Question about Fisher and Paykel DEGX1 Electric Dryer
Where is the element case that houses the high/limit cycle switch?
  • 32 Answers
Go here and get the parts manual, http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ . you will find the break down of what you are looking for.
Posted on Oct 15, 2010
Model RES 7646KQZ Drum turns, heat comes on, timer works, shuts off after 2-3 minutes.
either the high limit thermostat switch on the element case is weak or the cycling thermostat switch on the dryer blower housing is weak you can bypass both to test but dont leave them this way after youve found the bad component
Jun 05, 2011 | Roper RES7646KQ Electric Dryer
No a kenmore 80 series dryer will not heat . if the heating elment is good & fuse is good what else could be the problem
The heating circuit is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The problem is very likely in the thermal cut-off and the high-limit thermostat located on the blower housing. The thermal cut-off blows when the high-limit thermostat fails and cuts power to the heating element. Both the thermal cut-off and the high-limit thermostat need to be replaced if the former is blown open. Click on the link below for the detailed instructions in troubleshooting this kind of problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Mar 09, 2011 | Kenmore Elite HE3 Steam 8676 Dryer
I have been asked (Im an HVAC technician) to look at three commercial Maytag MDE16csayu elect. dryers that the apt. mang. says "dont work". Just looking for a place to start. I know to check the...
check the belt switch by the motor if it wont start,also the thermal fuse on the blower housing,if the motor turns the drum,but no heat,then the element,high limit thermostat on the element case can be suspect,or the heat cycling ther5mostat on the blower housing and again the thermal fuse located there also can be suspect
Mar 03, 2011 | Maytag MDE16CS Electric Dryer
I DONT UNDERSTAND WHY TWO THERMAL SWITCH ON HEATING ELEMENT HOUSING THEN TWO MORE ON BLOWER HOUSING AINT THAT OVER KILL BOB NELSON THANKS
Safety is the main concern but they do have different functions. The two that you mention on the blower housing, the the inch long slender one is a thermal fuse but it is wired in series with the drive motor. The other one on the blower housing is actually a thermistor which monitors exhaust temperature which the computer the uses to cycle the heater relay on and off. Now the two on the heater element housing, One is a high limit thermostat which is normally closed till about 295 degrees ,the other is the thermal cut out set to open at about 350 degrees in case the high limit fails. The system is not as redundant as it may first appear they each have their own special functions
Hope this Helps Have a great Day
Oct 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
The high limit thermal switch on heater burns out.
There are two thermostats, a 'limit' or 'operating' thermostat which turns the heating element on and off, and a 'high limit' or 'safety' thermostat which oversees the 'operating' thermostat by opening and removing power to the heating element when the upper limit temperature is reached. Basically, the only difference between these two are the temperature ratings. The 'high limit' is higher than the 'operating' thermostat. The thermal fuse is the last resort protection.
First and foremost, you must know that every inch of your exhaust vent pipe is clean.
Usually, a bimetallic limit switch will degenerate in the direction of too low of a temperature range because as the parts wear out inside, the mechanical tolerance widens (the tiny rod that pushes the contacts together gets shorter).
The high limit thermostat is by the thermal fuse. The operating thermostat is in the blower housing.
Check the fan impeller for broken vanes and lint. The impeller is directly coupled to the motor and should not turn without the motor. The fan housing and ducting should be free of excess lint.
Good luck.
May 02, 2010 | Samsung DV316LES Electric Dryer
Dryer will not produce heat to dry clothes
you first need to access the heating element case and with a multi-meter check the element for 50-250 ohms,then the hi-limit switch and cycling switch on this case,then on the dryer exhaust vent housing theres a thermal-fuse,check this for continuity all components will check 0 or near 0 ohms=good/infinity,no reading=bad/except the element and the above is just an approximation as each element has its own resistance
Mar 19, 2010 | Kenmore 800 6983 Electric Dryer
Wont turn on changed thurmal fuse. worked one load than blew agin.
if your machine is running extremely hot,check for proper exhaust from element housing thru blower wheel housing all the way to the outside vent pipe,any lint will impede air flow and can cause this condition,then replace the dryer cycling switch as it may be getting erratic and not cycling when dryer is hot enough it is located on the element case along with the hi-limit thermostat,replace them both
Jan 25, 2010 | Kenmore 62802 Electric Dryer
I'd like to know how to change a heating element in my dryer (29' whirlpool) I'd like to know exactly how to take it apart and where to find the element. I'am not sure of the dryer #
first you nead to unplug the dryer,next you nead to remove the vent hose,next you nead to remove the back panal and the power cord cover,on the left side you will see the heater housing,at the bottom you will see the heating element,there are four wires,the two at the bottom are hooked to the element,you nead to pull them off,the other two wires are hooked to the high limit switch,you nead to pull them off,next there are two 1/4"screws,one on each side off the heating element,remove them,now pull out on the bottom of element,with element removed,remove the high limit switch from old element and put it on the new element,take new element and put it back in the heater housing and replace the two 1/4" screws,you will see that the two wires that go to the element are biger than the two going to the high limit switch,put the two wires to the element,now replace the two wires to the high limit switch,replace the back panal and the power cord cover,replace the vent hose,plug power cord in and check element out.
Nov 25, 2009 | Whirlpool LER5636P Electric Dryer
Hi, I have a electric LG DLE2516W dryer, that runs, but does not heat, here's what i've been able to determine: 1. verified ac 240vac to terminal back of dryer 2. vent clear, blowing only cold air 3. ...
Sure, looks like the high limit is your problem, but why did it fail? If your vent is good as you say, the dryer should cycle on the operating thermo (thermistor sensor in this case), and the high limit should never trip. I'd replace the 6323EL2001B thermistor too (back side of the blower housing), along with the 6931EL3003D and the 6931EL3001E which are mounted on the element assembly. Non heating issues can also be caused by a bad relay on the board or a bad centrifical switch in the motor.
Oct 05, 2008 | Dryers
Fisher and Paykel DEGX1 Electric Dryer Logo
54 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Virgil Watts
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
