Question about GPS
Where is the clost place to hook up the reverse signal input wire on a 2005 f150
  • 625 Answers
The reverse wire is black with pink and it is located in the driver's kick panel. It is in a gray plug,pin 13. The driver's kick panel is the panel that is located left of where your left foot would rest when driving.
Posted on Oct 09, 2010
Turn signal handle broke off and is hanging by wires
You can buy the turn signal switch at Napa or other auto parts stores. It's a combination switch. Remove the steering wheel and remove the 2 screws that hold the turn signal switch on, unplug the wires and installation is reverse of removal.
Apr 02, 2010 | 1992 Ford F150 SuperCab
Hi i got a n reg ford transit recovery truck someone cut the back light wires now i cant find where they go could you help ?
Use a 12v test light, test the wires on the left side.
One at a time turn on head lights and locate tail light
wire and mark it. do the same thing for the brake light
and turn signals. Now measure out enough wire to go
the left light assy. and across to the right, plus 6". If
you wan't backup lights, turn the key to the on position(don't start engine) block the wheel and put in
reverse, locate wire the same way. After you hook up
the left socket, splice in the brake-backup and tail
lights, to go across to the right. Splice the plate light
in to the tail light 1/2 way across. The right turn signal wire should already be there. Hook up your
sockets, and thats it. Hope this helps. Good luck.
Jan 25, 2010 | 1995 Ford F150 Styleside Regular Cab
Where can i hook my aftermarket tach signal wire in my 2004 f150 to get a signal
my recomendation is to find a tach that does not require to be hard wired. it is callec conductive sensor, havent bought one in 15 years but they were aviable then.
Jan 13, 2010 | 2004 Ford F150
I have brake lights,signal lights,flashers but i Dont have night lights on the trailer connected to my trailblazer.What's Wrong?
I have a new F150 I have hooked up to my horse trailer. Running light work but when I turn on a turn signal this blows the fuse to my running lights, any ideas?
Aug 22, 2009 | 2005 Chevrolet TrailBlazer
2006 F150 - hook up to fifth wheel and all lights work except running lights. All lights come on the truck but not on the trailer. I have signals,flashers,and brake lights that work on the trailer but not...
No running lamps. Flasher irrelevent.
Wire conection more likely. Pay attention to fuse rating on tow vehicle. focus on brown and black wire
May 07, 2009 | 2005 Ford F-150
HOW DO I INSTALL A RCA ADAPTER TO MY VEHICLE
There should be a diagram entitled "adding and amplifier to a factory stereo" in the owner/install manual of the high to low convertor. You need to signal tap some audio signal from your front or rear stock speakers in the car and those wires need hook up to the high to low convertor's input side. From the convertor you connect RCAs that go to your amp. In other words find your rear speaker wires and hook them to your adapter then hook up the rca wires
Dec 02, 2008 | RCA Pie Pio/P Rca Adapter P Bus Mcd To Aux...
NO sound and NO cable signals
Is your tv connected to your cable box through HDMI, AV, or component?
_____________________________
If its through HDMI then your cable carrier needs to load updated frimware in your box to communicate properly with your 2005 tv. The firmware loaded in your cable box needs to be "reverse compatible" for first generation HDMI from your 2005 tv. If your using AV or component hook-up and there's no sound then re-check all of your audio settings within the tv's menu. Also recheck the cable-wire your using and proper input/output ports.
ON your dvd player, is your tv connected through component, AV(rca) or HDMI?
If its through "component" then you need an extra audio cable to and from the DVD and tv.
May 07, 2008 | Akai LCT2060 Television
Installing a rear camera
Your local high end installation shops would have all that info on hand. Goodluck.
Mar 30, 2008 | Eclipse AVN5500 Car DVD Player
GPS Logo
115 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
