Question about Lexmark E232 Laser Printer
My printer won't communicate with the computer
It looks like it should work, but we have tried it out on several different computers, and it will not print.
  • Anonymous Jun 10, 2008
    We had two printers do the same thing for no apparent reason. Threw the first one out and am about to do the same thing with the second one. Wouldn't communicate with the computer, any computer.
    Master:
    Sergeant:
  • 461 Answers
You might need to check your driver if it is install correctly for the correct OS, i'm not sure what OS you are using but below link might be helpful to help solve your issue
http://etech.maiila.com/?p=42
all the best..
p/s please rate me...
Posted on May 30, 2008
LEXMARK PROSPECT PRO 205. HAS A CURRENT SOLUTION FINALLY BEEN FOUND FOR "PRINTER CANNOT COMMUNICATE WITH COMPUTER". LEXMARK CANNOT OR WILL NOT FIX THIS PROBLEM.
Chuck, I certainly sympathize with "tech support" that isn't, and with you on printers that don't get new drivers when new versions of Windows com out.
I'd be happy to enter a dialog with you to try to help you.
Have you tried another computer, hopefully running something different?
What connection are you trying to use? Does the printer have any alternative connection available? (say, USB or network)
When you first plug it into the computer, does the computer sense it's there and look for drivers, or does it ignore you?
Jun 16, 2015 | Lexmark Pro 205 Inkjet Multifunction...
S405 printer won't communicate with computer when trying to print
First, make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, try to uninstall the Lexmark driver and download an updated driver online at http://bit.ly/rtOKTx. Just choose the Operating System of your computer.
Also, if your printer is connected to your network, try to set a static IP to your printer to prevent it from getting a different IP.
Dec 12, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark X1190 problem communicating with computer
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
Dec 20, 2011 | Lexmark X Office Equipment & Supplies
Bought dongle E173 works on dell computer Xpworks on laptop windows 7 but wont install on PC Specialist windows XP why ????
Hi there! If the E173 worked with your windows 7 then that means the E173 is working properly, try to check first if the PC specialist windows XP computer can detect the dongle if not then try to use a different USB port now if is detected but won't install try to find it in the drive go to my computer then look for the removable disk or the e173 then manually install it but if after trying different USB ports and the dongle is still not being detected then check if it is compatible with that computer or you can try to use another USB device to check if the ports are working properly.
Hope this helps!
Sep 01, 2011 | Microsoft Computers & Internet
Printer suddenly will not communicate with the computer. Tried unplugging both wall plug and usb plug. Printer can print but only test page. Tried to uninstall, but computer won't allow me, gives error...
Have you tried rebooting your PC? Do you see a printer Icon in the taskbar (right corner) if so click on it and you may see several que's and the printer is bound up, so-to-speak. The reason your able to do a test print is because that command bypasses any que's in memory. Turn your printer power off, then reboot your PC. Onces its booted up, turn on your printer. This will clear any que's and your printer should communicate again.
Let me know if this help you.
Thank you
Jul 04, 2011 | Computers & Internet
Computer won't communicate with printer
Make sure that the printer driver you are using is compatible with your version of windows. If so, open all printers in "control panel" and make sure that this printer is the preferred printer and not an old one you might still have installed.
May 09, 2009 | Lexmark P4350 All-In-One InkJet Printer
Computer can't communicate with scanner.
Go to START menu click on devices and printer, then locate and click on add device, and follow the instructions.
Hope this helps you
Mar 08, 2009 | Pacific Image PrimeFilm 1800u Film Scanner...
Lexmark 1270 all in one
First try plugging into a different USB port. I have seen several machines have a port suddenly die for no apparent reason. If that dosent work, try a different USB cable. Assuming the printer is working, the only thing left is either the cable or the port you have it plugged into.
Feb 07, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark E232 Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
