Question about Pioneer DV-626D DVD Player
The dvd player won't play the disk it tries and then opens
  • 597 Answers
The problem is from the lens of the player, it is too weak and cannot read the disc that is inserted in it.
The solution is either for you to clean it with a lens cleaner or have the lens replaced.
Take care
Posted on Oct 09, 2010
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Dvd player reads no disk..even though the disk is in player, i want to watch the dvd i rented now. help
Some rented discs won't play becauses of scratches and dirt, if other DVD 'S work it is not your player, but if all won't play try a DVD cleaning kit and follow instructions.
Mar 17, 2012 | Sony Televison & Video
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
DVD on Curtis LD DVD 199A combo won't work in DVD mode. The DVD won't take or accept the DVD. I have never used the player before today. I did have the label to the back of the unit.
your dvd player wornt play the disk you are playing? Try to consult the region code of the player and the disk you are trying to play make sure they are of the same region..also clean the lens with a cotton buds moistened with an alcohol gently wipe it on the lens.post again if you have further question..
May 24, 2011 | Televison & Video
Mum tried to play computer disc in my all-in-one tv/dvd player!now it buzzes but won`t open...help?!
Unplug from wall and let the reset action take over. Replug and see if that will eject the disk
please leave feedback
Feb 21, 2011 | Televison & Video
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
Will not play disk comes up no disk
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 12, 2009 | Mintek MDP-1770 Portable DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Samsung DVD-4600 DVD/VCR Player
My Smasung DVD/VCR Combo stopped reading DVDs because of a dirty read head. It started by only playing disks sometimes, and progressed to never playing disks. I assumed it was a dirty laser lens so I bought a lens cleaner set. Unfortunately my player wouldn't play the cleaner disk.
So I took it apart and cleaned the laser lens manually with some isopropyl alcohol (the clenser that came with my cleaning disk), and a lens cloth (that came with my glasses). Just open the case (starting with the screws in the back) and remove the snap in cross panel that obscures the lens of the DVD portion. Put a drop of cleanser on the lens and gently wipe it with the cloth.
Oh and by the way, I take no responsibility if you break your own player while following my instructions. My own DVD player was far out of warranty at the time I cracked it open.
Aug 16, 2007 | Samsung DVD-V4600 DVD Player/VCR
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Pioneer DV-626D DVD Player Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
