Question about Crown CE2000 2-Channel Amplifier
I have a Crown XLS 1000 running in stereo highpass mode. Can't get any output on channel 2. Can't get any output on channel 2 in any mode. Checked amp at store, everything worked perfectly. Any ideas?
  • Frank Oct 09, 2010
    Swapped cables. Second speaker works fine on both cables going out. Both cables coming from mixer to amp are delivering signal. Both meters on amp show signal activity, but no output on channel 2. I've tried every combination of cable hookups I can think of, going out and in to the amp. Going out of channel 1 (speakon) I have sound to either speaker with either cable. Going out of channel 2, nothing on either cable or speaker. I'm wondering if my problem lies with channel 1 out and the wiring of the speakon connecter. If the speakon connector going to channel 1 is 4 wired, does that make the amp think that channel 1 is carrying a stereo signal and is cutting off the channel 2 output?
  • 55 Answers
Make sure you are getting a signal into channel 2, A cable swap will tell you this.
Posted on Oct 09, 2010
    Solved own problem. Swapped the NLF4C speakon with NLF2C, no more problem.
  • Larry Townsend Oct 10, 2010
    That was my next idea was to try a speakon 2 cable. I love Speakon cables but te can be a pickle at times. I use Speakon 4 Cables my self as I use one amp for my Woofers and another for my horn's or Biamping. I come out of the Amps with Speakon 2 to a J Box and out to the Speaker with Speakon 4's from the J box. So my J box has 4 in and 2 out to the Byamped Speakers.
I have a crown xls602 with no audio. Speaker and power relays activates normally, signal leds palpitates with input but no sound. Appreciate any help. Thank ou.
- Use your favourite search engine (Webcrawler is dandy) and type your question/info into it.
- SEARCH ENGINES ARE YOUR FRIEND!!! Type in keywords and check the results.
- I'm not an expert but it almost sounds like maybe a speaker relay or whatever on the amp has bailed out.
Good Luck :)
R
Feb 13, 2015 | Crown XLS 602 2-Channel Amplifier
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
Trouble shooting crown xls ampilifier602
There are two similar circuits , use the good channel as a guide in
troubleshooting.
Aug 17, 2012 | Crown XLS 602 2-Channel Amplifier
Got a crown amplifier XLS 602 its powering up the relays are clicking, all voltages seems ok the signal led's are on but there's no sound output on both channels. I manage to trace the signal
Check your input or output cables might be dirty I had the same problem
and 1 of my output wire was dirty so i sprayed tha electric cleaner and its all good now
Aloha
May 21, 2012 | Crown XLS 602 2-Channel Amplifier
How do you "bridge" a d.j. 2 channel power amp? it
Very carefully... SInce the outputs are not specified as isolated, your speakers would be connected across the hots and the returns would be jumpered.
Then for the two inputs you would drive them balanced into the XLR connectors from a single balanced source and reverse pins 2 and 3 in ONE of the connectors of this Wye cable into one of the two inputs on the amp.
Nov 28, 2010 | Crown-Audio XLS 402D Amplif 300 with 8o...
I have a crown 602 channel 2 shows signal coming in, but no volume comes out. Yet when its bridge it seems to put out more power than just one chanel. Not sure where to start looking into the #2 channel...
Common problem. Power transistor in channel#2 is weak or out completely.
Bridging converts from 2 channel(stereo) to mono and you are are useing both channels in series to effectivley double your output.
Oct 04, 2010 | Crown XLS 602 2-Channel Amplifier
I have a Crown XLS 602 amp. I use it for my home stereo system..It is stored in a well ventilated cabinet with a cloth grill front. There is nothing under or on top of amp...I don't listen to my music real...
I would not recomend disconnecting the fans. They might be running to keep a certain heat sensitive (and perhaps expensive) part cool. However it could be the case that the fan speed control circuit has developed a fault, therefore the fans are running too fast.
Jun 30, 2010 | Crown XLS 602 2-Channel Amplifier
Wattage
I have the following specs for you
Basically 150watts per channel using two channels , or 75watts using all four
Here goes:
  • 4 Channel Mosfet Amplifier
  • Advanced Overload and Thermal Protection
  • Metal Film Capacitors/Resistors In Signal Path
  • Frequency Response +/-1dB, 20Hz to 20 kHZ
  • Signal to Noise Ratio (A-weighted) >100dB
  • Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
  • Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
  • Nominal Continuous Power per Channel @ 1 % THD 35 Watts x 4 into 4 ohms @ 14.4 Vdc
  • IASCA/USAC Power Rating 12 Watts x 4 into 4 ohms @ 12.5 Vdc
  • Minimum Load when Bridged 2 Ohms
  • Minimum Load per Channel 1 Ohm
  • Input Signal Voltage Range 0.1 volts to 2 volts
  • Crossover Type Resisitor Network, Linkwitz Riley,
  • Highpass/Lowpass
  • Crossover Slope 24 dB per octave
  • Crossover Frequency Range 20-550Hz
  • Factory Crossover Setting 85 Hz
  • Auxilary Output Channels 2
  • Auxilary Output Frequency Range Highpass or Lowpass, Opposite of Speaker Output
  • Bass Boost 0- to +18dB @ 45 hZ
  • Power Supply Voltage 10Vdc to 15.5Vdc
  • Recommended Fuse 40 amp
Dimensions 12.25L x 9.25W x 2.10H
May 23, 2010 | Car Audio & Video
What is RMS power output both channels driven at 20-20000 hz. on xls602D
This unit is described as delivering 380W per channel into an 8 Ohm load.
Feb 23, 2010 | Crown XLS 602 2-Channel Amplifier
Hooking up 2 speakers to 1 speakon output
Power Output (1 kHz*) Stereo Bridge-Mono 8 Ohm 4 Ohm 8 Ohm XLS 802 500W 800W 1600W XLS 602 380W 600W 1200W XLS 402 300W 450W 900W XLS 202 200W 300W 600W *1 kHz Power: refers to maximum average power in watts at 1 kHz with 0.5% THD. It depends on the impedence of the speakers. Carfull as you could burn up this amp if you exceed the resistance rating on it. Go here on all of the specs of this model of crown amps. http://www.crownaudio.com/amp_htm/xlsspec.htm Good Luck
Mar 27, 2007 | Crown XLS202A 2-Channel Amplifier
Crown CE2000 2-Channel Amplifier Logo
508 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
