Question about RCA L32HD31 32 in. LCD HDTV
I have a RCA L32HD31YX12. I have had the tv for a little over a year, and now there is no sound. The tv comes on and everything seems to work properly, but no sound is coming from the tv...at all. What could be the problem? Thanks!
  • 4 more comments
  • weslee_masse Oct 09, 2010
    Hello, Thanks for commenting!
    This may sound dumb, but I am not real sure what an AV receiver is... sorry.
    I do have sound, but it is from my surround sound, not from the tv. The tv has an output for headphones. So, I bought one of those RCA(White/Red) to headphone jack cables. Then I plug in the red/white end into the surround sound. This works good, but I would like to have sound coming from my tv again.
    Also, I have a satellite receiver, and a xbox 360 plugged in to the tv....and no sound is made from the either....
    It is a dish satellite receiver. It is connected to the tv through the audio/video input using the red/white/yellow cable
    I looked at the manual, and my menu does not look exactly like that, but it is close. It doesn't have the equalizer, and it doesn't say surround it say SRS. However, the SRS was already set to Off.
    I personally think there is something wrong with the speakers or something. I think this because even with nothing plugged in except a regular antenna (to watch local channels) no sound comes out. (I unplugged everything today and plugged in an antenna just to see if that did anything) I have played around with the sound setting, but nothing seems to work.
    Well, I opened up the tv today, but I did not know what I was looking for so I closed it back up. I am currently watching it (sound through my surround sound). How much would a main board be?
  • RCA Master
  • 5,807 Answers
Thanks in advance for choosing Fixya for assistance.
I would like to make a clarification request , before I present my possible solution to
your problem,
Does it happen on all TV inputs ? or just on the tuner?
Have you tried connecting the TV audio out to your AV Receiver or similar just
for initial troubleshooting?
If it happens to produce sound on your AV receiver , then Congrats...
you have just troubleshooted a large percentage on electronic circuits
inside the TV ( even without opening it up ).
I can post further , while I await for your answer , to resolve the problem
you are having and post if you can further DIY ( inside the unit )
Posted on Oct 09, 2010
  • 8 more comments
  • Rommel Cana
    Rommel Cana Oct 09, 2010
    here is a copy of your manual :
    http://tv.manualsonline.com/manuals/mfg/...
    refer to page 26 for checking on the audio settings.
    AV Receiver means an Audio Video receiver , it could be any brand that you may have
    Since headphones is OK , then at least the problem is minimal, could just be the settings
    ( audio ) and I hope it is not the amp or associated circuits like speaker
  • Rommel Cana
    an AV receiver is something that have a separate speaker ( on most big speakers )
  • Rommel Cana
    On your satellite receiver , how is it connected to your TV?, is it from the RF ant IN or from the TV
    AV ( Audio-Video ) Input , and what kind of cable have you used?
  • Rommel Cana
    thanks for the info,
    more details on page 26 of the manual
    some of it,
    Surround >>>>on / off , set it to Off
  • Rommel Cana
    it might cost you more ,( Main Board ) than if you have an AV receiver
    But AV receiver is more costly if you do not have one,
    do you have other stereo amplifier in there?
    Or can you be able to open the unit ? to be precise on what to check for?
    A simple computer speaker can do the trick , by connecting it on your TV headphones
    jack , more cheaper than the solutions above
    ( Only if you can hear sound on your headphones )
  • Rommel Cana
    here are the details for the possible board:
  • Rommel Cana
  • Rommel Cana
    Before ordering anything :
    here are sample troubleshooting:
    a ) Start with the input , then to the op-amp IC. b ) check your cable like those above for co
    these may not be exactly like yours, but the process in troubleshooting is the same.
    you may need a multimeter
    need to measure voltages on the speaker terminal, referencing the chassis as the ground
    ( meaning negative of your multimeter ) and post voltages on it.
  • Rommel Cana
    Post voltages ( speaker terminal ) when:
    a) speaker is connected
    b ) speaker is disconnected ( one terminal only )
    Post voltages on the SP ( speaker out to your speaker )
    a ) when it is connected ( speaker )
    b ) when one terminal is disconnected
    Output of SP have two ( 2 ) terminals on each
    you may have to measure each output separately
    Connect ( or clip ) the negative probe of your multimeter ( set to Volts ) on the chassis
    when measuring for voltages
    and keep one hand in your pocket
  • Rommel Cana
    please check if these board looks like yours:
    http://cgi.ebay.com/275551-MAIN-UNIT-40-...
RCA 32 Smart Tv SLD32A30RQ Will turn but nothing happens and has a blank screen.
It sounds like the internal calendar function is working perfectly.
Nov 12, 2015 | RCA Televison & Video
Hi I have a RCA Model L32HD31YX12 tv and cannot find the code to set up on a universal remote.
You might try this, worked for my Comcast remotes:
Code for Comcast Remote Control is 13183
Code for Voice Control Remote Control is 12292, however when you go thru the automated process of programming your TV you need to select TCL as your TV brand. Do not select RCA for Voice Control Remotes.
Aug 17, 2015 | RCA Televison & Video
Rca l32hd31yx12
How is the TV hooked up to the sound par?
Nov 21, 2013 | Televison & Video
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
HI, I have a RCA Model: L32HD31YX12 TV and when i plug the power and cable into it all I get is a black screen. The green light at the bottom of the TV is on but I'm not sure what to do. Also I do not have...
I have an RCA LCD TV Model#:L32hd31yx12. I have an issue with the settings staying in place when I shut it off then turn it back on I have to reset everything. Is there an update for the firmware for this particular tv???
Dec 26, 2010 | Televison & Video
I've had a rca model l32hd31yx12 and recently began to get white vertical lines after a minute they fade but certain screen changes like volume adjustments and the lines come back and fade again same thing...
Sounds like the power supply has filtering issues, in other words bad capacitors. its best to have a tv shop take a look at it. they shouldn't charge you. good luck
Nov 06, 2010 | RCA L32HD31 32 in. LCD HDTV
32'' RCA L32HD31YX12 Picture went out
Hi friend,,,
welcome to fixya
Commonly for RCA tv's if the screen went out,,the problem will be the CATHODE RAY TUBE,it is costly to buy.if you want you can buy it,,or it may be the D-board problem will be also,,,
but it is unusual,so check the tube.
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Televison & Video
Olevia
You should check to see if the sound is really coming from the TV- you may have the sound from the directTV cable box composite audio red and white RCA connectors.
Try connecting from the audio out of the TV to the stereo
Try the menu and see if you can adjust vertical and horizontal hold.
unplug tv for 10 minutes - tehn try again.
change battery in remote, if the remote does not seem to work
good luck
Oct 26, 2008 | Televison & Video
No picture
When our tv does this,it seems like it's warming up. Sometimes it will eventually come on. Sometimes not. We discovered by accident that turning the floor fan on it (towards the back) helps.I didn't think it was that dusty back there, yet it seems to make a difference.
Sep 09, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA L32HD31 32 in. LCD HDTV Logo
218 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
