Question about Acer Aspire 5100 Notebook
MY ACER LAPTOP WILL NOT TAKE MY PASSWORD TO OPEN AND I DID NOT MAKE A PASSWORD CHANGE THAT THEY ASK FOR WHEN I SAY I FORGOT PASSWORD. I KNOW I HAVE NOT FORGOTTEN IT FOR I WROTE IT DOWN.
  • 146 Answers
SOURCE: acer aspire 3003lci forgotten bios password
you will need to disconnect the cmos battery for a few seconds to allow the bios settings to revert to default, reconnecting the cmos battery will allow you to boot up without a password, howver any changes which were made to bios settings will be lost....have you tried pressing f8 while booting, then selecting the option "last known good configuration" ?
Posted on Jan 05, 2008
oldnovii
  • 667 Answers
SOURCE: Forgotten Password
Good.
If that’s your only problem, then you probably have nothing to worry about. As long as you have your Windows XP CD, you can get back into your system using a simple but effective method made possible by a little known access hole in Windows XP.
This method is easy enough for newbies to follow – it doesn’t require using the Recovery Console or any complicated commands. And it’s free - I mention that because you can pay two hundred dollars for an emergency download of Winternals ERD with Locksmith which is a utility for unlocking lost Windows passwords. See here http://www.winternals.com/products/repai...
ERD is an excellent multi purpose product, but you should know it is not a necessary one if you have a healthy system and your sole problem is the inability to logon to Windows due to a forgotten password. Not necessary because you can easily change or wipe out your Administrator password for free during a Windows XP Repair. Here’s how with a step-by-step description of the initial Repair process included for newbie’s.
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set a new password.
Here's how to create one if your computer is NOT on a domain:
Go to the Control Panel and open up User Accounts.
Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
This will initiate a wizard.
Click Next and then insert a blank formatted floppy disk into your A: drive.
Click Next and enter your logon password in the password box.
Click Next to begin the creation of your Password disk.
Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything. This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and follow the wizard which will let you choose a new password to use for your account. Just in case your laptop isn't set to boot from cd, it probably is, you just have to go into the BIOS and make sure sure that the cd is is set to bootable and it is set to boot from cd before your hard drive. Try it with your Win XP cd first and if it doesn't work and you don't know how to go into the bios and set it, add another comment and I'll come back and tell you how to do that. This looks long and involved but it doesn't really take that long. Good Luck. If I helped out rate me a big 4 Fix Ya. Let me know how it turns out. Thanks for using Fix Ya.
Posted on Mar 15, 2008
sandrew
  • 2961 Answers
SOURCE: acer password/file decryption
that means your files have been encrypted by Acer management tools, so open up acer empower and the tools menu for encryption will be there, althogh this must have been enabled by someone in the first place.
Posted on Sep 15, 2008
tekguru
  • 68 Answers
SOURCE: solution to forgotten password
IF ITS WORKING ON XP .. THEN ALL THE LOGIN PAGE PRESS CTRL+ALT+DEL TWICE AND IN THE WINDOW THAT APPEARS TYPE ADMINISTRATOR AS USER NAME ... LEAVE THE PASSWORD BLANK TRY LOGGONG IN
rockitman187
  • 2559 Answers
SOURCE: forgotten password
I agree with Ekse
Posted on Jun 03, 2009
I forgot my acer aspire v11 touch password. I cannot use my laptop.
The easiest and most efficient method is using Windows 7 password recovery reset disk. iSeepassword Windows Password Recovery Pro allows you to create an all-new password restore disc to find Windows 7 password.
The article below tells you how to crack forgotten password in Windows 7 specifically.
https://www.iseepassword.com/forgot-my-acer-laptop-password.html
Feb 22, 2017 | Acer Computers & Internet
I forgot my power on password and i dont know my bios how can i reset password please help
is it windows password or BIOS password ?
which version, model and computer are you using ?
Jan 16, 2013 | Aspire Acer 7520-5071 Notebook
I can't go to my internet. It is bothering me with username &password what I forgot
I'm a bit confused, When you open Internet Explorer, What ask you for a username and password? OR , Is it the Laptop , at boot that's asking for a username and password? Or , wireless?
Jan 08, 2013 | Acer Computers & Internet
Reset my password on my acer laptop
If you know the current password then click Start/Control Panel/User Accounts. Under user accounts select change password.
If you forgot the password, turn off the laptop then turn it back on and repeatedly hit the F8 key until you see SAFE Mode. Select Safe Mode and let it boot up. You will see a login screen with the Administrator account and the Account of the id that you forgot the password. Select the Administrator account (hopefully it will not be password protected). One you are logged in click Start/Control Panel/User Accounts. Select the account for which you forgot the password and then select Remove Password. Reboot your laptop.
Mar 14, 2012 | Acer Computers & Internet
Hi I forgot my password and I cannot open my laptop acer travelmate 3200 the technician ask me the bios password which I also donot know. Hope you can help me thanks..\
Hi
Go onto another computer and download a copy of ERD Commander or ABF password recovery. Either of these will solve your problem. By the way a reputable repair person would have known this.
Jun 12, 2010 | Acer TravelMate 2502LM Notebook
Acer 7735Z, forgot the password, no guest, need to reset
open your laptop and remove the cmos battery to 5min. and then put the battery again and on restore the settings
Mar 25, 2010 | Computers & Internet
Anyone know how to unlock a locked bios on an Acer 5630? My wife forgot the password and now I can't log on. my newphew locked my acer how do i unlock it he changed the password and doesnt remember it
Reset the Bios by removing the small battery inside your laptop in few seconds. but you need to open your laptop if this under warranty don't open it to avoid broke the warranty bring your laptop to warranty if they ask you the payment for removing the password just pay them.. the inportant is the warranty still there.., if not under warranty open you laptop remove the battery or short it in few second to remove the Bios password.. if not Bios password. use the program password changer or password remover,, just donwload in ISOHUNT.COM program is available there..< program name> hirens, password changer...
May 26, 2009 | Acer Aspire 5630 Notebook
Cant open password
This should get you going...
http://home.eunet.no/pnordahl/ntpasswd/
May 21, 2009 | Acer Aspire 5315 Notebook
Acer password/file decryption
Sep 11, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5100 Notebook Logo
136 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
