Question about Hayward Northstar Pool Pump 2 Hp Sp4020ns
The system does not turn on, then when i reset circuit breakers, whines for about ten seconds and turns off
  • 44 Answers
Your motor has shorted out and needs to be replaced
Posted on Oct 09, 2010
Outside unit turns on and runs for a long time by itself then shuts off. Does this all day an night long. Notice this after a circuit breaker tripped. Not breaker to unit though. Other parts of house.
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need any other Air Conditioning Repair help. Check us out online.
Jul 25, 2016 | Celiera Celi 24000 BTU Ductless Mini Split...
Dishwasher reset button
Hi friend, I appreciate your post!
I understand you are trying to locate a reset button on your dishwasher FDB1502RGC0. Generally dishwashers do not have a reset button on them but in order to reset your appliance as a whole. You would disconnect power to it by unplugging it or turning off the household circuit breaker for ten minutes and turning it back on. Hope this helps. -Matt
Jul 23, 2014 | Frigidaire Dishwashers
How do u reset kelvinator reverse cycle airconditioning system
Ok first there should be a switch on the wall near the Condensing unit this is the unit outside Switch off for 10 sec and then back on if cant locate switch just switch circuit breaker labeled with Ac or just switch main circuit breaker off for ten seconds
Jul 15, 2014 | Heating & Cooling
Door will not unlock
Hello Susan, thank you for your post!
Try pressing and hold OPTIONS and SELECT at the same time for approximately ten to twenty seconds to unlock the washer. If it proves to be ineffective, reset the unit by unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn your washer on. If issue continues, then I personally recommend consulting a professional to move forward accurately. The washer could possibly be experiencing a communication error with the control board, faulty door lock assembly/strike or a potential wiring failure.
Sep 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
ERROR CODE "OF"
Hello V - Generally, OF means that the unit is turn off. Try resetting the freezer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. Set the unit to ON, by pressing and holding the Power button for approximately ten seconds. If issue persists and unit does not turn on, then the refrigerator may be experiencing a potential wiring failure, faulty temperature control, or control board. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Jun 25, 2013 | Frigidaire : FFHS2313LS 33" 22.6 Cu. Ft....
Dishwasher heating element won't turn off
Hello niki4god - I recommend resetting the dishwasher by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on the unit. An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the control board or a potential wiring failure.
Jun 20, 2013 | Frigidaire 24 in. FDB635RF Built-in...
Can't get freezer to reset model number LFFH17HWC serial numberWB93766371
Hello richardso903 - Once again try resetting the freezer by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart the unit. Set the unit to ON, by pressing and holding the Power button for approximately ten seconds. If issue persists and freezer does not turn on, then the unit may be experiencing a wiring failure, faulty plug or control board. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
Mar 30, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
1996 harley 883 headlight flickers off real quick every minute or so with a clicking sound and my front and rear blinkers are dead. I turned it off and pulled out the key and it still made the clicking...
You have a short in your electrical system somewhere that is causing your circuit breaker to trip. Harley uses automatic reset circuit breakers rather than fuses. If you get a short in your system somewhere, the current though the circuit breaker will cause it to trip. After a minute or so, the circuit breaker's bi-metal strip inside will cool and the circuit breaker will reset. If the short circuit still exist, the breaker will again trip.
To help find the source of the problem, you must determine which circuit breaker is tripping. In this case it sounds like the "lights" circuit breaker. Since your turn signals are on that circuit and they are not working, I'd start there to look for the reason.
When you turned off the key and it made the clicking noise again, this was probably the circuit breaker resetting itself after you removed the voltage and current flow through it by turning the switch off.
Good Luck
Steve
Jan 04, 2011 | 2000 Harley Davidson XL 1200 S Sportster...
Flowtron Leaf-Eater Mulcher LE-900F
Shot in the dark here. If the mulcher is tripping and needs to turned off then back on, it's defective and should be replaced. If the circuit breaker in your house panel is tripping, try to use different circuit on a 20 amp circuit breaker. If your using a plug that is controlled by a GFCI receptacle or breaker, move to a different plug. GFCI receptacles tend trip when motor loads are applied. These are my best guesses since I'm not sure what exactly you are reseting.
Apr 25, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
Audiovox AVT2540 won't turn on
The only possible check that could be done without removing/opening the Audiovox TV would be to check for the presence/absence of supply power/voltage depending on how the TV is powered (12VDC or 120 VAC). Normally, there would be an fuse and/or circuit breakers.for the RV's entertainment system including the TV.
The 120-volt circuit breakers and 12-volt fuses are located in the same compartment. These devices interrupt the power if the circuit is overloaded.The 120-volt circuit breakers include a 30 amp main breaker and several smaller breakers for individual circuits. If a circuit breaker is tripped, look for an overload on the circuit, then reset it by turning the breaker OFF and then turning it ON. Do not try to reset a breaker the second time without locating the overload problem. The 12-volt fuses protect individual circuits. If the circuit is overloaded, it will blow the fuse and the fuse must be replaced. Check the circuit for an overload and replace the fuse with the same type or amperage rating.
If the above checks out, then problem is internal to the unit and would require removal from its current position.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 23, 2008 | Televison & Video
Hayward Northstar Pool Pump 2 Hp Sp4020ns Logo
110 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
