Question about HP Pavilion dv4000 Notebook
I turn the notebook on and i have power but nothing comes up on the screen. it is a hp pavillion dv4000 im not very educated on computers but if u guide me through im sure i can do it.......thans for the help...
  • 734 Answers
Hi There,
Your laptop needs some troubleshooting and here's the fastest (and free) way to locate your issue. Get to a friend's place (or at home) where there's a regular desktop computer monitor and connect your laptop to it. Look up at the top row of "F" keys (1 thru 12) and find the one that looks like it has to do with a monitor. With your laptop connected to the external monitor, press the "fn" key in the lower left of keyboard and hold it doen while your press the monitor transfer F key above.
If your laptop's normal display shows on the big monitor, then you just have a bad sceen that needs replacement. If all is dark on both, then your video card inside the laptop has faild and a new motherboard is needed.
Kind Regards,
TheSelkie
Posted on Oct 09, 2010
My HP Pavillion DV6000 laptop starts up fine and after a few minutes the screen turns black. I can still see the desktop image in the background but barely. If I reboot the screen looks normal again but...
That means your backlight is going out. The fact that it's happening intermittently like that suggests that you have a faulty screen inverter (a small circuit behind the screen that converts DC power to AC, in order to light the florescent backlight).
I suggest replacing it. Here are some on abay for pretty cheap:
http://shop.ebay.com/i.html?_trkparms=65%253A12%257C66%253A2%257C39%253A1%257C72%253A2608&_nkw=Pavilion+dv4000+inverter&_ipg=&_sticky=1&_trksid=p3286.c0.m14&_sop=15&_sc=1
Mar 24, 2010 | HP Pavilion dv4000 Notebook
HP Pavillion DV4000 notebook display shading
It sounds very much like an inverter issue. The inverter sits under the lcd screen in the screen plastics. It is replaceable, but obviously there is a danger the screen may get damaged.
Nov 21, 2009 | HP Computers & Internet
I cannot pair my HP Pavillion dv4000 Notebook and
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your device. Choose the headset, and then at the next page, choose your device. Moving your mouse over each step will change the picture to what you should be seeing at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 29, 2009 | HP Pavilion dv4000 Notebook
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Hp dv4000 screen turned pink now black
If its not the backlight inverter or cable. It will be the LCD screen itself. It seems the shop you took it to isn't really up on laptop repair, as this is a common issue I see often. Get on Ebay and find a screen for your model and replace it. I asure you this will fix your problem.
May 19, 2009 | HP Pavilion dv4000 Notebook
HP Pavillion dv4000 cto won't start
Hey,
if the computer doesn't beep at all, and noting comes on the screen.
Lets do this first,
Remote the ram from the computer, start up without ram.
turn the laptop off and unplug, did you hear beeps?
Place the other memory module back in and try starting up.
if the computer starts up then all is ok you can plug in the other ram and start up again. if it doesn't start up then repeat the previous process.
if this has no effect and you don't get any beeps from the computer the motherboard most likely has a problem.
I would suggest you call hp or your dealer to check your warranty.
If you are outside of warranty the repairs will cost you.
Discuss repairs with hp and see if its worth it.
Let me know if you need anything else.
Thanks,
Ekse
Feb 16, 2009 | HP Pavilion dv4000 Notebook
Faulty Connection
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Jan 05, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 display dies b4 it even boots
When you get to the normal/safe mode screen, select enable VGA. This will boot your computer using the standard 640 x 480 default. Once you are in windows, then you can go into the display properties and change it to a resolution that is compatible with your screen and computer.
Thanks and pelase take a moment to rate as fixya.
Nov 08, 2008 | HP Pavilion dv4000 Notebook
HP Pavillion dv4000 turns on and shuts off and turns on and shuts off -
No I work on HP's all day, it is nothing to do with the OS or the BIOS. It is a problem with the motherboard fan control, in other words the mainboard is bad even with the latest BIOS update. The CPU is getting too hot, as this happens the CPU gets damaged because the Fox board does not have a temp sensor. So periodically the voltage make kick on the cpu but for the most part the computer will never work the same. The longest I got this dv4000 to run was just under 4 hours with no apps running.
Total overhaul replace board, processor, and possibly the fan.
~Hope this answers your question.
Apr 08, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
