Question about Kenmore 47732 / 47734 / 47739 Electric Double Oven
Hi, The door of the oven of my kenmore cooker locked itself and the code 'F9' flashes alternatively with the code 'dr' can you please give me some help to fix this issue? Thanks
  • 2,382 Answers
Hi, the F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Posted on Oct 09, 2010
Self clean is locked but door still open
oven won't heat, "door locked" always flashing if I push"off/cancel there is a crackeling noise and "F9" fashes for a while then stops, Display flashes "door locked" but door will open but will not heat and now always flashes "door locked"
Dec 18, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
721.646662 microwave runs 5 seconds & gets f9 error code
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 16, 2010 | Kenmore Ovens
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
The F9 code indicates there is a problem with the door lock.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Hit the "clean " button on my gas stove. Not only did it not clean but the Door locked button has been flashing for 2 weeks. Everytime I go to cook and it the Bake, Broil key it flashes DR then F9 I h
Personal opinion. Do not mess with settings on a gas stove. Call a gas oven repair tech and have them come out and fix it. That way if it happens again you have someone to call
Nov 03, 2017 | Frigidaire (FEB30S7D) Oven
The lock switch is on and door is open-"dr" then "f9" message
Unplug the range and then have someone hold in the door/light button while plugging in the unit again. The locking mechanism should reset itself. Let me know if I can help further.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven clean 'dr', F9, door lock flashing
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&^%$%^
Jun 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
F9 code
F9 is a Door latch failure need to replace door latch or check wire or latch motor
Dec 13, 2007 | Amana AOCS3040 Electric Single Oven
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Kenmore 47732 / 47734 / 47739 Electric Double Oven Logo
413 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
