Question about Dryers
Where is the belt housing located - Dryers
You have to take the front of the dyer a part frist unplug it; and the belt is located around the drum.
Posted on Oct 09, 2010
Looking for belt drive 2042 rail sprockets
Notes on replacing drive sprocket on Genie 2042 belt drive garage door opener.
The unit originally came with a cast metal sprocket disk with a plastic sleeve insert that formed the sprockets themselves. The plastic insert's sprockets shattered when I tried opening the garage door that had frozen shut with ice. Genie's service assistant was of no help, as she suggested that I remove the entire rail then call them back. Removal of the rail was totally unnecessary. I purchased an all metal sprocket designed for the 2042 from an on-line supplier. Neither the owner's manual nor on-line instructions were available to assist me. I followed these steps:
    1.With the door open, loosen the tension on the belt by turning the bolt in the tension assembly located on the rail opposite side of the motor. Slide the belt off the pulley and let the belt hang.
    2.The sprocket housing is located on top of the motor. Unscrew the two Phillips screws that hold the sprocket housing onto the motor assembly.
    3.Using a screwdriver, force the cover up. The cover is on a hinge-like appendage that is riveted onto the rail frame. With the housing pried up, the belt and sprocket can be seen.
    4.Pull the belt out of the housing to allow the old sprocket to be removed. Be careful to locate the black plastic bushing/spacer on top of the old sprocket and save it for the new sprocket.
    5.Install the new sprocket and bushing/spacer into the motor shaft along with the belt.
    6.Replace the two Phillips screws on the sprocket cover.
    7.Place the belt back on the tension assembly and tighten to manufacturer's specifications.
    8.If the motor won't run from the wall switch, the up/down limits need to be reset. The motor will move the garage door up and down using the control buttons on the bottom of the motor unit. Follow the manufacturer's instructions on setting the up/down limits, which include holding the "set" buttons for over 5 seconds once the garage door is in the desired up and down locations.
Mar 29, 2013 | Home Security
Replace water pump 1995 aurora
Water Pump REMOVAL & INSTALLATION 3.5L Engine
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Partially drain the cooling system.
  3. Remove or disconnect the following:
    • Water pump pulley bolts, loosen but do not remove at this time
    • Drive belt
    • Idler pulley
    • Water pump pulley
    NOTE: The water pump is attached to the engine with both long and short bolts, be sure to note their locations.
    • Water pump and discard the gasket
    NOTE: Note the locations of the 5 long bolts.
  4. Clean the water pump mounting surface. Fig. 1: Be sure to install the 5 long water pump bolts in the correct locations - 3.5L engine 9300z502.gif
    Fig. 2: Water pump mounting - 3.5L engine 9300z503.gif
    To install: NOTE: Be sure to install the 5 long bolts in the proper locations.
  5. Install or connect the following:
    • Water pump using a new gasket. Torque the bolts to 124 inch lbs. (14 Nm).
    • Water pump pulley
    • Idler pulley. Torque the bolt to 37 ft. lbs. (50 Nm).
    • Drive belt
  6. Refill the cooling system.
  7. Start the engine and check for leaks.
3.8L Engines
  2. Disconnect the negative battery cable.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • Serpentine belt
    • Heater and bypass hoses from the water pump
    • Water pump pulley
    NOTE: The long bolt can be removed by aligning the bolt head with the frame rail hole.
  5. Install an engine support fixture.
  6. Remove or disconnect the following:
    • Torque axis mount
    To install: Fig. 3: Exploded view of the water pump and mounting bolt locations - 3.8L engines 7922xg01.gif
  7. Thoroughly clean all the sealing surfaces.
  8. Apply a thin bead of sealer around the outside edge of the water pump
  9. Install or connect the following:
    • New gasket
    • Water pump. Torque the inlet and outlet side bolts to 29 ft. lbs. (39 Nm) and the remaining bolts to 97 inch lbs. (11 Nm).
    • Torque axis mount
  10. Remove the support fixture.
  11. Install or connect the following:
    • Water pump pulley
    • Water pump hoses
    • Serpentine belt
    • Water pump pulley bolts. Torque the bolts to 115 inch lbs. (13 Nm).
    • Negative battery cable
  12. Refill the cooling system.
  13. Start the vehicle and check for proper operation.
4.0L Engine
    • Air inlet duct
    • Water pump drive belt cover
    • Lower radiator hose and bypass hose
    • Thermostat housing from the water pump housing
    • Water pump from the water pump housing, by turning the locking ring with a Water Pump Remover/Installer tool J-38816
    To install: Fig. 4: Exploded view of the water pump housing and water pump - 4.0L engine 7922xg02.gif
    • Water pump, seat the locking ring
    • Thermostat housing to the water pump housing
    • Lower radiator hose and coolant bypass hose
    • Drive belt and drive belt cover
    • Air inlet duct
  6. Refill and bleed the cooling system.
Jan 24, 2011 | 1995 Oldsmobile Aurora
Need location of thermostate
Removal & Installation 3.9L, 5.2L & 5.9L Engines To Remove:
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Support bracket located near rear of alternator (A/C Vehicles) dod_trk_releasebelttension.gif
    • Alternator drive belt by attaching a wrench to the pulley mounting bolt of the automatic tensioner, rotating the tensioner clockwise to release belt tension, and removing the belt:
    • Alternator mounting bolts, but do not remove any wiring at alternator
    • 4WD indicator lamp wiring harness (4WD vehicles)
    • Alternator and position aside WARNING
      When servicing constant tension hose clamps, use only tools designed for servicing this type of clamp, such as special clamp tool (number 6094). Always wear safety glasses when servicing constant tension clamps. Always replace constant tension clamps with the same numbered clamp.
