Question about Kenmore 88752 Top Load Stacked Washer / Dryer
Kenmore washer/dryer combo
The dryer is turning but is not heating. Would that be the heating element? Dryer is about 4 years old.
  • 3 more comments
  • SeannyB May 30, 2008
    Sorry it is electric.
    No heat at all. I let it run for all 30min(watching the kids) but air is moving freely...just completly cold air.
  • PLEmonjello Oct 09, 2008
    Same problem-dryer turns, but no heat on any cycle. What's the easiest way to access the fuse, theromstat(s), and heating coil? Can I remove the cover on the very top of the dryer, or does it need to be pulled out from the wall and accessed from the back? Thanks for you help!
  • Buck Whyte
    Buck Whyte May 11, 2010
    No heat can be many things.. there are sensors that can overload to keep it from heating to it being something as simple as the vent being plugged and overheating the element making it shut down.. if it has not been running.. turn it on timed dry and set it on cotton high with a dry towel in it.. set it for 30 mins and let it run for about 10.. check the towel and also the dryer vent if you can get to it.. see if there is any heat at all, and let me know.. we can go from there...
  • Buck Whyte
    Is it electric or gas?
  • 46 Answers
I Can give you a few things to check if your mechanically inclined, but if you dont feel comfortable digging into the machine I would suggest a technician visit..   if you feel like digging into it send me an email at bigtexan1000@yahoo.com and we can begin
Posted on May 30, 2008
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Newer kenmore dryer does not heat , element has continuity
Check the thermal cut-off located on the heating housing. check for continuity on that.
Jul 03, 2009 | Kenmore 73952 Gas Dryer
Kenmore Dryer won't heat up
thermal fuse is bad. replace fuse. clean out vent duct. thermal fuse usually blows when there is restricted air flow over heating element.
Jun 24, 2009 | Dryers
Dryer no longer has heat to dry clothes
The element gets brittle and breaks. The element is in the rear of the dryer under the dustcover.
May 06, 2009 | Kenmore Dryers
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
My Kenmore Dryer turns on and then goes off on it's own
by the time you purchase a part it would be almost half of what a new one would cost. Check for any clogs that may be in a drain and try playing with the dryer door latch. These things could also cause this problem. But a 12 year old washer could just be a motor wearing out from age.
Feb 11, 2009 | Kenmore 62602 Electric Dryer
My Kenmore Elite Electic dryer mod #11063012101
OK .. on your dryer it does have a bi-metal switch that turns on and off the element....if your dryer produces heat... nothing wrong with element.. a thermostat w/wire sensor is the only way to check for your heat if its working correctly.. the other is to check if your clothes coming out of your washer is it wetter then before.. might need to spin one more time.. good luck..
Jan 13, 2009 | Kenmore 62602 Electric Dryer
Dryer no longer heats up on my Kenmore 417.94812301 laundry stacked unit
On your dryer the common problems found is either you lost some of your electrical power (check your fuse box) or you need a new heater #131475300 about $100 for the part.
Jul 28, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elec Dryer Won't Heat up
Sounds like either a faulty thermostat or heating element. Both are accessed from the lower right backside of the dryer behind a metal door. Be CAUTIOUS, the edges can be sharp and cut you very easily. Good luck.
Mar 23, 2008 | Kenmore 65924 Electric Dryer
Kenmore 88752 Top Load Stacked Washer / Dryer Logo
254 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
