Question about HP Photosmart C4580 All-in-One InkJet Printer
Hi, I am using printer HP 4580, and the problem of "missing cartridge" occurs. Please help me out. Thanks
  • 55 Answers
Unplug your printer from both sides. Pull out the cartridge and place it again gently. place it again gently with care in its room. attach again with your computer, restart it you will find it working, INSHALLAH.
Posted on Oct 09, 2010
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Where is the ink cartridge located in the printer
Replace print cartridges that show any of the following symptoms:
  • Print is faded, is missing, or has missing streaks.
  • Printed colors are different than expected. This usually occurs when one or more ink colors are empty.
  • Print cartridge error messages that cannot be resolved appear on the front panel display.
    Read More....Replacing the Print Cartridges and HP Printer Support
    Thanks.
Jul 15, 2014 | HP OfficeJet 6110 All-In-One InkJet...
How do you remove/open printer to take out cartridge on hp 4580 printer
Access the manufacturer's web-site: http://support.hp.com
Enter: 4580
and do the search.
Choose from:
» HP Deskjet F4580 All-in-One Printer » HP Officejet J4580 All-in-One Printer » HP Photosmart C4580 All-in-One Printer and read the online documentation for the specific model. It will describe the exact steps.
Jul 12, 2011 | Computers & Internet
I have a issue with hp laserjet 1022 having cartridge missing error please provide some needful helps
Hi
Make sure you installed HP toner cartridge for your printer. and Insert is correctly into the printer. Try to use the old toner cartridge and check if this is the problem.
Just replace new toner cartridge and i might solve your problem. Regards
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 11, 2011 | HP LaserJet 1022 Printer
I've just installed a HP deskjet 4580 printer...everything went well except an error light showing the black ink cartridge is not installed correctly....I've removed it and put it back in numerous...
reinstall drivers from
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3944758
and what OS you have mension it that website and download fresh drivers this is sometimes due to DLL files missing
do vote if it helps
Mar 31, 2011 | Office Equipment & Supplies
We have an HP 2015n printer with an error code of 10.1000. Can you please tell me what this code means? Thanks
10.1000 Black e-label missing error Error message 10.1000 supply error alternates with Reinstall c00381084.jpg with a ? under the Black print cartridge gas gauge Description The black print cartridge or print cartridge e-label is missing. Action
  1. Install the black print cartridge.
NOTE: If this error occurs upon initial power-up on the printer, remove all cartridges to check for the orange packing tape. If present, remove it before reinstalling the toners.
Nov 10, 2010 | Computers & Internet
Ink cartridge problem( s) appear to be missing or damaged
hi there,
Ink cartridge Problem
Cause : The indicated ink cartridge(s) are missing or are damaged.
Solution : Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-one, the ink cartridge contacts might need to be cleaned.
IF there is no ink cartridge missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Replace the ink cartridge.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 26, 2009 | HP Photosmart C6280 Printer
Users Manual for HP 4580 All-in-one Printer. How
Please download the user manual from this link
static.tigerdirect.com/pdf/HP-Officejet-J4580-Printer-Manual.pdf
Hope this information will help you
thank you
Oct 02, 2009 | HP Computers & Internet
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
Incompatible cartridge error in j 4580
refix your cartidge .may be your cartridge is faulty.
Dec 25, 2008 | HP OfficeJet J4580 All-In-One Laser...
HP Photosmart C4580 All-in-One InkJet Printer Logo
141 people viewed this question
Seeker5211
Seeker5211
