Question about Kenmore Refrigerators
I have a Sears Kenmore model 10651582200 side by side refrigerator that is freezing everything in the refrigerator. The damper seems OK. The Freezer setting is set at the lowest and I have the refrigerator (thermostat) set to the off position, yet it still runs and the refrigerator temperature is still in the freezer range. Is it the thermostat or is there another component that might cause this problem?
HVACRH20
  • 237 Answers
SOURCE: Hot point side by side electronics not operating damper
See if you have some paperwork on how to test, etc. located in a plastic bag taped up to the underside of the fridge. Pull the front vent cover off and you should see (feel) a bag taped up there with the test paperwork in it. If you don't have it let us know and maybe I can email it to you.
Posted on Dec 26, 2006
fridgetech
  • 473 Answers
SOURCE: My kenmore refrigerator side by side
Sounds like it has a defrost problem.  Check for thick frost buildup on the back bottom panel in the freezer first and let me know what you find so I can steer you in the right direction.  Also, give me the entire model # from the sticker inside fridge.
Posted on Oct 18, 2007
bobotfel
  • 236 Answers
SOURCE: Thermostat (1) Assembly defrost, (2) damper, (3)Thermostat???
If it is digital control its either the thermistor or the control itself, if it is manual then the problem is the thermostat.
Posted on Feb 05, 2008
  • 66 Answers
SOURCE: The Freezer freezes...and so does the Refrigerator!
your thromstae is bad
Posted on Feb 06, 2008
  • 110 Answers
SOURCE: Refrigerator freezing over
if you haveno control of the temp. it is the cold control t-stat that is bad, but first i would sett all controls to factory setting and allow to run for 24 hrs to confirm
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Jun 01, 2008
Refrigerator side freezes
if the food in the fridge side is freezing it sounds like the damper door isn't closing,the way it works is cold air is produced in the freezer side,the evaporator fan blows the cold air from the freezer to the fridge side and it blows through the damper assy. if the damper door isn't closing youll have sub zero air constantly blowing into the fridge sidethe part number is 5304482075 but it's around 200 dollars.you can go here to sears and look up the parts or call a tech in to check it out
http://www.searspartsdirect.com/partsdirect/part-model/FRIGIDAIRE-Parts/Refrigerator-Parts/Model-FRS26R4AB0/1428/0165000/R0108022/00005?blt=06&prst=&shdMod=FRS26R4A
Jun 17, 2014 | Frigidaire FRS26R4A Side by Side...
Where is damper door in a kenmore refrigerator model #9510681 side by side
If you can't see the damper door, it is most probably shut, possibly frozen or not working. Top of middle section, allows airflow from freezer to fridge part. Switch thermostat off, wait 20 mins, switch back on. If damper doesn't open, check stat and damper motor.
May 30, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Past couple days the refrigerator side is freezing everything. turned the setting all the way back and still freezing......dont know if there is a thermostat and if its a DIY fix
Damper door is either broken, stuck open or stuck open and frozen with ice. Damper door is located in the top left corner of the "refrigerator side" of the fridge. Damper door may be concealed by an outer plastic covering usually held in place by a 1/4 inch screw.
Thanks and let me know if that helps,
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie GOFAR Services, LLC
Aug 26, 2011 | Kenmore Side by Side Refrigerator
Refrigerator freezes food regardless of dial setting. Control board?
Thank you. The part number you need is 240383703 at $146.18 thru Sears and is the control for the refrigerator not the freezer. The refrigerator control operates the opening and closing of the damper door which lets air pass from the freezer to the fresh food. The control is keeping the door open longer than it should. Hope this helps. Worth the repair and has been one of the most common problems with this model.
Feb 04, 2010 | Kenmore 52642 / 52644 / 52649 Side by Side...
Kenmore refrigerator-- freezer is working fine. Refrigerator is freezing food. I changed the temp dials to send coldest air to freezer. Food is still freezing any suggestions.
I need the model number that Sears put on the fresh food section door to confirm. Until I know which model you have I need to assume that it has an electrically controlled damper between the freezer and 2 temperature controls. I also have to assume that they both are connected by their wiring to a Adaptive Defrost Control. If one of the three things listed is not working then that part will need replaced. Now there are cases when the damper door becomes stuck and you would need to unplug the power and open the rear panel in the back of freezer to see if frost or ice has the damper stuck wide open. Sears numbers look like this for example 231.564897 bottom of fresh food door behind door seal and near floor kick plate, Let me know what you find and I will be happy to help you, Thanks, Sea Breeze
Sep 13, 2009 | Kenmore Refrigerators
Fridge compartment is freezing
It is the part # 2315515. It is a motororized contraption that opens and closes the baffle to let the freezer air into the refrigerator. It is one part. Mine shut closed. I removed the whole thing in hopes I can do without it. It will be a trickey proposition getting the freezer temp adjusted just right enough to keep the fridge just right enough. The repair man said they are seeing alot of these right about now. They don't make em like they used to.
Jun 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Food in refrigerator freezing solid toward back of compartment
Been there, done that. You need to have a new computer board installed in the fridge near the top. Ours got hit by static lightning ang blew two of them in two years. When they go out, the defrost cycle fails and Ice builds up in the freezer in the back middle. Take the back vover off in the freezer and you'll see it packed with ice since the defroster is not getting the signal to defrost. order a new computer board, install it in the top of the fridge side, in the back, above all those controls on the back right side in a white case to hold the board. defrost the ice by using a hair dryer and letting all the water drain out and get it dry. Those PC boards do not like static at all
Nov 28, 2006 | Maytag MTB2456G Top Freezer Refrigerator
Refrigerators Logo
55 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
