone. then you put a document into the feeder and dial your cell phone number and press send, when your cell phone rings answer and listen if you are getting a high pitched squeel. if you are then it should be working. try it the other way too by dialing from your cell and listen again for the squeel. if you still don't get the squeel you have a defective modem.
Thank You,
Mikey
Thank You,
Mikey
Posted on Apr 06, 2008
  • 215 Answers
SOURCE: Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Posted on Apr 13, 2009
FixinFax
  • 3085 Answers
SOURCE: Fax Machine Panasonic KX-Fl511 a fax was sent
Unplug the power cord for 10 mins.
Posted on Jul 02, 2009
What is the code 43 in a panasonic KX-FL511
Your error 43 refers to the fact that the fax you are calling does not answer. Talk to them and ask if their fax is set to "Auto Receive". its probably not.
Dec 01, 2016 | Panasonic KX-FL511 Plain Paper Laser Fax
Call service 1
At this time we recommend you locate an authorized service center using the below link.
Welcome to Panasonic Online Repair
Apr 03, 2014 | Panasonic KX-FL511 Plain Paper Laser Fax
I have the kx-fl511 and it's displaying a call service 3 and won't answer fax calls anymore.
Hi Kenneth, honestly I know nothing about faxes, I checked Panasonic site and that error means the unit is not heating up properly, they suggest to check the power cable. You can connect and check the site: shop.panasonic.com/support, select: get support, enter model #, then enter your inquiry, or click: operating manual (or instructions). hope this will help.
Dec 13, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
How do you program the panasonic kx-fl511 to print fax confirmations sent.
How can i remove call service6 problem on my
Problem with the Panasonic KX-FL511 Plain Paper Laser Fax
Jul 07, 2011 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Dec 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Need user manual
You can download a manual here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Laser-Fax/Copier/model.KX-FL511
Feb 06, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic fax KX-FT73
I THINK THAT IS MECHINACIAL PROBLEM .CHECK DEEPLY ALL SENSORS AND ALL GEARS .ANY MISHANDLING IN MACHANICAL.mian akhlaq
Aug 07, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
I have one Panasonic fax model no.KX-FM89BX showing call service 2
So, people, really! "Call service"message means CALL the SERVICE! (The problems can be various, so only the service can check wich is is the give problem and solve it.)
Jul 02, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 Plain Paper Laser Fax Logo
725 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
