Question about Whirlpool Duet GHW9150P Front Load Washer
REPLACE PROGRAM UNIT WIRING
REPLACING THE PROGRAMER FOR A FROUNT LOADER
WIRING LAYOUT FOR CONTROL PROGRAMER,FOR A WHIRLPOOL WF665/1
  • Julia Bradley
    Julia Bradley May 30, 2008
    Hi I am trying to replace the timer module on a front loading whirlpool wf665/1. dont have the wiring diagram and cannot remember the sequence of wires. Can you help? It has 4 layers of wiring listed a-d.
    Guru:
  • 1,894 Answers
Wiring diagrams are difficult to get unless they are released by the company itself sir.
so we cant assure you of getting one.
bu we wil try our best to get you one.
Posted on Jun 14, 2008
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
How do I install the control board part # W10180782 in a whirlpool washer
Since you did not mention the model number to your washer or whether it is a top or side load washer, I have attached a youtube video for you to watch to get the general idea of how to gain access to the control board on top-loader whirlpool washers; although it is not specific to the part number you are replacing. Repair clinic offers self-help videos on side load washers as well in case yours is a side loader.I hope this helps.
Feb 20, 2015 | Whirlpool Washing Machines
I have whrilpool front loader, when washing some times I get a error F70 & F71. The washer stops, clothes are not rinse alaway. What can I do. I don't have my munual handy. Thanks for your...
Hello & Welcome to FixYa
F70 is a communication error which is caused when no communication is detected from the user interface to the CCU (central control unit). Please check the wiring to user interface and the central control unit, if that is fine and you can see the drum rotating then replacing the user interface is recommended repair. If the drum won't turn then the CCU needs replacement. Please get back to me if you have any other questions.
Kevin
Aug 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Problem with my Whirlpool Calypso top-loader: when I push Start, no water comes into the machine. This is a sudden problem - it worked fine a few days ago. I verified the water is coming out of the hoses...
I would normally suggest a water control valve malfunction but you are experiencing NO water at all and I would doubt both valves would fail at the same time. So we need to diagnose further. Put it direct onto a (cold) rinse and see if water goes in then. If it does then it's the hot water control valve which needs replacing and a Service call ;-0(
If there still is no water going in at all I would suspect the control PCB which needs replacing or a wiring problem - and a Service call ;-0(;-0(
Good luck,
John C
Mar 06, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
My tub on my dyer has quit working-where is the belt located and it is hard to change??
first you nead to unplug the dryer.next you nead to remove the lint filter and remove the two screws that are under it.now grab the top on both sides and pull it forward and up.roll top back and let it lay on back wall.look between the drum and the frount panal and remove the two 5/16 screws one on both sides.next pull the frount panal forward 6"and pull up on the frount panal.rotate the frount panal and let it rest on the side of the dryer.you do not nead to remove the wires from the door switch.next look under dryer drum and you should see the old belt.remove the belt.next place the new belt over top of drum,next with your left hand grab the frount top of the drum and lift it about 2"and with your right hand grab the drum belt and feed it under the drum.2/3 the way back.next lay down in frount of dryer and look under the drum.you will see that the idler assembly neads to be reinastaled in the slot in frount of motor.with your right hand hold the idler assembly and with your left hand you nead to feed the drum belt thrugh the idler assembly and over the moter pully.next you nead to replace the frount panal to the two clips one on each side at the bottom.next with your left hand push back on the drum and with your right hand push the frount panal forward and set the drum with the frount panal and replace the two 5/16 screws.next lower the top panal and replace the two screws and the lint filter.plug the dryer in and test unit out.
Jan 21, 2010 | Whirlpool LER4634J Electric Dryer
F3 error on whirlpool duet front loader
F03 = HEATER SC TO GROUND
The Heater has a internal short circuit.
Short circuit of Heater to Ground.
Measure insulating resistance of heater between contact and housing
(norm. 2 M?).
Replace heater.
Perform test program.
Nov 11, 2009 | Whirlpool Washing Machines
Clothes come out wet
HI, this is a common issue that is easily fixed by, replacing the control unit. this control manages the motor functions during operations. if this unit is not spinning correctly, replace the Control unit. aka(motor control unit). In you washer, they call the motor control board a (Control Unit). replace this asap if possible. this will fix your washer. ADDITIONAL CHECKS--(Make sure that this unit is also draining water properly as well. this will cuase wet spin outs as well).
Jun 10, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Fault code F11 on whirlpool AWM8143 6th sense mwashing machine
got this from another site....
Starting to see these fault codes pop up in these otherwise fine machines. The F/11 code is just a generic code generated when there’s a communications error between the two main control boards in the washer. These two boards are the motor control unit(MCU) and the central control unit(CCU).
A common problem is the wiring harness jiggling loose; remove and reseat it and that usually fixes it. If not, then you’re looking at spending some money on control boards. Yes, I said boards, plural. The really sucky part is that there’s no way to definitively and conclusively prove which board, the MCU or the CCU, is at fault so, unfortunately, that only leaves the parts changing monkey method: replace both boards,
But, on a brighter note, the electronics are covered under warranty for 24 months. If your machine is older that this, then you’ll need to shell out some shekels
tnx 4 using fixya,
drcool
Oct 05, 2008 | Whirlpool AWM8143 Front Load Washer
Question
it will be up in the panel that the cold control is mounted to the celing in the fresh food section,
remove the knobs for the freezer and the ref side
remove the frount plate that tells you how cold the settings for each side of the ref are
remove the 1/4 screws in the frount of the panel, and the ones in the rear of the panel
there you will find the cold contol
part number 2198202
May 08, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool AWM 6100 wont let in water?
this may sound silly but is the hot and cold hoses around the right way
Feb 18, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
166 people viewed this question
Dan Webster
Dan Webster
Sal De