    • Radiator hose clamp and upper radiator hose at thermostat housing and position wiring harness aside to gain access to thermostat dod_trk_59l_thermostat.gif
    • Thermostat housing mounting bolts, thermostat housing, gasket and thermostat
To Install:
  1. Clean intake manifold and thermostat housing mating surfaces.
  2. Install or connect the following:
    • Thermostat (spring side down) into recessed machined groove on intake manifold
    • Gasket on intake manifold and over thermostat dod_trk_thermohousingposition.gif
    • Thermostat housing to intake manifold NOTE: The word FRONT is stamped on housing and must be placed towards front of vehicle.
    • Housing-to-intake manifold bolts.
      1. Torque to: 200 inch lbs. (23 Nm)
    • Alternator (A/C Vehicles)
      1. Torque to: 30 ft. lbs. (41 Nm)
    • Support bracket
      1. Torque to: 40 ft. lbs. (54 Nm)
    • Drive belt over all pulleys except idler pulley
    • Socket/wrench to pulley mounting bolt of automatic tensioner and rotate clockwise
    • Belt over idler pulley, let tensioner rotate back into place and remove wrench
    • Coolant
  3. Start and warm the engine and check for leaks.
4.7L Engine To Remove:
    • Coolant
  3. Safely raise and support the vehicle.
    • Splash shield
    • Lower radiator hose clamp and lower radiator hose at thermostat housing 4.7L engine shown 3.7L similar chry_47_thermostst.gif
    • Thermostat housing mounting bolts, thermostat housing and thermostat
To Install:
  1. Clean timing chain cover and thermostat housing mating surfaces.
    • Thermostat (spring side down) into recessed machined groove on timing chain cover
    • Thermostat housing on timing chain cover
    • Housing-to-timing chain cover bolts.
      1. Torque to: 112 inch lbs. (13 Nm)
    • Lower radiator hose on thermostat housing
    • Splash shield
  3. Lower vehicle.
  4. Fill cooling system.
  5. Connect negative battery cable to battery.
  6. Start the engine and check for leaks.
Aug 26, 2010 | 2001 Dodge Durango
Location of knock sensor 3.2 1996 acura tl
remove the intake manifold ,remove radiator ,remove radiator intake and outake housing, remove fan ,remove all belts: power steering, alternator and if you have a/c, remove harmonic balancer ,remove timing belt covers, remove timing belt remove intake housinng once you have remove all the above, your freaken engine will look naked, you can see the location of the knock sensor is locate in the engine valley
Jan 21, 2010 | 1996 Acura TL Series
Need to locate rear knock sensor on 2004 gmc sierra1500 4.8 litre
Jan 19, 2010 | 2004 GMC Sierra
Where is the knock sensor located? 2000 Toyota camry 4cyl
Jan 11, 2010 | 2000 Toyota Camry
Knock sensor location 08 accord
Dec 31, 2009 | 2008 Honda Accord
Just needed to know ware the thormostat is located ?
if it has the V6 it located at the front of the engine behind the timing belt cover.
if it is the 4 cyl it is located under the front part of the intake manifold.
either way the lower radiator hose is hooked up to the housing were the thermostat is housed.
Dec 08, 2009 | 1993 Nissan Pickup
How do I replace and located the thermastat of my 96 Audi A4, 2.8L
The thermostat is located in the engine block just to the side of the water pump underneath the housing where the upper radiator hose is attached.
  1. Remove the lower engine shield.
  2. Place a large drain pan under the vehicle to collect the coolant.
  3. Remove the radiator cap and drain the cooling system into a suitable container.
  4. Place a large drain pan under the engine block drain located at the bottom of the engine near the vicinity of the flywheel and the oil pan.
  5. Drain the engine block coolant into a suitable container.
  6. Place the (hood) lock carrier in the "service position". For additional information, please refer to the following topic(s): Body And Trim, Service Position, Front Bumper, Hood Lock Carrier.
  7. Remove the accessory drive belt. For additional information, please refer to the following topic(s): General Information And Maintenance, Routing Maintenance And Tune-Up.
  8. If installed, remove the upper front engine cover.
  9. Remove the toothed camshaft drive belt from the right side cylinder head to allow enough access to remove the thermostat housing. Cover and protect the drive belt from residual coolant.
  10. Remove the mounting fasteners; remove the housing, then the thermostat.
0900c152800c2b1e.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. An exploded view of the water pump, thermostat housing and thermostat-2.8L V6 engines
0900c152800c2c46.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Lubricate the O-ring with coolant and make sure the thermostat is installed with the bleeder facing up-2.8L V6 engines
To install:
WARNING The thermostat vent valve must be installed facing up otherwise the cooling system may develop air pockets and allow the engine to overheat.
  1. Using new O-ring, install the thermostat making sure the vent valve is installed facing up.
  2. Install the thermostat housing and torque the housing the bolts to 88 inch lbs. (10 Nm).
  3. Inspect the camshaft drive belt for wear and damage and replace if necessary. If contaminated with fluids or lubricants, it should be replaced. For additional information, please refer to the following topic(s): General Information And Maintenance, Routine Maintenance And Tune-Up, Engine And Engine Overhaul, Timing Belt And Sprockets.
  4. Installation is in reverse order of removal noting the following:
Jul 09, 2009 | 1996 Audi A4
Changing my Belt
There should be 2 or 3 screw on the top housing, if not there, then they are on the bottom. Remove those screws, then the top housing comes off and the belt and brushroll are in the open.Part # 61120A long life belt. Brush roll #62365-2 if needed.
Dec 16, 2007 | Vacuums
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
