Question about KitchenAid KSRS25IL Side by Side Refrigerator
Slime in refrigerator water line
Did you ever find a resolution to the slime in your refrigerator water line? We have a KitchenAid with the exact same problem.
  • 1 more comment
  • cecole Jul 17, 2008
    just changed our filter and water still tastes like mildew
  • kbabe Dec 13, 2008
    Any solutions? I just recently found the same thing - green tube like pieces floating in the glass. Looks like they line the water tube somewhere and break off when dispensing water.
  • Mr PW Jan 22, 2009
    I have a Kenmore side by side with the same problem. Disgusting slime that cuts loose from the line and gets in the ice and the water dispenser water. My water is fed from a reverse osmosis water filter system which also feeds a dispenser at the sink. The water at the sink is crystal clear so I know that this problem is refrigerator specific (generated within the fridge). My theory is that it may be "matter" cutting loose from the refrigerator filter since the tubing full of slime is after this filter. I just bypassed the filter at the bottom of the refrigerator so I am no longer using it - since my water is already coming from an R.O. system. I will have to wait and see if this clears up the problem. If it doesn't clear up the problem, the slime is forming in the tube. But what would cause that? I'm interested in your solutions let me know.
    PW
    Sergeant:
    Champion:
  • 330 Answers
The water quality is really bad, you should change your filter often even the big water filter from your main line, need to change it after 4 to 5 months.
Posted on Jul 02, 2008
Why is rust-colored slime leaking out of top of water heater?
The water heater needs to be replaced. The rust-colored slime indicates that the water heater has a leak.
Sep 17, 2015 | Water Water Heaters
How do I change filters
all the new ones in the front on bottom
all the old ones are on the back attached to hose pull out the fridge to see turn off an drain water ,disconnect an go buy one .
i like to back flush them with bleach ugh i found slime.
Jan 12, 2015 | KitchenAid Refrigerators
Ice guide replacement for Kenmore side by side
if the clog is soft, kind of slimmy, you can remove the water line and flush it with white vinagar and water mixed, blow thru the line to push the slime out - if hard scale, you will need to use pure vinagar and soak the line to disolve the deposits.
Jan 25, 2010 | Kenmore 57029 Side by Side Refrigerator
Green slime around rubber and drum that won't come clean. I did 3 maintance washes with bleach and let them air dry and still green slime around rubber and drum of washe. It stinks. I even used a small...
I don't even know if this is possible on your machine but see if you can get bleach into your water intake port, if the green slime still shows up you may need to contact your board of health because it sounds as if the problem is your incoming water and you may need to have your water company clean their pipes or even replace them, did you perchance loose water pressure before the slime became a problem?
Dec 07, 2009 | LG WM2688HWM TROMM SteamWasher
Rv a/c drain water becomes slime
Use a shop vac( wet/dry vaccum) and as you clean the coils use the vaccum to remove the slime and debris. This slime is caused by particles in the air that has been drawn into the coil during a/c usage. To prevent this slime from continuing to build up you can use a tablespoon of bleach and pour it into the drainage pan this will kill all the algae producing bacteria and will keep your a/c condensate drain in tip top shape. Hope this helps Good Luck
Dave
Aug 06, 2009 | Heating & Cooling
MY WATER LINES LOOK RED AND THE WATER CAMES WITH RED STUFFS
sounds like a dirty in line filter the red slime is alge replace the filter and flush the water lines
Jun 23, 2009 | GE Profile¿ Arctica® Energy...
Water from refrigerator has pink slime in it
Pink Slime coming out of the Water Dispenser on your Fridge:We contacted our appliance repair guy about this for one of our rental properties. He informed me that the pink slime is an algae formed in the water line. You won't get that out & is it not repairable. The fridge will be condemned if you send out an appliance repairman. It is very crucial to replace the entire fridge, because it is a highly reactive algae that will make people extremely sick!
Apr 11, 2009 | LG Refrigerators
Kenmore refrigerator water dispenser problem
SORRY TO SAY THIS BUT IT SOUND LIKE YOU HAVE BLACK ALGEA IN YOU WATER SYS WHICH IS GOING TO REQUIRE A TECH TO REPLACE ALL THE TUBING IN YOUR WATER INLET SYS TO GET RID OF IT. GOOD LUCK AND CONTACT APPLIANCE SERVICE CO. P.S. DON'T DRINK THE WATER OR USE THE ICE IT WILL CAUSE MEDICAL COMPLICATIONS
May 30, 2008 | KitchenAid KSRS25IL Side by Side...
Water Dispener has an algae like slime in the water.
Try cleaning with a dilute solution of bleach. Let it stand for a couple of hours then flush through with fresh tap water.
Oct 14, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KitchenAid KSRS25IL Side by Side Refrigerator Logo
1,143 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
