Question about Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER
How to install a 3 way plug for stove - Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER
If I understand correctly, your stove plugs into the wall.
Your stove plug looks similar to one shown
Review wires inside wall.
There are 2 hot wires which are red and black
There is 1 neutral wire which is white
And there is a bare ground wire
Connect wires so they match image above.
2 hot wires, black and red go across from each other
White neutral connects to flat prong on top
Bare ground connects to round prong on bottom
Older wiring might not have both white and ground ... if you do not have both, then connect the wire you have to the flat prong on top
Posted on Oct 09, 2010
My whirlpool electric stove not turning on
Make sure it is plugged in and you have power to your house.If everything is dead check your fusebox for blown fuses if you have circuit breakers reset the breaker for the stove by turning it off then back on. If the burners on the top work,but the oven won't you probably have a burned out bake element .To change this turn off power to the stove and unplug remove 2 or 3 screws holding the bake element and remove the wires to the element by loosing the screws on the terminals note sometimes bake elements plug in in this case just unplug. Reverse process to install. Reapply power and test.
Aug 06, 2014 | Whirlpool Stove / Oven / Range Electric...
Shock from new stove when setting wet pan on burner. Stove not yet turned on. I was barefoot. 3 prong plug to 3 slot receptacle. Double pole 50 amp circuit breaker
Sounds like maybe the wall outlet has a bad ground pin in the connector. Can you plug the range into another outlet for a temporary test? If that solves it you can have the wall outlet replaced with a new one.
Hope this helps
Jun 29, 2011 | Kitchen Ranges
I just bought a used jbp82 and the plug does not fit the house plug in. Its a 3 prong and the stove is a 4 prong. Can this be worked out somehow?
You need to change the plug from the old stove to the new stove. It is easy to do. Black on right. white in center, and red on left. The 4th wire is the ground or green. You will not have that one to hook up.
Apr 10, 2011 | GE JBP82 Electric Kitchen Range
Im putting in new stove. i have 3 wire(6 gauge)
most stoves require a 4 wire plug..red, black, white and ground..the white is needed for the 110V to work properly..ground is there for safety incase something shorts out it will blow a fuse/trip circuit breaker
Sep 16, 2009 | Ovens
A friend gave us a jennair stove, the new stove has a four pin plug and our old stove had three. Can I change the plug on the stove or do I need to change the outlet in the house
Either works. Do what is easier. If you g with the 3 wire the white on the range has to be connected to the chassis as well as the terminal connector. Eric
Aug 10, 2009 | Jenn-Air JES9800BAS Electric Kitchen Range
Installed a new Tappan stove electric
check if there are links on the mains connector block and if so, make sure they are tight
Aug 10, 2008 | Tappan 30IN ELEC IGNa Oven
To install electric stove ...what is the recomended and required amps number
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=573502
Generic problem for all Kitchen Ranges
Posted by kukla61 on May 05, 2008
To install electric stove ...what is the recommended and required amps number
I would advise you to ALWAYS to FIRST UNPLUG YOUR APPLIANCE before beginning any service procedure.
Most of the electric ranges have either a 3 prong or a 4 prong gray electric cord that usually has a 220 plug, follow the color wires and match them to the wiring panel in back of the range. I am not sure on the amps, you may want to check with your local appliance dealer and also the customer’s owner’s manual, so check on the plug in the wall and then purchase the correct plug according to the number of prongs in the outlet and once installed level the range with the leveling legs. So if you need further assistance, please feel free to contact your local appliance dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. You did not give me a brand name or model # so check with the silver tag on the actual appliance and sometimes that will tell you the number of amps.
Thanks, Don – The Appliance Man
Go Ahead. Use Us.
May 05, 2008 | Kitchen Ranges
Jenn-Air 88370 drop-in stove, want to convert!
your old jennair is 220 should be three or 4 wires in it red for 1 side of the 220 black for the other side of the 220 white for the bottom of the outlet and if green is there you can hook it with the white wire or just not use it let me know if your colors are different
Feb 14, 2008 | Ovens
Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER Logo
770 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
