Question about Roomba Robotic Floor Bagless Vacuum
My Roomba start for about 2 second and quit ? Battery fully charge
    Brigadier General:
  • 4,088 Answers
The battery may be fully charged, but it sounds as if the service life of the battery is done. If you could measure the battery voltage from turn on to quit, it would likely go from full voltage to near zero almost instantly. If you know someone else with one of these machines, try swapping batteries for a check. Good luck!
Posted on Oct 09, 2010
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . homesupport.irobot.com homesupport.irobot.com/.../roomba-600%2F500-battery-and-charging- overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. homesupport.irobot.com homesupport.irobot.com/app/answers/.../a.../roomba-700-anatomy LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... homesupport.irobot.com homesupport.irobot.com/ci/documents/.../042809_500MaintBatt_vib LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. homesupport.irobot.com homesupport.irobot.com/.../roomba-400-series%2Fdiscovery-battery-and- charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
Battery will not charge fully
Hello. I can assist you. You will have to take the steps to RESET the Roomba charging system. Here are the steps:
1. Remove the battery. 2. Hold down the power button for five full seconds. 3. Reinstall the battery. 4. Charge the battery until the power light is solid green AND then leave it on the charger for another 72 hours, yes 3 full days!
Here is a great link to the Roomba instructions and a video that shows you all of the steps I stated above.
Regards, Joe PS please rate my answer. Thank you and happy holidays.
Dec 23, 2009 | iRobot Roomba 4000 Bagless Robotic Vacuum
My roomba was not used for a month. Now it does
Hello
You can revive the dead nicd batteries in your tools.
There is a simple guide that can fix all nicd batteries in few minutes, available here.
Thanks
Nov 29, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Roomba stops running after 2 minutes
First drain the battery completely and then take out battery and charger and hold power button for 30 seconds and then clean the roomba with compressed air take out all compartments and blow air thoroughly everywhere especially near the wheels where the wheel sensors are. Leave battery to charge for full day and try to run.
Jan 31, 2009 | Roomba Robotic Floor Bagless Vacuum
ROOMBA 415
It could be the power button itself. If you have a Roomba remote, try using that to power on the robot.
Sep 28, 2008 | iRobot 4150 Roomba Vacuum
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba Robotic Floor Bagless Vacuum Logo
150 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
