Question about Tappan TEF242 Electric Kitchen Range
Tappan oven shows f13 when i try to turn it on.
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Dec 15, 2014 | Tappan Kitchen Ranges
F13 code
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
Aug 07, 2014 | Frigidaire Ovens
How to fix f13 error code on a tappan stove
Good Afternoon Friend,
I understand that you are receiving an F13 error code on your Tappan range. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. If further troubleshooting is needed, I ask that you please leave your model number in the comments as well. Hope this is helpful.
-Best Regards-
WP
May 31, 2014 | Frigidaire FEF336BC Electric Kitchen Range
Why my oven shows f 13
your eoc is bad, electronic oven control (clock)
Apr 11, 2013 | Frigidaire FEF336BC Electric Kitchen Range
When I try to turn on the oven it say f13 err
Most of the F13 fault codes say it is either the Main board or a temperature sensor.
May 10, 2011 | Ovens
Receiving Error F13
Turn the breaker to the stove off for one minute, reset time and everything should work just fine. It worked for me.
Ken
Jan 08, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
TAPPAN gas range model 30-3991-00/03 oven won't work.
the button your holding is the switch that tells the board that the consumer whats to bake.so if holding the switch causes that message to work[or oven to heat] and letting go of that button ,then no work .its that button ,but its all part of the board .just that part of its funktion is broken.,if it was lets say your oven ignitor or oven gas safty valve ,the board/oven control[the one with the button]would continue to try after you have selected bake [pushed button]or would give error code.hope that helps you. God bless you , tom
Jan 05, 2009 | Tappan Kitchen Ranges
Tappan Millennia Stove/Oven
I have a delay when trying to turn on to use the over, then an exploding sound. What is this? Is the ignitor going bad?
Oak Park, IL
Jun 16, 2008 | Tappan TGF320 Gas Kitchen Range
Tappan TEF242 Electric Kitchen Range Logo
188 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
