Question about Samsung Televison & Video
My dvd player htx250 ejects some CDs(does not play them) and plays others. The CDs ejected are ones i played successfully few hours ago
SOURCE: Insignia DVD Player
Try hitting the "Lock" button on the remote. That solved the problem for us.
Posted on Jan 28, 2007
simplemitch
  • 752 Answers
SOURCE: Ejecting a dvd
It's a mechanical problem and the unit needs to be opened up and serviced by a repair shop.
Posted on Sep 22, 2007
shadow5599
  • 51 Answers
SOURCE: DVD Drawer / VHS Eject button
My 1st suggestion is to pull the AC power plug from the wall, wait 5 minutes (have a smoke or a coffee) and plug it back in.
Then retry the functions that are giving you grief.
Report back with the results and we'll go from there.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating Other than Solved
Posted on Oct 18, 2007
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
SOURCE: dvd wont eject
Look at the bottom of the unit, under the disk drive. You'll see an open slot about 1 3/8" long. If you look in the slot, on the right (facing the front of the machine) you'll see a small (about 1/8" square") piece of while plastic. Insert a small bladed screwdriver to the right of the white plastic square and slide the square all the way to the left end of the slot. When you do this, the tray will open enough for you to pull it out and remove the offending disk.
Posted on Dec 25, 2007
Cadillac dolby sund system will not play or eject 2008 sts
the internal mechanism has died ,one of the plastic wheel has worn out ,just renew the player and get one with USB and SD card players then you will not need lots of CDs cluttering up your car
Dec 02, 2012 | 2008 Cadillac STS
2002 maxima cd player would not eject
This is not a fix, but if you can see the CD and it's not ejecting, get two box cutter razor blades place one blade above the CD and the other under it. Squeeze the blades gently together using needle nose pliers. Be sure not to push the blades in too deep. Sometimes CD players will not play home copied CDs
Sep 14, 2009 | 2002 Nissan Maxima
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
Alpine CDE0-7826P Cd Player doesn't always work
If It dosent play burned cds its not an mp3 compatiable cd player as far as the other problem kinda seems like its time for a new cd player
Jun 14, 2009 | Alpine CDE-7826P
Jesen touch screen player new will not play cds or dvds , it will scan the disk and in a moment will promptly eject the disk . is this a factory recall?
My first question is: Has it ever played CDs? If not, it try using factor CD's and NOT Burnt ones.
I also recommend taking the cover off the player and use rubbing alcohol and a cotton swab and clean the glass laser eye. They tend not to read when they are dusting.
If the player is going to work, it will after the suggestions I just made. Otherwise the laser or laser motor may be faulty.
May 22, 2009 | Jensen Car Audio & Video
TV DVD VCR combo eats tapes and now won't eject DVD's
Its shot, time to get a new one. dvd players are now only $20
do you have a newer lcd tv. Id say look into getting an upconverter,itll play your dvds at 1080 :) better picture.
Feb 27, 2009 | Philips Magnavox MWD200G DVD Player
Samsung dvd-r130
you advertise on web sit let our experts solve your problem for free then you want me to pay im out of work at 60yrs old or i would gladly pay to hep me fix the problem
all the best and thanks
Jan 14, 2009 | Samsung DVD-R130 DVD Recorder
Televison & Video Logo
16 people viewed this question
Henry  Thomas
Henry Thomas
