Question about Goldstar MV-1310W/B Microwave Oven
Model MV-1310B lights underneath microwave will not come on. Changed bulbs but still no light. Keypad pushed to low and high, still no lights. Any suggestions? ****
SOURCE: Hood lights
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
Posted on Sep 29, 2007
SOURCE: Hood lights
my microwave won't heat. I want to remove it and replace. How do I do this.
Posted on Jul 20, 2008
  • 4 Answers
SOURCE: Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Posted on Apr 03, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: I need to know what bulbs to buy for my microwave.
The manual is not showing the part number.
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Your best bet is to call them and ask. I think they'll have to look them up.
Posted on Jul 05, 2009
SOURCE: Switch for stovetop light on Goldstar over-the-range microwave
This is caused by a failure in the Sharp solid state relay "chip" (S201DH2). The newer pin-compatible versions don't seem to suffer this weakness. I used the R31HD2 (http://document.sharpsma.com/files/pr21hd22_e.pdf) which should still be available in the US for less than $10 delivered from Mouser or similar retail friendly parts houses.
A simple repair for someone with the tools and basic skills for removing and replacing a chip that is soldered to a printed circuit board. If you lack either of these, better to order a replacement board or have it serviced professionally.
Posted on Dec 07, 2009
Lights underneath will not turn off or to low
There maybe one or two bad door switches often caused by food partical build up.
Mar 16, 2012 | Goldstar MV-1310W/B Microwave Oven
Model Goldstar MS-71tc. when I plug the microwave in it on and the table spins and light inside is on as though it is microwaving something. But there is no heat being generated.I put something in to try...
The problem is in the magnetron "more likely" or the high voltage transformer that drives the magnetron. The cost to repair will run high in either case and come down to a personal choice, but! in the long run cheaper to buy new than to repair.
Jan 16, 2011 | Goldstar MV-1501 Microwave Oven
Goldstar microwave model mv-1310B problems, when turned on there is an unfamiliar hum and no heat being generated. Are parts available and is this type of problem frequent with this model?
in 99 % of cases the problem is the magnatron it is a very expensive part and unless the microwave is well worth the money we normally write the units off
sorry (
but i hope this helps
best of wishes
please remember to take the time to rank this reply .
Dec 08, 2010 | Goldstar MV-1310W/B Microwave Oven
I have a MV 1310B GOLDSTAR microwave. I can not get a 125v 30watt bulb to work. It call for a 40watt and I can not find one. Power is getting to the socket.
Unplug the microwave and try using a small pick to pull on the tab inside the socket a bit. Sometimes a replacement bulb like that is just a tiny bit shorter and will not make contact. Again, MAKE SURE IT IS UNPLUGGED FIRST!
Jan 26, 2010 | Microwave Ovens
Goldstar mircowave model 1310b parts manuel theres a plate at top of cooking area thats is burned two plastic pins hold it to top of mircowave need replacement, help curtis
Assuming that model is MV-1310B, that would be your stirrer fan cover, part number 3301W2A017A, which you can get from Encompass here or by calling toll-free at 866-779-5835.
If you need new clips / rivets for it, they are part number 4051W3A001A.
Jan 09, 2010 | Goldstar Microwave Ovens
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Goldstar microwave oven stop heating
microwave ovens have a special Magntron fuse that is inside the body of the microwave its much bigger than a normal fuse, if its blown the microwave wont work.
Jul 30, 2017 | Goldstar Microwave Ovens
Cooktop light - night light only
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 30, 2007 | GE JVM1650 1000 Watts Microwave Oven
Hood lights
Sep 09, 2007 | Goldstar MV-1320W/B Microwave Oven
Microwave Ovens Logo
135 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
