Question about Casio fx-300ES Calculator
When i try and divide it just gives me the answer back as a fraction
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Posted on Oct 09, 2010
How do I simplify the fraction 3/2
just divide 3 by 2 and it gives you 1.5 which is the answer
Feb 09, 2015 | Casio Fraction Mate Calculator
How does dividing mixed numbers compare with dividing fractions?
This may not be what you want, but I turn the mixed number into a fraction. Say 5 1/2, you multiply the whole number (5) by the denominator for the fraction (2), then add the numerator. So you have 5X2+1. That is the new numerator, it goes over the denominator. This gives you 11/2. To check it divide the numerator by the denominator. 2 into 11 gives you 5 (Rem) 1. 1 is the numerator now and it goes over the denomerator. 5 1/2.
I know it sounds like a lot, but try about ten or so, it becomes 2nd nature. You can make it all into decimal, 5 1/2 becomes 5.5, but now you have to put more numbers into the equation.
This is true. I had a math teacher ask me if he had to cut down a tree so I'd have enough scratch paper.
Jan 26, 2015 | Office Equipment & Supplies
My hp50 calculator only will give me fractions like if I put in 50 enter divide 3 it answers with 50/3. Sometimes it gives me an actual number when I divide something, but usually it gives me fractions,...
Press MODE to bring up the mode screen. Press F3 to bring up the CAS screen. Use the cursor keys to move to the Numeric field. Press F3 if necessary to check it. Move to the Approx field and check this also if necessary. Press ENTER twice to save the changes.
Nov 03, 2011 | HP 50g Graphic Calculator
When I divide the answer is in fraction form not decimal form how do i get it back
There are two options.
1) Whenever you want the answer in decimal form, place a decimal after at least one of the numbers.
For example: instead of using (1/2) use (1/2.)
2) Press the "Mode" button. Scroll down the list that appears until you find "Exact/Approx". If you set it to "Approximate", then it will always give the answer in decimal form. If you set it to "Exact", it will give the answer in fraction form.
Nov 12, 2009 | Texas Instruments TI-89 Calculator
When I try to divide numbers that would leave a remainder like 1 divided by 6 which should give me an answer like 0.16666666666 instead all it says for an answer is 1/6. it does say in the manual to input...
To convert from fractions to decimals, and from decimals to fractions use the [S<-->D] key. If you want your decimal results to have a fixed number of decimal places press [SHIFT][SETUP][6:Fix]. Screen shows Fix 0~9. Enter the number of decimal places exemple 3.
Dans ce cas 1/6 is displayes ase 0.167.
Hope it helps.
Sep 23, 2009 | Casio FX-115ES Scientific Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
Mixed numbers
Proper fraction e.g. 3/5, input 3, divide, 5, =, answer 0.6
Improper fraction, either enter as improper fraction, or enter the whole number first, then +, then the proper fraction as before, then =.
E.g. 8/5 which is "1 and 3/5': enter 1, +, 3, "divide", 5 =, answer is 1.6
Or, just 8, "divide", 5, same 1.6 answer. Why go to mixed number first?
13/5 which is "2 and 3/5", enter 2, +, 3, "divide", 5, =, answer is 2.6. Or, just 13/5, same answer
Dec 17, 2008 | Texas Instruments TI-30XA Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Fraction problem
Go into MODE to the second page.  In Exact/Approximate, change it to Approx instead of Auto or Exact.  This will give you decimals instead of fractions.
Nov 17, 2007 | Texas Instruments TI-89 Calculator
Casio fx-300ES Calculator Logo
64 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
