Question about Roper REX4634KQ Electric Dryer
Roper model red4440vq1 electric dryer heating but not spinning. belt is fine but looks like small wheel fell off
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
  • 163 Answers
SOURCE: My Roper Electric Dryer will not heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 26, 2008
TheMobilian
  • 8220 Answers
SOURCE: Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Posted on Jan 20, 2009
hiltonjug
  • 612 Answers
SOURCE: i have a rope model red4440vq1 electric
Find your breaker box, flip the breaker that goes to your dryer off and then back on. If this does not fix it, I would call where I bought it and have them repair it under warranty. What they will find is either a bad thermal fuse and or thermal cut off or a bad element. The dryer has a year warranty on it and if the place where I bought it will not repair it for free, I would contact Roper or Whirlpool because Whirlpool is who makes Roper and let them know that the people refuse to repair it. I don't believe you will have a problem. Good luck
Posted on Oct 22, 2009
marka19
  • 1430 Answers
SOURCE: Roper Dryer heats up but won't spin
The problem is likely the dryer belt . Go to www.appliancehelponline.com/servicemanual.html there is a video that will show you how to replace it. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available There is also videos to show you how to disassemble your dryer.
Posted on Apr 09, 2010
Roper dryer red4440vq1 not drying after changing internal fuse, internal bias, high limit thermostat and thermal cut off and cleaning vent, element heats up to temp and cycles
If heater is heating and not drying clothes, you have a blockage in ventilation system somewhere either internally in dryer or going out from dryer to outside. Take vent off back of dryer and turn on. Is air flow strong and hot?
Sep 15, 2017 | Roper Dryers
Roper RED4440VQ1 how do you know if high limit thermostat is broken?
you have to unplug the dryer,and remove at least one of the wires and read it out with a meter to check it for continuity.you can go here and see the parts you need to check,http://www.searspartsdirect.com/partsdirect/part-model/Roper-Parts/Dryer-Parts/Model-RED4440VQ1/0893/0151200/W0905172/00003?blt=06&prst=0&shdMod=RED4440VQ1
check the element,part number 17 on the diagram and is part 279838,if that's good check the thermostats on the heater box, part 9 and 15 on diagram,if one of them is bad buy part number 279816,it replaces both of them,also check the thermal fuse number 7 on the diagram and it's part 3392519.your lint filter is on top so all your parts are in the back,pull out the dryer,unplug it,remove the vent line and then the back panel,also take out the lint filter and the two phillips screws that are on the top panel and in front of the lint filter,when you're in the back,remove the 4 screws and clean out the metal duct that the filter slides into,if the vent line is a long run you can blow it out with a leaf blower,make sure nothing is blocking the air flow outside,if there's a cage or screen remove it so the lint doesn't build up and block the air flow.hope this helps and good luck.
Dec 19, 2012 | Whirlpool LER4634J Electric Dryer
I have a roper dryer model red4440vq1 and it want start
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 29, 2011 | Roper Dryers
My red4440vq1 does nothing
heatman101
Mar 15, 2011 | Roper REX4634KQ Electric Dryer
Have a rope model red4440vq1 electric dryer. it is about 5 months old. the the dryer is heating but not spinning
Aha Broken belt. You would need to get inside the machine to investigate the problema. If you were drying some big old tennis shoes that would knock the belt off. I have a pictorial on this with a manual and a nice video prepared by Repair Clinic HERE
Oct 08, 2010 | Roper REX4634KQ Electric Dryer
MY ROPER DRYER QUIT HEATING STILLS WORKS NO HEAT
The thermal cut-off , which is the small t-stat looking piece located at the top of the element housing ( on vertical mount elements ) or the far front of the element housing ( on horizontal mount elements ) , is usually the cause for no heat .
Aug 02, 2010 | Roper REX4634KQ Electric Dryer
Apr 09, 2010 | Roper REX4634KQ Electric Dryer
Jan 20, 2009 | Roper REX3614KW Electric Dryer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
213 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
