Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a 50 inch rzt with a 22 horse kawasaki motor. it has worked fine until this year. now, it runs for a little while and then shuts off. it is hard to start back but when it does it runs fine for a while then shuts off again. any ideas???
  • Cub Cadet Master
  • 7,482 Answers
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
Exmark lazer HP 19 Kawasaki 50" deck new PTO and new relays blades engage for 30 minutes then shut off engine on. After cooling will engage for 10 minutes then shut off
Engine valves need adjusting.
symptoms: starts ok, runs until engine reaches max temp loses power then stops. can't restart when hot. once restarted runs for a while stops again.
There is very little clerance in these valves and temperature alters the lenth by a few thou and the valve don't close fully losing compression, once cold the valves shrink back enough to create enough compression to start again.
Aug 13, 2015 | kawasaki Garden
I got a z master 149 mower and put a RZT mustang Kawasaki twin motor wires or differ color how do I hook them up
First off you need to go to web site with your Model # .Get the wiring drawing for both systems.Them wire it up using the right color wire
Mar 05, 2015 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
How to replace throttle cable rzt 50 cub cadet briggs motor
You will need to remove the left fender/tank to access the throttle lever mounting screws. Make either written notes or take snap shots as you remove the old cable as there are several different setups for this mower series so you can install the new cable correctly.
Feb 10, 2015 | Cub Cadet Garden
Troy bilt RZT 50
Is this a twin cylinder motor if it is it sounds like a bad spark plug
Oct 15, 2017 | Garden
John deere 445 96 w 22 horse kawasaki fuel injected starts fine runs but rough with raw exhaust gas new olugs new fuel &filter new oil
When it runs rough is it blowing dark smoke? This is a sign of running rich like a choke will do and can cause stalling especially when the motor is warmed up. If it is not blowing dark smoke it sounds like maybe your injectors are not working properly and it is not getting enough fuel through them under load. either way as an injected machine it sounds like injectors may be the culprit since youve taken care of some other issues. You might try running a heavy dose of an injector cleaner through it (I've had good results with lucas brand) and see if that helps. Otherwise, you might try to manually clean the injectors.
Sep 25, 2012 | Garden
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Flywheel not ingaging when turning ignition for my tractor mower rzt 50 kawasaki fr651v
You have a fiber gear on your starter it has striped out,you have to remove your starter to replace it, on some you have to remove the flywheel.hope this help you
Aug 28, 2009 | Mustang Rzt 50" Zero Turn Riding Lawn...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
445 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
