Question about Pioneer DEH-P6400 CD Player
Need to know which connector pins are power and which are speakers?
    Scholar:
  • 50 Answers
Here's a link to the installation guide for your unit different model but the wiring is still the same. May have wires your don't but the basic wiring will be the same.
It is in PDF format so you will need Adobe to view it. You can get it for free at www.adobe.com
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/50166installation_manual_DEH-P6500_2003117152575930.pdf
Posted on Oct 09, 2010
Installing an internal speaker on a Desk top pc mother board do you need to reconfigure your system.
Typically, the speaker is connected with 2 or 3 wires. The connector block should have a pin labled "SPKR" or "Speaker". From there, count three up and find a pin labeled "+5v". These two pins are typically separated by two ground pins.
So, the connection would be: spkr, gnd, gnd, +5v. The ground pins may, or may not be used depending on your design.
Nov 06, 2014 | Computers & Internet
Replacement power supply - can i convert AC to DC output connector?
I'm not clear on the four pins of the DC power supply for the speakers. Do you think there two different voltages needed??? It's not worth trying to convert your ac power supply/ It would take a few parts and you will not end up with 18 vdc. You can purchase a 18 v dc adapter for as little as 15.00.
Jun 16, 2014 | Altec Lansing M604 Computer Speakers
What or the color of the radio wires for in a 1993 bonneville
Use a multimeter to find the two feeds and then a 9v pp3 battery to check the speakers it thats simple .
Feb 25, 2012 | 1993 Pontiac Bonneville
Where can I get a speaker connector?
After a few hours of looking on line and finding nothing I decided to make my own Sharp Receiver connectors. Here are the steps that I took:
_1349.jpgItems I used were wire strippers, wire snips, a file and a sugar free Rockstar (not pictured items: computer power supply, fine grit sandpaper and zip-ties).
_1350.jpg The first this I did was find the 4 pin connector and the 20 pin connector (some times a 16 pin) on the pc power supply and i cut the wires so that there was about 10" to 12" of wire hanging from each connector. These are the 2 connectors need from the power supply to use in your Sharp Receiver.
_1351.jpg This is the smaller of the 2 connectors (the 4 pin) and nothing needs to be done with this one. It fits perfectly into the back of the Sharp Receiver into the area labeled " surround sound". I would just zip tie the wires 3" from the connector and then 6" from the connector.
_1352.jpg The large connector I cut from the pc power supply is the one where all the work needs to be done. The Sharp Receiver requires an 8 pin connector for the are labeled "front speakers/center speakers/sub woofer". Notice the location of the clip for this connector and that it is centered, we need this clip to remain in the center when we are done so re are going to have to remove every thing from it except for the center 8 pins.
_1353.jpg What I did to get the connector to look like this picture is I cut the 6 pins off on both ends of the connector (you would only cut the 4 pins off both end if you are using a 16 pin connector from the power supply). after I cut those pins off I just pulled the wires out from the back side (they come out very easy after you cut the pins off). Now we need to get rid of the extra plastic where we cut the pins. Please view the next 2 pictures before you begin to do your cut.
_1355.jpg Notice how I left the plastic intact surrounding the 8 remaining pins we are using. I know that it seems like common sense to do it this way but there's people out there who would have cut the plastic so the pins we need are showing. There may be some jagged edged now from where u cut the extra plastic so to get rid of that we are going to use a file or a grinder. Don't grind the sides completely down though, I left a little bit of the ridges because the new ends have thin plastic walls and if you leave a little of the ridges, it will make it a little stronger.
_1356.jpg I tried to put my, now 8 pin, connector in the back of my Sharp Receiver and it was really snug. This is where the fine grit sandpaper comes in handy. just go around each of the 8 pins with the sandpaper, not a lot, just enough so the pins slide into the plug easy and doesn't wiggle. I used 2 zip-ties on this connector also to secure the wired a little more. Again, 3" and 6" from the connector. Now its ready to be plugged into the area labeled "front speakers/center speakers/sub woofer".
_1357.jpg This is what it should look like when you are all done making the speaker connectors for your Sharp Receiver. All that's left is to connect your speaker wires to your speaker connectors and then all of your components.
I only found 1 website that had the parts for this unit for sale and it was about $50 plus shipping for the connectors. You can get the computer power supply from your local area on www.craigslist.org for $5 or $10, you might have one lying around. If you have any questions or need additional help with this please feel free to email me: jlusk80 @ gmail.com
Thanks for reading my solution!
Jan 01, 2011 | Sharp HT-DP3000 System
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
I need a circuit diagram for My Logitech Z-640 Computer Speakers
You may have to call Logitech support or email to find out what the pin out is. that would be my only solution if there is one.
Mar 26, 2009 | Logitech Z-640 Computer Speakers
I need to know the sequence on how to connect my Power LED, Reset Switch, HDD LED, and M/B Switch up correctly. I have an MS-7142 VER:1 Can you help me?
Hi carlmtclem, your not alone when it comes to hooking up the right led connector to the MSI MB. Firstly, you need to know what wire color is positive & which is negative. Most commonly the color white is ground/negative. Wire colors do vary from case to case. So look at your case led wires. Which ever color is common for each 2-pin connector, is negative. (Except the speaker wire).
All other colors are positive.
(The speaker wire color for negative is usually black & red is positive).
Your MSI board has two separate sets of pins.
JFP2 is used for the speaker only. Do not connect the power led there.
Pin one for JFP1 is shown in the manual. Pin 1 is positive & pin 3 is negitive for the HDD-LED, ECT.
Thats it.
Need more information?
Post here.
Good luck carlmtclem!
Thank you for using fixya.
Mike
Jan 11, 2009 | MSI K8MM-V Motherboard
Compaq Power Led and Speakers connectors
Ok on the front panel pin header , you should see 2 pins labeled SPK for the speaker and 2 pins labeled pw led. And also you should see 2 pins for the reset connector. Use a flashlight and /or a magnify glass, the letter may be faint.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2008 | Computers & Internet
Need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Pioneer DEH-P6400 CD Player Logo
81 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
