Question about Vacuums
How to wash starc MD-602 fiter - Vacuums
Dyson dc59 animal starts fir about 2 seconds with blue light flashing then stops. Yellow light flashes for about 5 seconds and the this keeps repeating. Can u advise what the problem is tx
sounds like filter is dead, run machine without fiter first see if its the same if it is, phone dyson for a free repair under your 2 year warrenty
Jul 14, 2017 | Dyson Vacuums
My Dyson DC 23 won't power up. Is there a fuse or reset button or do you think my motor is fried?
will be cable reel costs 49, if its your motor take motor fiter out and smell it motor cost 39
Jun 25, 2017 | Dyson Vacuums
Vax action 602 manual
There are several models of the Action 602 by VAX. The manuals are available on the company's support site: http://support.vax.co.uk/ . Use the search feature to find your particular model. The direct link to the manual for the Vax Action 602-AN-Be is http://library.vax.co.uk/resource/1086/u86-an-range/user-guide.pdf .
I hope this helps.
I hope this helps.
Aug 12, 2016 | Vax Vacuums
Motor just makes 4 or 5 small clicking noises when you pull the trigger, then stops. The little lights illumintae around the "max" button as well. However, the motor does not engage in the slightest. ...
fiter is dead clogged up inside. you could wash it 50 times still wont unclog. simple fix, just buy a new filter and empty bin more often in the future and wash filter every month and fit new one every two years
Jul 15, 2017 | Dyson DC35 Handheld Vacuum
I just ordered/received the filter apparatus that attaches to the clear plastic canister, BUT I can't seem to remove it.
The filters on a Dyson DC07 dont go inside the clear bin. There are 2 filters in this machine the first which is your washable filter is on the lower right side of the vacuum, if your facing the front of the vacuum. to remove this filter you push on the purple fiter catch button and lift up on that filter area then your filter will be in there. the only other filter is your permanate Hepa filter. which sits under neath the clear bin assy but that should almost never be removed. if you do need to the are 3 spots on the gray plastic lid. you take a flat head screw driver and gently slide it in the slots starting with the sides and then moving to the one in the middle in the front and then you just get under the lip and pop it up. and then you can access that filter. but again that is a permanate filter. it should not have to be replaced. and it can never be washed.
Sep 19, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Flashing lights.
The Flashing lights indicate several different things. 1 flashing red light means its time to charge your unit. if it is still flashing after charging then you will more than likely need to change the battery. A flashing red and green light means that the unit is overheating which could happen if the filters need to be washed, or that there is a blockage or if your machine has been left in direct sunlight. Allow 1 hour for machine to cool down. 3 flashing lights indicated that the pre-filter has been put on incorrectly. I hope this helps. If you do decide to wash your filter dont use any type of soap it is not needed and allow fiter to dry for atleast 24 hours. putting a wet or damp filter in will damage your machine.
Sep 18, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Need a picture or specs of the insides near motor
the big paper fiter attaches to the underside of the big black top piece of vacuum. there is a round plate and a nut you scew on to hold it. a foam rubber filter fits over it.
May 17, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Le s558 s'arrete sans raison meme apres verification des filtres sac, etc
maybe the fiter it not place properly, there it'a a safety switch that it's not activated
Jan 06, 2010 | Miele S558 Red Velvet Bagged Canister...
My Dyson Animal Dc07 is having problems suction problems
The most common problem with this machine is that either the filters are blocked, or you have a blockage in the hose. Check and replace fiters if necessary.
Rob
Feb 05, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
136 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
