i dont want to get a step down for my printer i want to be able to do the electronics in it by converting 110v to 220v power supply
thaank yu
plz help me
Converting a power supply from 110 volts to 220 volts input isnt't easy task buddy. it needs alot hardware changes in it and there is not gaurantee of compatible electronics parts. I gave you a simple and economical solution/ suggestion. final decision will be yours.
Comments:
Jun 01, 2008
- Hi,
Have you done the job or not? I mean you did hardware changes in power supply or got step-down power transformer.
I can't seem to install the drivers for my HP laserjet 1200 printer in Windows 7 64bit... I...
(More)
I can't seem to install the drivers for my HP laserjet 1200 printer in Windows 7 64bit... I downloaded all three sets of drivers from the HP support page. But Windows says that it cannot install the driver because the file is already in use. This happens with all three drivers - PCL5, PCL6, and the Post Script one. Please help! Thanks
I have installed Windows 7 and my hp laserjet 1200 series will not print on a command from the...
(More)
I have installed Windows 7 and my hp laserjet 1200 series will not print on a command from the computer. I have installed the program and reinstalled the program. During the installation I'm told to check if the the printer is plugged in or not. It is and still this stage must be by passed to complete installation. However, my word doc. still will not print.
Helloo I have a problem with my hp 1200,It doesn't want to take the paper and I hear a annoying...
(More)
Helloo I have a problem with my hp 1200,It doesn't want to take the paper and I hear a annoying sound
have a hp1200 laser jet printer .problem is install new cortdage but yellow light is falsher i...
(More)
have a hp1200 laser jet printer .problem is install new cortdage but yellow light is falsher i change the cordage and sansor and saceening unit .but problem is stal
HP 1200 series all-in-one. Warned ink level low and reinstalled a new cartridge identical to the...
(More)
HP 1200 series all-in-one. Warned ink level low and reinstalled a new cartridge identical to the used one (Tesco brand). Will not work and 'check cartridge' light flashes and error message on PC refers to cartridge problem. Another possibly unrelated snag is that the paper display light shows empty even tho' paper tray loaded
