Question about Haier 65-Pint Dehumidifier
Just bought 2 Model # DE65-RBG humidifiers. I plugged the first one in, and it states "Lo" where it states current/set humidity. What can be the problem. ANd on the 2nd dehumidifier, there is no water in bucket, though it has been plugged and working for 30 mins already. Shouldn't there be some sort of condensation?
22yooper
  • 828 Answers
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Posted on May 09, 2008
SOURCE: humidifier not taking out water
On my third unit.
First unit worked well (but loud) died in 5 weeks, replacement (14.99 to ship) was DOA, third unit appears to be working. Horrible bucket design, it's impossible to remove and carry when full without spilling. Float level is set too high, no adjustment..
Would not recommend.
Posted on Jul 08, 2008
  • 121 Answers
SOURCE: humidifier measuring wrong %
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is 2 years old.
Posted on Aug 04, 2008
  • 958 Answers
SOURCE: no longer drawing humidity and condensing into bucket
thermostats are device to control the compressor. you said the compressor is running. if you are sure that the compressor is running, then it could have a leak and it is not functioning as it should. feel the air that is coming out of the fan, it should be a little bit warm, if it is not, and the compressor is running, i would suggest for you to turn it off and seek professional advice on how to find the leak and recharge the system of the unit. it is bad for the compressor to run without refrigerant.
tnx for using fixya,
drcool
Posted on Sep 22, 2008
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
Posted on May 02, 2009
I don't understand how to set my humidifier to run economically and still do it's job.
check manufacturer web site for a manual, most have them available for download
Jul 30, 2014 | Midea MDF1-30AEN3-BA4 Westpointe 30-Pint...
WE have a model DE45EJ - T. The humidifer is not pulling in anything or making any noise or doing anything at all. It says Lo in the bottom reading.
The "LO" in the bottom reading, Indicates the current humidity extraction setting. If the unit was operating properly not that long ago (A couple of hours), the reason it is not doing anything, maybe that there is no humidity above "LO" = 30% at this time. Once it the humidity level rises above 30%, it should turn ON and function normally.
Also, was the timer set to turn the unit OFF at a specific time?
If the unit wasn't working properly a couple of hours ago.
Check the air intake filter for excessive dirt or clogs. Turn the unit OFF & unplug it before removing the filter. While the unit is OFF, remove the bucket, empty it if needed and carefully replace i, making sure it is fitted properly in to it's holder.
Air obstruction: The dehumidifier requires an minimum of 12" to 18" clear air space around the entire unit.
Hope this has helped you further troubleshoot and solve the problem. To assist you further, in case you have misplaced yours, I am including a link to your Owner's Manual that you can download and print for future reference. http://www.haieramerica.com/en/asset/product/4ba7175e54
Jun 22, 2011 | Haier 45-Pint Dehumidifier
How do you set it to come on and off automatically
Generally, setting the humidity extraction level to what you want (Remember, the lower the percentage, the more humidity will be extracted) and not operating it in continual run mode will do the trick. Most humidifiers can be set to run in a 2 hour or 4 hour intervals. That means it will run as necessary for 2 or 4 hours and then turn OFF. It will turn back ON again, when the humidity level in the home rises above the setting you have it on.
Hope this helped you. Please let me know. Thanks.
Jun 03, 2011 | Friedrich D50C Dehumidifier
My dehumidifier is not collecting water what can i do to fix it? the model #99701
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 primary reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Kenmore 54501 Dehumidifier
My dehumidifer is not drawing any water, but the fan continues to run.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
Machine runs, but no water is coming out into the bucket
Jun 02, 2011 | LG LHD459EL Dehumidifier
Humidity pad doesn't work
You've posted in DEhumidifier section.
Sounds like you have a Humidifier. Please post there.
Although why you want to add humidity to the tropics is beyond me.
Sep 01, 2017 | Kenmore 54501 Dehumidifier
Humidifier measuring wrong %
Aug 03, 2008 | LG LD65EL Dehumidifier
Humidifier that never shuts off.
I am having the same problem with mine and it has started freezing up for no reason. Did you get any answers
Nov 20, 2006 | GE AHG40LA Dehumidifier
Humidifier stopeed working
You have a bad fan motor. Put your hand against the grill to see if there any air movement. You need to buy a new fan motor assembly, it is attached by two long
bolts, easy to swap, except the wiring may not be easy. May have to cut the 3 wires and resolder. Get to the motor by removing the back panel and then the fan. Removing the fan may not be easy, they put some gunk on the spidle thread.
The cheapest price I have seen for the motor is $27-$28, shipping about $8 and tax
about $1.5.
Sep 18, 2006 | LG Goldstar LD65EL Dehumidifier
Haier 65-Pint Dehumidifier Logo
118 people viewed this question
Top Haier Dehumidifiers Experts
Shawn DuRee
Michael Vincent Cruz
Shehu Pro
Shehu Pro
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
