Question about Sunbeam 2350 Heritage Series Mixer
Sunbeam Mixmaster Heritage series 2350 does not do variable speeds, only high. Apparently this is and was a problem for this model for a long time. There should have been a recall on this. It's very good looking but does not work like advertised and has not been used that many times. So, what do I do now ?? Is this another throw-a-way item ?? Probably will shop for some other brand next time. I would appreciate any solution, thanks.
    Champion:
  • 248 Answers
If this item was recalled,Iwould return it.If you cannot return it try contacting the manufacturer
Posted on Oct 09, 2010
I'm from Colombia my blender buy it in the US, when I use it here in Colombia does not increase the speed always remains constant, not increase, because it can be?
Nothing different between blenders working in US then Colombia. Your blender is defective. Bad luck you bought it in US and never tested before taking it to Colombia. Well, actually a blender can work with just one speed!
Jun 29, 2015 | Sunbeam Mixmaster Heritage Series Stand...
I have a Sunbeam Mixmaster 2351 Heritage Series that the speed dial control numbers fade. Sunbeam replaced my mixer but want to prevent the same problem for reoccurring, Any suggestions?
I would propose to solution to your problem,
one. Try getting some clear contact and cutting a a square or circle a little more than the size of the dial. Removed the dial if possible and later clear contact over the surface.
Two. Get some clear nail polish and cover the markings on the dial with thin coat.
Warning warning warning!!! (Test the nail polish on a surface that is not exposed, for example underneath) to make sure that the nail polish does not react with the surface of the mixer.
Regards
Trevor
Feb 15, 2012 | Sunbeam 2346 Heritage MixMaster Series...
How do you remove the speed control on a Sunbeam Mixmaster Heritage Series Model 2350 Thanks
Remove the end cap. It has 3 legs which are hooked UNDER the inside rim of the outer speed dial ring.
These legs look like a one piece plastic part as if it belongs to the outer ring, but it does not.
The end cap legs can be bent inwards, i.e. away from under the speed ring,
Make sure you have good light, so you can see how the legs move.
With a flat screwdriver (fairly wide) bend back (twist the screwdriver gentle) all three to evaluate how strong they are and get a feel.
That also help loosening them.
I recommend to bend back one at a time and put small shims where the screwdriver goes.
While I was able to do it without, it with shims it will be easier to keep the legs inward.
Once you get two legs to come up from under the ring, you can get the entire end cap out.
Had to do this to fix the tilt mechanism. There was an inner nut that had came off the holding bracket. I suspect vibration made it come off , so I put some nail enamel on it after fixing.
The speed ring screws etc. are all accessible once you have the end cap off.
To get to the actual speed control knob, just unscrew the next little part, you'll see and it becomes obvious how to get at the rest.
Jan 23, 2011 | Sunbeam 2350 Heritage Series Mixer
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
Nov 25, 2007 | Sunbeam 2485 MixMaster Series Hand Mixer
Sunbeam 2350 Heritage Series Mixer Logo
334 people viewed this question
Top Sunbeam Food Mixers Experts
Jerry Greenberg
Jerry Greenberg
Tony Vallette
Tony Vallette
Level 1 Expert
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
